Badger5Monster Motorsport
Page 1 of 3 123 LastLast
Results 1 to 40 of 86
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    3rd Gear logs for Chaz20vt - Limp Mode
    I've just been out logging a mapped (think MTM) for chaz20vt
    As far as i am aware it is a stage 1 map with a FMIC and a DV (full recirc)
    The complaint was that the car was accelerating and then felt flat/limp. The logs below show the requested boost dropping back after ~3500rpm correlating with timing pull that starts on cylinder #2 (8.3!) and then all 4 cylinders are being pulled
    What is likely to be causing these issues for him? What else should be logged?
    There was one fault code on the car:
    16795 - Secondary Air Injection System
    P0411 - 35-10 - Incorrect Flow Detected - Intermittent
    Thanks in advance for help/advice
    1st Log
    Code:
    Group A: '003 Group B: '115 Group C: '031
    Engine Speed Mass Air Flow Throttle Valve Angle Ignition Engine Speed Engine Load Boost Pressure Boost Pressure Lambda Control
    TIME (G28) Sensor (G70) Timing Angle TIME (G28) (specified) (actual) TIME Bank 1 (actual)
    STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP V
    0.3 840 2.97 1.6 5.3 0.6 840 19.5 990 1010 0 0.21
    1.2 840 3.06 1.6 3 1.5 840 19.5 990 1010 0.9 0.485
    2.1 840 3 1.6 4.5 2.4 840 19.5 990 1010 1.8 0.685
    3 840 3.06 1.6 3 3.3 840 19.5 990 1010 2.7 0.08
    3.9 840 3.03 1.6 4.5 4.2 840 19.5 990 1010 3.6 0.71
    4.8 840 3.03 1.6 4.5 5.1 840 19.5 990 1010 4.5 0.09
    5.7 840 2.97 1.2 4.5 6 840 19.5 990 1010 5.4 0.685
    6.6 840 3 1.6 5.3 6.9 840 19.5 990 1010 6.3 0.085
    7.5 840 3.03 1.6 4.5 7.8 840 19.5 990 1010 7.2 0.12
    8.39 840 2.94 1.6 5.3 8.69 840 18.8 990 1010 8.1 0.705
    9.29 840 3 1.6 5.3 9.59 840 19.5 990 1010 8.99 0.075
    10.19 840 2.97 1.2 2.3 10.49 840 19.5 990 1010 9.89 0.67
    11.09 840 2.86 1.2 6 11.39 840 18.8 990 1010 10.79 0.675
    11.99 840 2.86 1.2 4.5 12.29 840 18.8 990 1010 11.69 0.085
    12.89 840 2.86 1.2 6 13.19 840 18.8 990 1010 12.59 0.715
    13.79 840 2.83 1.2 4.5 14.09 840 18.8 990 1010 13.49 0.485
    14.69 840 2.81 1.2 3 14.99 840 18 990 1010 14.39 0.1
    15.59 840 2.56 1.2 10.5 15.89 840 18 990 1010 15.29 0.71
    16.49 840 2.86 1.2 6 16.79 840 18.8 990 1010 16.19 0.065
    17.39 840 3 1.2 2.3 17.69 840 18.8 990 1010 17.09 0.67
    18.29 840 2.94 1.2 3.8 18.59 840 18.8 990 1010 17.99 0.7
    19.19 840 2.89 1.2 0.8 19.49 840 18.8 990 1010 18.89 0.09
    20.09 920 4.86 3.5 21 20.39 1160 26.3 990 1010 19.79 0.71
    20.99 1200 3.11 2 27 21.29 1160 14.3 990 1010 20.69 0.74
    21.89 920 2.86 1.2 9 22.19 840 16.5 990 1010 21.59 0.055
    22.79 840 2.92 1.2 0 23.09 840 18.8 990 1010 22.49 0.06
    23.69 840 2.97 1.6 3 23.99 840 18.8 990 1010 23.39 0.785
