Volks AutosAH Fabrications
Results 1 to 12 of 12
    Jun 2008
    Thirsk, North Yorkshire
    12
    Wiring help please...
    Hey guys, got a 2000 A3 1.8T Quattro.
    The alarm doest work, neither does the remote central locking, so...
    Ive got an aftermarket alarm to fit...
    Ive fit a quite a few before but i dont have the wiring diagram for the A3 so could do with some help.
    I need wiring diagrams for; central locking, electric windows, indicators, ignition..
    Any help would be great.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    The stock alarm and RCL is controlled by the locking pump in the boot. the locks are all pneumatic so an aftermarket system isnt really going to work if the pumps dead.
    The windows and various other things like interior lighting also wont work properly without the stock locking pump...
    Your far better off just properly fixing whats broken. You can buy replacement pumps on ebay for around £50.
    TD5 Land Rover Defender build
    Jun 2008
    12
    the central locking works, just not from the remote..
    everything is fine with the alarm just the siren doesnt work, id rather fit an after market alarm as the standard one is useless even if working.
    Sep 2010
    Devon
    756
    Sounds stupid but have you put a new battery in the remote? That fixed the problem for me when mine didn't work
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Jun 2008
    12
    yeah tried the battery..
    id rather fit the new alarm because the standard one is useless and is no where near loud enough
    "Stick a V8 in it!"
    15,370
    Move the standard siern to under the bonnet and it'll be much louder. Get one off ebay from a newer Audi as they revised the design.
    Remote key probably just needs matched with the pump again.
    Jan 2012
    74
    I just did this - Will dig out the wiring when this wet stuff stops falling out the sky
    1998 Audi A3 1.6 Sport
    Jun 2008
    12
    cheers mate, much appreciated
    Jan 2012
    74
    Ok so for the remote central locking - Assuming the pumps are the same you need
    Audi Side
    There are 3 plugs that go to the central locking Pump.
    Power Plug = Self explanatory
    Black Plug = Has the Close signal wire
    Brown Plug = Has the Open Signal wire
    Power plug (haven't documented the colour, but has unique cable colours to identify)
    12v+ = RED/BLACK 10A general fused supply - your unit has a de-rated fuse
    12v- = Brown
    Black Plug Close
    Red/Brown cable - note* watch out there is a Brown/red cable also on the same plug!!!!!
    Brown Plug Open
    Grey cable
    ^^ Praise goes to A3steve^^ - I used this with my Hawk Kit and it all works fine - I used ScothLocks to connect it up, The pump can be a bit of a prick to get out, also make sure you put the sound proofing back around it as it is one noisy bit of kit
    Hope this helps
    Jun 2008
    12
    Cheers mate, any chance u can remember if its triggered by a live or earth on the lock and unlock? Got all the alarm wired apart from central locking
    Jan 2012
    74
    Negative switched off the top of my head - will pull out some paperwork and double check though
    Jun 2008
    12
    Cheers mate
  1. Avant rear wiper wiring help please.
    By mike-a in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2011, 19:12
  2. Help please - Running Live wire through bulkhead.
    By equinoxsu in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 00:11
  3. right click wire help please
    By mikeya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2009, 08:32
  4. Dension wiring help please
    By jimmymidnight in forum In-Car Entertainment
    Last Post: 15th April 2009, 15:20
  5. Headunit wiring help please !
    By Sam-K in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2007, 10:21
