Like Tree1Likes
  • 1 Post By superkarl
Thread: S3 akm clutch
    May 2012
    30
    S3 akm clutch
    Hi all
    Im sure i felt my clutch slip slightly a couple of times on the way home from work this morning
    Just having a quick nosey online and found this AUDI S3 SOLID MASS FLYWHEEL SPORTS CLUTCH KIT & BEARING | eBay
    Would be any good or am i better of sticking with a standard kit? Would i need to replace the dmf or would i get away with it if i stay standard?
    Cheers,Tony
    Aug 2011
    160
    Once the gearbox is off you can check the state of the flywheel, but yes you'll always better off in the long term replacing the DMF when doing a clutch.
    That ebay flywheel looks ok but I have a thing about clutch kits that have been painted RED on ebay, most of the time they're s**t.
    Maybe someone here has used this kit and will be able to give you more info.
    Audi A3 1.8T AUM Sport with more doors.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    AVOID.
    just do a quick google search on techniclutch to see why
    moredoor likes this.
  1. New clutch sorted and cheap !
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2003, 11:31
  2. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
  3. Clutch Dilemmas
    By RAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2003, 21:47
  4. Has anyone fitted MTM clutch?
    By theodore_p in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2003, 12:12
  5. Lifetime of an S3 Clutch - 18months / 12K miles??
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2003, 09:25