    24.59 840 2.86 1.2 4.5 24.89 840 18.8 990 1010 24.29 0.71
    25.49 840 5.5 4.3 21.8 25.79 1160 30.1 990 1010 25.19 0.095
    26.39 1920 13.28 8.6 29.3 26.69 1840 36.8 990 1010 26.09 0.81
    27.29 1440 10.56 7.1 26.3 27.59 1280 40.6 990 1020 26.99 0.69
    28.18 1000 9 6.3 24 28.48 1160 42.9 990 1020 27.88 0.75
    29.08 1440 11.72 8.2 25.5 29.38 1560 42.9 990 1020 28.78 0.715
    29.98 1880 16.19 10.6 27.8 30.28 2040 46.6 990 1030 29.68 0.125
    30.88 2400 23.61 14.5 25.5 31.18 2600 52.6 990 1060 30.58 0.695
    31.78 3000 31.86 17.6 19.5 32.08 2960 21.8 990 1160 31.48 0.095
    32.68 2360 4.44 3.5 9.8 32.98 2120 10.5 990 1050 32.38 0.04
    33.58 1400 11.28 7.5 24.8 33.88 1320 42.9 990 1020 33.28 0.065
    34.48 1440 23.69 65.5 18 34.78 1520 80.5 1400 1060 34.18 0.835
    35.38 1680 28.56 76.5 12.8 35.68 1760 91.7 1720 1150 35.08 0.075
    36.28 1920 38.53 84.7 12 36.58 2000 107.5 1900 1250 35.98 0.79
    37.18 2200 50.36 90.6 11.3 37.48 2280 124.1 2100 1410 36.88 0.825
    38.08 2520 67.36 96.9 12.8 38.38 2640 142.9 2270 1640 37.78 0.82
    38.98 2880 97.06 99.2 8.3 39.28 3040 180.5 2370 2010 38.68 0.83
    39.88 3400 136.31 100 4.5 40.18 3560 191.7 2340 2450 39.58 0.855
    40.79 3920 154.67 66.3 4.5 41.08 4080 158.6 1890 2190 40.48 0.865
    41.69 4320 126.42 100 10.5 41.99 4480 156.4 1820 1770 41.39 0.86
    42.59 4680 135.03 100 11.3 42.89 4800 146.6 1750 1730 42.29 0.87
    43.49 5040 136.5 100 12.8 43.79 5160 144.4 1720 1700 43.19 0.865
    44.39 5360 145.56 100 13.5 44.69 5440 143.6 1690 1690 44.09 0.87
    45.29 5640 156.58 100 15.8 45.59 5760 141.4 1710 1680 44.99 0.88
    46.19 5960 165.08 100 15 46.49 5840 63.9 990 1950 45.89 0.885
    47.09 4840 6.67 3.5 9.8 47.38 4480 6 990 1120 46.79 0.66
    47.98 4480 24.78 14.1 35.3 48.28 4480 30.1 990 1080 47.68 0.06
    48.88 4440 16.36 10.6 35.3 49.18 4440 19.5 990 1070 48.58 0.09
    re-log
    Code:
    0 840 3.58 2 2.3 0.3 840 21.8 990 1010 0.6 0.69
    0.9 840 3.69 2 0.8 1.2 840 22.6 990 1010 1.5 0.065
    1.83 840 3.69 2 -2.3 2.2 840 21.8 990 1010 2.5 0.145
    2.8 840 3.5 2 0 3.1 880 21.8 990 1010 3.4 0.665
    3.7 1000 4.03 2.4 24.8 4 960 23.3 990 1010 4.3 0.685
    4.6 1120 9.81 7.1 19.5 4.9 1040 48.1 990 1010 5.2 0.755
    5.5 1040 10.28 7.8 15.8 5.8 1160 49.6 990 1020 6.1 0.1
    6.4 1360 11.5 8.2 24 6.69 1520 44.4 990 1020 6.99 0.075
    7.29 1920 23.44 18.4 23.3 7.59 2160 67.7 990 1050 7.89 0.745
    8.19 2720 40.06 26.3 24 8.49 2920 54.1 990 1200 8.79 0.825
    9.09 2360 4.19 3.5 10.5 9.39 2080 10.5 990 1070 9.69 0.035
    9.99 1240 17.5 14.5 19.5 10.29 1480 71.4 1350 1050 10.59 0.755
    10.89 1560 25.39 71 13.5 11.19 1600 87.2 1600 1110 11.49 0.72
    11.79 1800 32.83 80.4 15 12.09 1880 96.2 1820 1190 12.39 0.825
