Volks AutosMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 73
    darko's Avatar
    Dec 2004
    london, uk
    272
    Help ! clutch pedal is dead...
    (luckily?) just as i was parking the car outside my flat i heard a loud crack and the clutch pedal fell to the floor (i was just half way through pressing it down) I had a look down there and the pedal is stuck down with pieces of sheared plastic on the floor mat.. Ive had a look through tons of posts and it seems this has happened to people before but i wanted some information about fixing it myself if possible ? the car is a 2001 S3. hopefully the weather will stay ok and i can use my scooter till I fix the car.....
    Please help !
    vbking's Avatar
    Dec 2004
    Bristol
    20
    Re: help ! clutch pedal is dead...
    Had this happen to me last christmas - not nice (I thought something major had broken). You will be able to fix it yourself, but from what I can remember it was a complete ball-ache of a job.
    You'll probably need a couple of new parts to fix the problem - a new clutch pedal (as it will be one of the welds on your current pedal that has snapped) and a new plastic bracket (not sure of the name of the part - it is the black bit that makes contact with the clutch sensor - but show whats left of it to someone down at audi and they will know what it is). These will set you back about 20 in total.
    To fit the parts you will have to take the bottom half of the dash off as the pedal attatches way up inside (there are a few screws and some clips holding the dash on). As I did this over 6 months ago I cant remember exactly what I did but basically you need to first remove the current clutch pedal by removing the bolt which attaches it to a large metal bracket up inside the dash - then install the new one.
    Somewhere amongst the broken bits on your floor should be a white clip(this should still be intact). This fits inside the bracket on the side of the clutch pedal - the ball on the top of the clutch cylinder then clips into this. Sounds simple, but it is a pain in the arse and the bit that took me the longest.
    Fitting the black bracket is the easist bit as this simply clips into a couple of holes on the arm of the clutch pedal. (you will see where this needs to go by looking at where the pedal makes contact with the sensor)
    If I remember correctly, the steering column and the clutch sensor get in the way, so you may need to turn the steering wheel until the column moves out of your way. The sensor is easily removed.
    Sorry about the lack of detail. If I remember anything else I will update my post. You will also get a bad back from laying on the door sill for hours [img]/ubbthreads/images/graemlins/frown.gif[/img]
    darko's Avatar
    Dec 2004
    london, uk
    272
    thanks for the info ! i will have a go at doing it myself and if i cant do it ill have to get it towed to the local audi specialist.. i managed to download a pdf showing how to remove the pedal which also shows a special tool for doing the part you mentioned was difficult - i might invest in one of those if it means less back breaking time!!
    darko's Avatar
    Dec 2004
    london, uk
    272
    mmm
    right fixed the pedal with a new clip, was a bit of a arse of a job. all was fine for about 20 miles and now its happened again except this time i dont think the clip has broken... will have to get the car towed home to check it properly but maybe the master cyclinder has gone ? does anyone have any more info to offer on this ?
    darko's Avatar
    Dec 2004
    london, uk
    272
    i think the answer may be because i didnt replace the actual pedal too ! lots and lots of info on this problem on the tt forum plus full info on the work required here:
    http://www.kisolutionz.com/ttforum/clutchinfo.pdf
    luckily a new pedal is around 15 and the clips if i need new ones again only cost 2.37
    part numbers for clips are:
    1H0721357 - mounting
    1J2721332A - stop
    ill try to post some pictures this time when i do the job again.....
    darko's Avatar
    Dec 2004
    london, uk
    272
    i have some pix of the broken pedal - cant remember ho w to post though ??!!?, the quality of the welds and in fact the metal are a throw back to 1970s Alfa Romeos ! I had the new pedal welded along the left hand edge where the original has no welding at all so hopefully that will stop it ever happening again....
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Upload them to http://www.imageshack.us
    Then you can link it here.
    darko's Avatar
    Dec 2004
    london, uk
    272
    [image]http://img314.imageshack.us/my.php?image=clutchpedala4hs.jpg][/URL][/image]
    Jun 2003
    Hythe, Kent
    1,180
    [image]http://img314.imageshack.us/my.php?image=clutchpedala4hs.jpg[/image]
    Kev.
