Badger5Sky Insurance
Results 1 to 24 of 24
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Any way to adjust the front/rear brake bias?
    Just wondering if there was any way at all to adjust the brake bias? Basically the rears don't appear to do a thing. I changed my rear discs and pads 2 weeks ago as they were nearly 3 years old and the components I removed were like brand new!
    Is there a bias lever attached to the rear beam? For some reason I thought the bias was adjusted by the height of the car. So the more passengers/weight in the back, the lower the car and the bias lever would adjust similar to the xenon lever on the front?
    I know some other VAG cars have a screw type thing to adjust the bias but is there anything we can do at all to our cars?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,585
    Not sure on our S3's but my mk2 has a brake bias valve, which is height dependant on the rear. Our S3's have brake force distribution, not sure what it exactly does, but it's suppose to spread the braking forces, when the ABS kicks in or something?
    Anyways, on my S3, when I put the ECS stage1 kit on, I could see a line of brake dust on the rear wheels after a track session, so they are definitely doing something on my car.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Strange because I've gone through 1 set of redstuff on the rear and over half way through a set of pagid RS2's which still got as spare and now got ds2500's on there but not sure how they're holding up as not checked them yet?
    Maybe got ultra hard pads on the rear?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    are you using standard rear Pads Westy?
    I've been using std rear pads up until now, and like you, there's almost NO wear at all. I've just changed to Mintex 1155 rears, but I don't have an engine to test them with :P
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    Rears on mine seem to shed a fair amount of brake dust, more than any other car iv owned. Oem Audi pads on the back and brembo pads on the front.
    Westy's Avatar
    Dec 2008
    17,283
    Well they were standard but are now ferodo road pads. The car feels like its doing an endo under extreme braking.
    S3 Build Thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Strange that one Westicles, my front brakes are bigger/better than yours (not a brag - just a statement) and my rear end is MUCH lighter, yet I don't suffer too much.
    Too much dive from the suspension maybe causing the weight transfer?
    I run my car ever so slightly rear end down, as it helps it feel more stable under heavy braking.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Ahh just had a thought I was running them stupid boxster rears for nearly a year and expect due to the ****eness (smaller pistons) was exerting a lot more force on the pedal thus the rears were probably doing a lot more work
    I expect now with the size of the front pistons they would be doing very little and would be interested if there was a way to move the bias a bit? Although have moved a tad more force on the rears by increasing the disk size?
    Westy's Avatar
    Dec 2008
    17,283
    It's as if bias is hugely out but its been like that since my OEM fronts were on. Both the rear discs and pads I removed were hardly worn. I bet they could have lasted another 3 years easy.
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Apart from little wear are there any symptoms? as in heavy front diving? try slam on, obv when save to do so and see how it reacts? mine are the same but obviously working or they would soon rust up..
    Westy's Avatar
    Dec 2008
    17,283
    Back goes light and it's a bit of a fight to keep the car straight. I'll be testing it properly at Bedford Autdrome on track in November but it would be nice to have a little more rear braking.
    S3 Build Thread
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,585
    Bleed rear brakes or sign of rear caliper seizing?
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by jojo View Post
    Rear callipers seem fine. No issue on wind back when fitting new discs and pads. I have 2 litres of RBF660 in the garage so I'll be bleeding the whole system when I get time.
    S3 Build Thread
    JMZ
    JMZ's Avatar
    Aug 2012
    Sunshine Coast, Australia
    12
    i've had the exact same problem in my '07 S3 Westy, although mine is more pronounced when braking up hill (sounds funny but i'm clocking 200km/h and there's a sharp left hander just over the crest so braking starts when going up the hill).
    It must be a bias thing because, well, none of us have stupid big wings on the back (because racecar!) to induce rear downforce. But it seems that there is no way to change the bias going by the responses so far. Certainly interested in finding out.
    Who's the resident Audi mechanic on here?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Try a rear diffusewr, flat underside and a functional front splitter
    May 2010
    Bedford
    2,877
    Few paving slabs in the boot will sort it.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Westy's Avatar
    Dec 2008
    17,283
    You bloody jokers! Next you'll be suggesting fat birds in the boot to make the car look lower!
    S3 Build Thread
    May 2010
    Bedford
    2,877
    I did actually type stick a fatty in the back but changed it lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    <tuffty/>
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,377
    Of course there are ways of altering the brake Bias, remove the ABS system entirely and fit a bias valve
    that's generally only used to reduce rear bias though, if your brakes are mechanically hugely unbalanced (monster fronts with small rears) I'd imagine it's a little harder to rectify.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Simplest way to alter bias is to alter the size of the caliper pistons, or fit larger/smaller disks as appropriate.
    Obviously from the factory the bias is setup "right". It will typically be slightly forward of perfect bias, as this makes the car more stable under braking and stops the arse end wanting to lock up and put you sideways. Basically nice and safe for normal motorists.
    Now you've changed the front calipers for the Brembo's, the piston sizes are similar, so at first glance nothing should have changed, however the brembos will flex a lot less, meaning for an equivalent line pressure, more of the force will end up transferred into the pad. As a result you've probably shifted the bias a little further forward if anything.
    The oddness is that what your reporting is the rear end squirming around under braking and the car being unstable, which is as though the rear has too much bias. Too much front bias typically just means the fronts get overheated quicker and your stopping distances increase. It shoudlnt really cause the car to become unstable.
    I guess the first step is to ensure 110% that they ARE boxster front calipers, and not rears? I'm sure they have part numbers on them that you can look up. Generally "351" is front and "352" is rear. After that i'd be looking at geometry issues, perhaps worn bushes causing toe change under braking or similar?
    TD5 Land Rover Defender build
    Westy's Avatar
    Dec 2008
    17,283
    Good info mate thanks.
    They are definitely Boxster fronts, checked the part numbers a million times before I bought them. I don't think that running budget tyres on a 280bhp car is particularly helpful! I'll bleed all 4 callipers and see how it behaves with proper rubber at ADI
    S3 Build Thread
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    Check to see if your discs are not warped slightly on the front , meaning you don't exactly have smoothness on the fronts and making the braking a little more aggressive on front.
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by Buzzer View Post
    It's all brand new discs and pads all round. Old discs were fine when they came off too.
    S3 Build Thread
  1. One for those with the 300mm rear brake set up...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2012, 11:20
  2. Knock from the front while braking
    By Mizan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2012, 16:44
  3. RS4 Front & Rear Brake Discs (Fantastic Prices)
    By shedboy13 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 24th January 2012, 11:00
  4. Replies: 4
    Last Post: 5th November 2010, 18:15
  5. Checking of the left rear brake pipe on new A3's
    By StephaneS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2004, 11:23