    12.69 2040 43.25 88.6 12.8 12.99 2120 112.8 2040 1310 13.29 0.82
    13.59 2360 57.94 94.1 12 13.89 2480 129.3 2220 1490 14.19 0.8
    14.49 2720 77.81 98.4 9.8 14.79 2840 154.9 2350 1760 15.09 0.855
    15.39 3120 117.81 100 7.5 15.69 3280 191.7 2370 2290 15.99 0.86
    16.29 3680 156.97 100 6.8 16.59 3840 191.7 2270 2480 16.9 0.865
    17.2 4200 124.17 40.4 4.5 17.5 4320 144.4 1870 1960 17.8 0.86
    18.1 4560 134.92 100 7.5 18.4 4680 153.4 1810 1790 18.7 0.875
    19 4880 137.31 100 11.3 19.3 5000 145.1 1770 1740 19.6 0.875
    19.9 5240 152.44 100 12 20.2 5360 152.6 1810 1790 20.5 0.885
    20.8 5560 160.47 100 14.3 21.1 5680 148.9 1720 1780 21.4 0.885
    21.7 5880 162.56 100 14.3 22 6000 143.6 1690 1750 22.3 0.89
    22.6 6200 171.53 98.8 14.3 22.9 6280 142.9 1620 1810 23.2 0.9
    23.5 6440 163.03 63.9 17.3 23.8 6520 129.3 1610 1790 24.1 0.895
    24.4 6640 157.92 54.9 18 24.7 6720 130.8 1610 1750 25 0.91
    25.3 6840 157.69 54.9 18 25.6 6920 130.1 1600 1740 25.9 0.6
    26.2 6080 9.47 5.1 14.3 26.49 5520 6.8 990 1180 26.79 0.795
    27.09 4560 5.28 3.9 9.8 27.38 4200 6.8 990 1080 27.68 0.01
    27.99 5040 7.53 5.1 10.5 28.29 4920 7.5 990 1050 28.58 0.005
    28.89 4800 8.28 5.1 9.8 29.19 4720 9 990 1040 29.48 0.005
    29.8 4080 7.81 4.7 9.8 30.08 3640 9.8 990 1040 30.39 0
    30.68 2800 4.89 3.1 9.8 30.98 2400 9 990 1040 31.28 0
    31.58 2560 4.5 2.7 9.8 31.88 2640 9 990 1040 32.18 0
    32.48 2600 5.22 2.7 9.8 32.78 2600 9.8 990 1040 33.08 0
    33.38 2520 5.06 3.1 9.8 33.68 2520 9.8 990 1040 33.98 0
    34.28 2440 4.81 3.1 9.8 34.58 2400 9.8 990 1040 34.88 0
    35.18 2320 4.81 2.7 9.8 35.48 2280 10.5 990 1030 35.78 0
    36.08 2200 4.5 2.7 9.8 36.38 2160 10.5 990 1030 36.69 0
    36.98 2080 4.33 2.7 8.3 37.28 2080 10.5 990 1030 37.58 0
    37.88 2040 4.28 2.4 7.5 38.18 2000 10.5 990 1020 38.48 0
    38.78 1960 4.19 2.4 6 39.08 1920 11.3 990 1020 39.38 0
    39.68 1800 3.92 2.4 1.5 39.98 1800 11.3 990 1020 40.28 0
    40.58 1680 3.36 2 -3.8 40.88 1600 9.8 990 1020 41.18 0
    41.48 1440 2.89 1.6 -6 41.78 1360 10.5 990 1020 42.08 0.705
    42.38 1080 2.92 1.6 15 42.68 880 14.3 990 1010 42.98 0.08
    43.28 680 3.81 2.4 20.3 43.58 760 24.8 990 1010 43.88 0.78
    44.18 880 4.03 2.4 0.8 44.48 840 22.6 990 1010 44.78 0.07
    45.08 840 3.42 2 7.5 45.38 840 21.8 990 1010 45.68 0.11
    45.97 880 3.89 2.4 -2.3 46.27 880 21.8 990 1010 46.57 0.67
    46.87 840 3.56 2 3 47.17 840 21.1 990 1010 47.48 0.63
    Code:
    Group A: '003 Group B: '020 Group C: '031
    Engine Speed Mass Air Flow Throttle Valve Angle Ignition Timing Retardation Timing Retardation Timing Retardation Timing Retardation Lambda Control
    TIME (G28) Sensor (G70) Timing Angle TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4 TIME Bank 1 (actual)