    EDIT: now why won't that work?!
    darko's Avatar
    Dec 2004
    london, uk
    272
    have a better pic too - not sure what i did wrong ?
    Jun 2003
    Hythe, Kent
    1,180
    Host the pic, right click on it and view properites, copy and paste the url between the image tags...
    Should be as simple as that.
    Kev.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Clicky the piccy.
    Just to let you know this forum uses (img)(/img), rather than (image)(/image). But with square brackets.
    darko's Avatar
    Dec 2004
    london, uk
    272
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    i have just taken my lower dash off and my problem is EXACTLY the same.
    Thing i cant work out is how do you get the pedal off??
    I tried removing the whole pedal box but the master cylider is connect to it. Cant work out how to get the pedal off without the spring going off and then it would be impossible to get back in i reckon.
    advice please.
    Age 18: CRX MK2 | Age 20: Corrado VR6 | Age 21: Audi S3 (rip) | Age 23: Audi S3 | Age 25: BMW E46 M3
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    You only need to remove the pedal pivot bolt IIRC.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    quite difficult with that big spring though!
    Sep 2006
    In the Westcountry
    185
    Yeah. That spring can be a PITA.
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    done.. its all off. the white clip seems intact. just the pedal that broke. will take it to audi tomorrow and shove a rocket up their ass... or maybe the pedal!!
    Sep 2006
    In the Westcountry
    185
    The design of the pedal is flawed. The new pedal is the same, so unfortunately it is only a matter of time before that breaks too.
    The only consolation is most dealers usually have the three parts in stock.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    How very amusing... it would appear my car has it in for me this week... guess what's just broken... where's JoJo... after my last post I'm sure this will make someone laugh!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    You called? I havn't been driving my S3 lately, been too busy, but funily enough, a mate of mine called me yesterday to ask for a quick fix for this very same problem... he called the AA in the end... must be the weather!.
    You've got to have a laugh!
    mazzy's Avatar
    Jan 2004
    West Midlands, UK
    299
    Quote Originally Posted by jojo
    Sorted it, had it stripped down yesterday and fitted the plastic clip and had the pedal welded as Audi did not have 1 in stock. Just 1 thing...
    Where does the BLACK plastic thing go???
    Jun 2004
    Crowthorne, England
    2,512
    Err, chaps, anyone that's done this I have a quick question... how hard was it to push the metal link into the cylinder to allow you to fit the new pedal?
    Managed to swap the pedal and sort the spring pretty easily and I'm sure this bit shouldn't be a serious arse ache to do...
    Jun 2004
    Crowthorne, England
    2,512
    Well got that sorted (all made sense in daylight), but a quick question for anyone what does the switch on the front of the pedal mounting actually do?
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    Quote Originally Posted by god_thats_quick
    Pretty damned hard to push back in mate! Is the metal rod straight? When this happened to me a few months ago, it was because the master cylinder locked up and the force of me puting my foot on the pedal caused it to bend the metal link rod!
    Jun 2004
    Crowthorne, England
    2,512
    It's interesting you said that - did you need a new master cylinder?
    Mine was very slightly bent towards the pedal end, not even worth trying to bend back and got it all sorted.
    I'm just wondering if the switch at the front it working as it should (and WTF it does)?
  28. #27
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    Yeah, I had to have a new master cylinder. Had that, new pedal and all the plastic clips etc, cost me around 70 from VW. (Same parts as used on mk4 Golf which I assume you know.)
    I'm not entirely sure what the switch does, but I think it's something to do with the ECU.
    I changed the cylinder myself btw and fitting it is very easy, bleeding it however is a *****!!!
  29. #28
    Jun 2004
    Crowthorne, England
    2,512
    I don't seem to be able to change gear smoothly (which could just be my driving ) but it wasn't a problem before. So I'm guessing either that switch isn't doing it's thing or there is something more seriously up with my car... which is nice.
  30. #29
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    The switch attached to the clutch pedal is supposed to make gear chaning easy and smooth. I think it must somehow drop the revs slightly as you change gear.
