I've just been out logging a mapped (think MTM) for chaz20vt
As far as i am aware it is a stage 1 map with a FMIC and a DV (full recirc)
The complaint was that the car was accelerating and then felt flat/limp. The logs below show the requested boost dropping back after ~3500rpm correlating with timing pull that starts on cylinder #2 (8.3!) and then all 4 cylinders are being pulled
What is likely to be causing these issues for him? What else should be logged?
There was one fault code on the car:
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
Thanks in advance for help/advice
1st Log
re-log
1st Log
Code:
[TABLE="width: 715"]
[TR]
[TD]Group A:[/TD]
[TD]'003[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group B:[/TD]
[TD]'115[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group C:[/TD]
[TD]'031[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Engine
Speed[/TD]
[TD]Mass
Air
Flow[/TD]
[TD]Throttle
Valve
Angle[/TD]
[TD]Ignition[/TD]
[TD][/TD]
[TD]Engine
Speed[/TD]
[TD]Engine
Load[/TD]
[TD]Boost
Pressure[/TD]
[TD]Boost
Pressure[/TD]
[TD][/TD]
[TD]Lambda
Control[/TD]
[/TR]
[TR]
[TD]TIME[/TD]
[TD](G28)[/TD]
[TD]Sensor (G70)[/TD]
[TD][/TD]
[TD]Timing
Angle[/TD]
[TD]TIME[/TD]
[TD](G28)[/TD]
[TD][/TD]
[TD](specified)[/TD]
[TD](actual)[/TD]
[TD]TIME[/TD]
[TD]Bank 1
(actual)[/TD]
[/TR]
[TR]
[TD]STAMP[/TD]
[TD] /min[/TD]
[TD] g/s[/TD]
[TD] %[/TD]
[TD] °BTDC[/TD]
[TD]STAMP[/TD]
[TD] /min[/TD]
[TD] %[/TD]
[TD] mbar[/TD]
[TD] mbar[/TD]
[TD]STAMP[/TD]
[TD] V[/TD]
[/TR]
[TR]
[TD="align: right"]0.3[/TD]
[TD="align: right"]840[/TD]
[TD="align: right"]2.97[/TD]
[TD="align: right"]1.6[/TD]
[TD="align: right"]5.3[/TD]
[TD="align: right"]0.6[/TD]
[TD="align: right"]19.5[/TD]
[TD="align: right"]990[/TD]
[TD="align: right"]1010[/TD]
[TD="align: right"]0[/TD]
[TD="align: right"]0.21[/TD]
[/TR]
[TR]
[TD="align: right"]1.2[/TD]
[TD="align: right"]3.06[/TD]
[TD="align: right"]3[/TD]
[TD="align: right"]1.5[/TD]
[TD="align: right"]0.9[/TD]
[TD="align: right"]0.485[/TD]
[/TR]
[TR]
[TD="align: right"]2.1[/TD]
[TD="align: right"]4.5[/TD]
[TD="align: right"]2.4[/TD]
[TD="align: right"]1.8[/TD]
[TD="align: right"]0.685[/TD]
[/TR]
[TR]
[TD="align: right"]3.3[/TD]
[TD="align: right"]2.7[/TD]
[TD="align: right"]0.08[/TD]
[/TR]
[TR]
[TD="align: right"]3.9[/TD]
[TD="align: right"]3.03[/TD]
[TD="align: right"]4.2[/TD]
[TD="align: right"]3.6[/TD]
[TD="align: right"]0.71[/TD]
[/TR]
[TR]
[TD="align: right"]4.8[/TD]
[TD="align: right"]5.1[/TD]
[TD="align: right"]0.09[/TD]
[/TR]
[TR]
[TD="align: right"]5.7[/TD]
[TD="align: right"]6[/TD]
[TD="align: right"]5.4[/TD]
[/TR]
[TR]
[TD="align: right"]6.6[/TD]
[TD="align: right"]6.9[/TD]
[TD="align: right"]6.3[/TD]
[TD="align: right"]0.085[/TD]
[/TR]
[TR]
[TD="align: right"]7.5[/TD]
[TD="align: right"]7.8[/TD]
[TD="align: right"]7.2[/TD]
[TD="align: right"]0.12[/TD]
[/TR]
[TR]
[TD="align: right"]8.39[/TD]
[TD="align: right"]2.94[/TD]
[TD="align: right"]8.69[/TD]
[TD="align: right"]18.8[/TD]
[TD="align: right"]8.1[/TD]
[TD="align: right"]0.705[/TD]
[/TR]
[TR]
[TD="align: right"]9.29[/TD]
[TD="align: right"]9.59[/TD]
[TD="align: right"]8.99[/TD]
[TD="align: right"]0.075[/TD]
[/TR]
[TR]
[TD="align: right"]10.19[/TD]
[TD="align: right"]2.3[/TD]
[TD="align: right"]10.49[/TD]
[TD="align: right"]9.89[/TD]
[TD="align: right"]0.67[/TD]
[/TR]
[TR]
[TD="align: right"]11.09[/TD]
[TD="align: right"]2.86[/TD]
[TD="align: right"]11.39[/TD]
[TD="align: right"]10.79[/TD]
[TD="align: right"]0.675[/TD]
[/TR]
[TR]
[TD="align: right"]11.99[/TD]
[TD="align: right"]12.29[/TD]
[TD="align: right"]11.69[/TD]
[/TR]
[TR]
[TD="align: right"]12.89[/TD]
[TD="align: right"]13.19[/TD]
[TD="align: right"]12.59[/TD]
[TD="align: right"]0.715[/TD]
[/TR]
[TR]