    STAMP /min g/s % °BTDC STAMP °KW °KW °KW °KW STAMP V
    0.85 840 3.67 2 -4.5 0.25 0 0 0 0 0.55 0.13
    1.78 1440 9.08 6.3 24 1.15 0 0 0 0 1.45 0.065
    2.75 1440 10.67 7.8 24 2.15 0 0 0 0 2.46 0.455
    3.65 1040 11.31 9.4 9.8 3.05 0 0 0 0 3.35 0.685
    4.55 1320 9.94 7.1 23.3 3.95 0 0 0 0 4.25 0.685
    5.45 1680 14.89 10.2 24.8 4.85 0 0 0 0 5.15 0.62
    6.35 2280 28.42 20 23.3 5.75 0 0 0 0 6.05 0.35
    7.25 3160 53 36.5 22.5 6.65 0 3 0 0 6.95 0.105
    8.15 2920 3.72 4.3 13.5 7.56 0 2.3 0 0 7.85 0.83
    9.05 2200 27.67 18.4 26.3 8.45 0 0 0 0 8.75 0.04
    9.94 2520 47.25 34.5 21 9.34 0 3 0 0 9.64 0.1
    10.84 3080 83.08 100 15 10.24 0 3 0 0 10.54 0.11
    11.75 3880 72.14 24.3 -3.8 11.14 0 3 0 0 11.45 0.84
    12.64 2960 4.67 2.7 9.8 12.05 0 0 0 0 12.34 0.85
    13.54 2520 28.72 16.5 30.8 12.94 0 0 0 0 13.24 0.795
    14.44 2720 61.94 98.4 20.3 13.84 0 0 0 0 14.14 0.11
    15.34 3040 97.31 100 10.5 14.74 0 3 0 0 15.04 0.815
    16.24 3480 136.28 100 3 15.64 0 3 0 0 15.94 0.86
    17.15 4040 159.56 100 3.8 16.54 6 8.3 6 6 16.84 0.865
    18.05 4480 162.53 100 4.5 17.45 6 8.3 6 9 17.75 0.87
    18.94 4880 158.5 100 7.5 18.35 5.3 7.5 5.3 8.3 18.65 0.88
    19.84 5280 166.64 100 9.8 19.25 5.3 7.5 5.3 7.5 19.55 0.88
    20.75 5600 168.78 100 14.3 20.15 5.3 7.5 5.3 7.5 20.45 0.885
    21.65 5920 177.86 100 13.5 21.05 4.5 6.8 4.5 7.5 21.35 0.885
    22.55 6200 172.89 100 16.5 21.95 4.5 6.8 4.5 6.8 22.25 0.89
    23.45 6280 51.17 18.8 3 22.85 4.5 6.8 4.5 6.8 23.15 0.895
    24.35 5120 4.94 3.9 10.5 23.75 0 0 0 0 24.05 0.785
    25.25 4680 6.17 3.9 9.8 24.65 0 0 0 0 24.95 0.725
    26.14 4600 6.92 4.7 9.8 25.55 0 0 0 0 25.84 0.005
    27.04 4480 8.22 4.7 9.8 26.44 0 0 0 0 26.74 0.005
    27.95 4360 8.39 5.5 9.8 27.34 0 0 0 0 27.65 0
    28.85 4280 8.58 5.5 9.8 28.24 0 0 0 0 28.55 0
    29.74 4160 8.86 5.9 9.8 29.13 0 0 0 0 29.44 0
    30.63 4040 9.06 5.9 9.8 30.03 0 0 0 0 30.33 0
    31.53 3080 6.69 4.3 9.8 30.93 0 0 0 0 31.23 0
    32.43 1880 3.86 2 4.5 31.83 0 0 0 0 32.13 0
    33.33 2440 5.31 3.1 9.8 32.73 0 0 0 0 33.03 0.71
    34.23 2400 5.28 3.1 9.8 33.63 0 0 0 0 33.93 0.8
    35.13 2280 5.11 3.1 9.8 34.53 0 0 0 0 34.83 0
    36.03 2240 4.97 3.1 9.8 35.43 0 0 0 0 35.73 0
    36.93 2200 4.89 3.1 9.8 36.33 0 0 0 0 36.63 0
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    chaz20vt's Avatar
    Aug 2012
    425
    Thanks again for doing the logs hope some one can point me in the right direction now
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    It a apy s3? Mine showed the same fault and cleared it, never came back, relates to the sai, just removed mine, believe they can stick open and cause boost issues but not to the extent hes getting with the timing pull i dot think.