    When In changed my brake light switch the first time I took the clutch switch off by mistake. Easy thing to do as it is in the middle!!
    when I collected the brake switch from the dealers parts department I asked them what it did, and they just said, "something to do with making gear changes smoother"
    It may be that the switch has been broken or damaged when you changed the clutch pedal.
    I think they quoted me something like 13 for a replacement
    Simon
    A6 2.5tdi Quattro Sport 180
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    RNS-E, Audi BT, Phatnoise
  31. #30
    larsmate's Avatar
    Apr 2004
    111
    Quote Originally Posted by simonwjones
    It's actually for disengaging the cruise control. The switch is there regardless of whether you have cruise or not. That's why it's so easy to retrofit cruise.
    Black S3 | MY09 | APR 3.1 Stage 2+ | RNS-E Mk2 | Tints | Titaniums | APR DP | APR HPFP | WALK | H&R SPRINGS | Lamin-X | BlueVAG VAG-Check |
  32. #31
    Jun 2004
    Crowthorne, England
    2,512
    Thanks chap, that's what I though it was from the instructions as they refer to it at the cruise control sensor, however my car doesn't have cruise so wasn't 100% sure.
  33. #32
    PocketRocket's Avatar
    Jan 2006
    Lima - Peru
    78
    I've been messing with that sensor too. My A3 does not have cruise control, are you 100% sure that sensor is only for disengaging cruise control? no additional functionality?
  34. #33
    Bellic's Avatar
    Dec 2006
    253
    i think it does something with the revs keeps it stable when changing gears
  35. #34
    oversteer's Avatar
    Aug 2007
    23
    Mine broke last night... lucky me it was right in front of my house...
    Planing on fixing it on Saturday... only got one question... what time frame am I looking at to complete the swop from the old pedal to a new one?
    Also what tools will I need?
  36. #35
    Bellic's Avatar
    Dec 2006
    253
    should take an 1 hour for a novice , i think a couple of 13mm spanners
  37. #36
    oversteer's Avatar
    Aug 2007
    23
    Thanks!
    Kinda keen on doing this... been without a car for the whole week...
  38. #37
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    my pedal snapped today.on a hill on ten idr in Reading near the police station how fun,lkuckily my mate had his work van so we towed it home,removed the dash and found the broken weld,the spring jumped out so not entirely sure how it goes back.bloody car
    A4 TDI S-LINE
  39. #38
    Audi_Alex's Avatar
    Apr 2008
    Milton Keynes
    57
    hey there,
    i've just had my clutch pedal break on me and i'm struggling with trying to get the car in a working state! I see that some guys compress the over-centre spring before removing the pedal via the pivot bolt. How difficult is it to re-assemble if the spring isn't compressed. I don't see it being very easy?!
    I've got welding facilities so looking at the pedal a different way, i'm trying to take out the pedal and spring assembly which is bolted to the bulkead with 3 locking nuts. I thought loosening these would let the pedal box come away from the car, but the master cylinder has a complex three sided plastic clip which keeps the the cylinder attached to the pedal box. Is there someway of removing this plastic clip so i can get rid of the spring compressing process?
    Many thanks in advance.
    2000 Audi S3
  40. #39
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Just for your info guys..... this happend to me too about 6 months back just as i pulled of a motorway.... it is possible to still drive the car without a clutch pedal.... it's not easy but saved be the price of a callout from a break down wagon... with the engine off select 1st gear then with a small ammount of preassure on the accelerator turn the engine over.. the starter will pull you forward and the engine should catch and you'l be away in first gear.... accelerate then knock it out of gear and blip the accelerator whist pushing it into second gear... you can do this all the way up through the gears.... when it comes to changing down gears you need to rev the engine higher between gears but it works... i wouldn't recomend doing this for long periods but it got me home when mine went 3 miles from home... you just need to time it right for the traffic lights.... :o)
    http://www.answerbag.com/q_view/35127
    Might help someone in the future
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
  41. #40
    Audi_Alex's Avatar
    Apr 2008
    Milton Keynes
    57
    Hey, did you try to fix the breakage yourself or take it to a specialist? Would like to know about the spring before i demolish my car!
    cheers
    2000 Audi S3