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    yeah its an APY.
    Here is a plot of the boost request (blue) and actual (red) for the 2nd log
    Alex S3 AMK
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Poss boost leak? What g/s did it make? The car standard? Did you clear the fault codes and did they come back?
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    yeah i scanned for fault codes for him a few weeks ago and at the time it had the following fault codes
    Code:
                    Address 01: Engine       Labels: 06A-906-032-APX.clbControl Module Part Number: 8N0 906 018
      Component and/or Version: 1.8L R4 5VT      01 0003
               Software Coding: 05610
                Work Shop Code: WSC 06313
                          VCID: EED839A8AA91FF68439
    2 Faults Found:
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-10 - Signal too Low - Intermittent
    Readiness: 0000 0000
    I cleared these fault codes
    I think the MAF error was an old fault code generated by a old split-R DV he used to have. But he has since replaced it with a full recirc DV and the fault has not returned
    Only the SAI fault reappeared
    Alex S3 AMK
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What g/s it make?
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    log #2 shows a peak g/s of 171 at 6200rpm
    Alex S3 AMK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,560
    Too tired to absorb this tonight but I'll try and have a look through it tomorrow and let you know my thoughts...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sorry mate my iphones not displaying the info properly. Well thats only making 213bhp with the divide by 0.8 rule sonits under power for a stage 1, could be poss maf, when mine went on my apy it only showed the maf code once then never come back but the maf was dead, new one fixed it. Has he checked for poss boost leaks? Poss do a n249 and sai delete them check from their, simple and cheap todo on the apy motor.
    chaz20vt's Avatar
    Aug 2012
    425
    Hi I did try Another maf and it seem to run the same but the maf was not a new one it was from another car
    So you suggest I do the n249 bypass, is the SAI hard to do
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    Alex S3 AMK
    Oct 2011
    760
    Delete both, both quite easy and guides in the stickies section.
    I have apy and ditched both.
    i have also done pcv delete.
    This will basically simplify your vacuum system and update your old rotting pipes.
    Oct 2011
    760
    when doing the sai delete, the pump is a ***** coming out, but if hit the brackett from underneath with a hammer towards the drivers side the pump just drops out. easy
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yes defo do both. Sai you can do it and leave the pump in situ i have until i get around to removing it. Also what state is the pcv system in as thats prone to leaking.
    chaz20vt's Avatar
    Aug 2012
    425
    Thanks for the advice ill get the SAI removed and the PVC system deleted I think
    Oct 2011
    760
    sorry mate not deleted i meant simplified (pcv)
    chaz20vt's Avatar
    Aug 2012
    425
    Ok what do you mean simplified
    Oct 2011
    760
    chaz20vt's Avatar
    Aug 2012
    425
    ok ill take a look thanks again appreciate every ones help
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    what grade fuel do you use chaz?
    Alex S3 AMK
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by Alex C View Post
    yeah its an APY.
    i dont see a problem with that tbh.
    its just requesting alot early, which its never going to make. 1bar by 2000 rpm? turbo's only just spinning then lol.
    then after that its meeting it.
    the problem is after 3k boost request is poo, requesting 0.7bar at 5k, 6k, my standard map makes more than that lol.
    you sure its an mtm map? its a bloody bad one if its request is so low.
    i think that explains the low maf readings for sure.
    as for timing pull, that amount of timing pull will make the car feel flat, aswell as the drop in boost.
    to the owner: how much oil does it use? any found in the boost pipes, the intercoolers, and throttle body?
    p.s. log lambda values
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    i was guessing that the map went into some sort of protection mode seeing high engine pulls and cut the boost request
    Alex S3 AMK
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    it should log a 'boost limit exceeded' type code and boost request for the map would still be what the map wants. actual would just be actuator pressure, if that was the case. actual would be about 0.35-4bar then.
    il leave the rest up to tuffty and other more experienced people. but i think the problem is ze map.
    edit: should have read you post more clearly, high engine pulls, not high boost. i think the car will just pull and pull it back, not affecting boost.
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    Chaz - Do you have the paper work for the map telling you who mapped it?
    Alex S3 AMK
    chaz20vt's Avatar
    Aug 2012
    425
    Re: 3rd Gear logs for Chaz20vt - Limp Mode
    Sorry iv been working and only just got a break I only use normal unleaded fuel In the car and have done since iv owned it for a month now
    Iv searched through all of the receipts and I don't actually have paper work for a remap so its only what the guy who sold me it has said that its a stage 1 mtm map
    When I changed a couple of boost pipes and cleaned the throttle body there was a bit of oil in there but I though as I don't have a catch can that was normal
  28. #27
    chaz20vt's Avatar
    Aug 2012
    425
    This is a dyno grapth which is in the paper work I got
  29. #28
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    you should use high octane fuel especially when mapped. If you look at the fuel filler cap i think the label says high octane? I use Tesco Momentum 99. Some times if i'm feeling flush i'll fill with Shell V-power
    Alex S3 AMK
  30. #29
    chaz20vt's Avatar
    Aug 2012
    425
    So is it the fuel that I'm using making it not run right
  31. #30
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    no, don't think so, but it wont help it either
    Alex S3 AMK
  32. #31
    chaz20vt's Avatar
    Aug 2012
    425
    Ok ill start using better fuel
    Any ideas what's happening with it then Alex
  33. #32
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    not sure tbh mate. Fueling looks lean during full load with lambda ~>0.88
    I think its supposed to be around 0.85 on boost?
    Alex S3 AMK
  34. #33
    Apr 2012
    605
    when your down next i live in redruth log mine and compare mine to chaz's mine stage 1 by r-tech got a print out of 265bhp without forge tip on it holds boost better now as well..
  35. #34
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    Quote Originally Posted by dancupra225 View Post
    yeah sure, i never really plan to go that way but sometimes just go for a blast down there. Let me know when ever is good for you. I work during the week.
    Alex S3 AMK
  36. #35
    Oct 2011
    760
    Hi mate
    i forgot to add, a few weeks ago i was changing the old pipes from the n75 valve.
    when i plugged it all back in, the car would boost crazily and car would take off and then hit limp mode.
    The cause was the n75 plumped in the wrong way.
    it gave a torque limit exceeded fault code.
    the small feed from the charge pipe to the n75 was actually plumped into my tip.
    Once changed back to the correct way it was all good.
    needless to say i will be experimenting once the rods are uprated
  37. #36
    chaz20vt's Avatar
    Aug 2012
    425
    Ok so do you think its my lamba I noticed today when I looked under my car iv got a decat pipe and the 2nd lamba is not there at all just a empty hole
    I just want the car to run right now im abit scared to drive it
  38. #37
    chaz20vt's Avatar
    Aug 2012
    425
    Any one shed any more light on this
  39. #38
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thats fine mate, apy's only have one lambda sensor and thats just after the turbo, amk/bams have one just after the cat and with yours been an apy your fine.
  40. #39
    chaz20vt's Avatar
    Aug 2012
    425
    So it just being a whole there is fine yea
  41. #40
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What, its literally a hole in the exhaust? if so, no its not lol, you should have a bung for it to blank it off.
  1. First 3rd gear logs, don't look right.
    By jitvv in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2012, 14:24
  2. 3rd gear log (readable this time) lol
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 17:05
  3. 3rd gear log.
    Last Post: 9th March 2012, 14:58
  4. 3rd gear logs
    By millermk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2012, 10:45
  5. Crunching gears with limp mode!!
    By fasttdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2009, 09:56