[TD="align: right"]13.79[/TD]
[TD="align: right"]2.83[/TD]
[TD="align: right"]14.09[/TD]
[TD="align: right"]13.49[/TD]
[/TR]
[TR]
[TD="align: right"]14.69[/TD]
[TD="align: right"]2.81[/TD]
[TD="align: right"]14.99[/TD]
[TD="align: right"]18[/TD]
[TD="align: right"]14.39[/TD]
[TD="align: right"]0.1[/TD]
[/TR]
[TR]
[TD="align: right"]15.59[/TD]
[TD="align: right"]2.56[/TD]
[TD="align: right"]10.5[/TD]
[TD="align: right"]15.89[/TD]
[TD="align: right"]15.29[/TD]
[/TR]
[TR]
[TD="align: right"]16.49[/TD]
[TD="align: right"]16.79[/TD]
[TD="align: right"]16.19[/TD]
[TD="align: right"]0.065[/TD]
[/TR]
[TR]
[TD="align: right"]17.39[/TD]
[TD="align: right"]17.69[/TD]
[TD="align: right"]17.09[/TD]
[/TR]
[TR]
[TD="align: right"]18.29[/TD]
[TD="align: right"]3.8[/TD]
[TD="align: right"]18.59[/TD]
[TD="align: right"]17.99[/TD]
[TD="align: right"]0.7[/TD]
[/TR]
[TR]
[TD="align: right"]19.19[/TD]
[TD="align: right"]2.89[/TD]
[TD="align: right"]0.8[/TD]
[TD="align: right"]19.49[/TD]
[TD="align: right"]18.89[/TD]
[/TR]
[TR]
[TD="align: right"]20.09[/TD]
[TD="align: right"]920[/TD]
[TD="align: right"]4.86[/TD]
[TD="align: right"]3.5[/TD]
[TD="align: right"]21[/TD]
[TD="align: right"]20.39[/TD]
[TD="align: right"]1160[/TD]
[TD="align: right"]26.3[/TD]
[TD="align: right"]19.79[/TD]
[/TR]
[TR]
[TD="align: right"]20.99[/TD]
[TD="align: right"]1200[/TD]
[TD="align: right"]3.11[/TD]
[TD="align: right"]2[/TD]
[TD="align: right"]27[/TD]
[TD="align: right"]21.29[/TD]
[TD="align: right"]14.3[/TD]
[TD="align: right"]20.69[/TD]
[TD="align: right"]0.74[/TD]
[/TR]
[TR]
[TD="align: right"]21.89[/TD]
[TD="align: right"]9[/TD]
[TD="align: right"]22.19[/TD]
[TD="align: right"]16.5[/TD]
[TD="align: right"]21.59[/TD]
[TD="align: right"]0.055[/TD]
[/TR]
[TR]
[TD="align: right"]22.79[/TD]
[TD="align: right"]2.92[/TD]
[TD="align: right"]23.09[/TD]
[TD="align: right"]22.49[/TD]
[TD="align: right"]0.06[/TD]
[/TR]
[TR]
[TD="align: right"]23.69[/TD]
[TD="align: right"]23.99[/TD]
[TD="align: right"]23.39[/TD]
[TD="align: right"]0.785[/TD]
[/TR]
[TR]
[TD="align: right"]24.59[/TD]
[TD="align: right"]24.89[/TD]
[TD="align: right"]24.29[/TD]
[/TR]
[TR]
[TD="align: right"]25.49[/TD]
[TD="align: right"]5.5[/TD]
[TD="align: right"]4.3[/TD]
[TD="align: right"]21.8[/TD]
[TD="align: right"]25.79[/TD]
[TD="align: right"]30.1[/TD]
[TD="align: right"]25.19[/TD]
[TD="align: right"]0.095[/TD]
[/TR]
[TR]
[TD="align: right"]26.39[/TD]
[TD="align: right"]1920[/TD]
[TD="align: right"]13.28[/TD]
[TD="align: right"]8.6[/TD]
[TD="align: right"]29.3[/TD]
[TD="align: right"]26.69[/TD]
[TD="align: right"]1840[/TD]
[TD="align: right"]36.8[/TD]
[TD="align: right"]26.09[/TD]
[TD="align: right"]0.81[/TD]
[/TR]
[TR]
[TD="align: right"]27.29[/TD]
[TD="align: right"]1440[/TD]
[TD="align: right"]10.56[/TD]
[TD="align: right"]7.1[/TD]
[TD="align: right"]27.59[/TD]
[TD="align: right"]1280[/TD]
[TD="align: right"]40.6[/TD]
[TD="align: right"]1020[/TD]
[TD="align: right"]26.99[/TD]
[TD="align: right"]0.69[/TD]
[/TR]
[TR]
[TD="align: right"]28.18[/TD]
[TD="align: right"]1000[/TD]
[TD="align: right"]24[/TD]
[TD="align: right"]28.48[/TD]
[TD="align: right"]42.9[/TD]
[TD="align: right"]27.88[/TD]
[TD="align: right"]0.75[/TD]
[/TR]
[TR]
[TD="align: right"]29.08[/TD]
[TD="align: right"]11.72[/TD]
[TD="align: right"]8.2[/TD]
[TD="align: right"]25.5[/TD]
[TD="align: right"]29.38[/TD]
[TD="align: right"]1560[/TD]
[TD="align: right"]28.78[/TD]
[/TR]
[TR]
[TD="align: right"]29.98[/TD]
[TD="align: right"]1880[/TD]
[TD="align: right"]10.6[/TD]
[TD="align: right"]27.8[/TD]
[TD="align: right"]30.28[/TD]
[TD="align: right"]2040[/TD]
[TD="align: right"]46.6[/TD]
[TD="align: right"]1030[/TD]
[TD="align: right"]29.68[/TD]
[TD="align: right"]0.125[/TD]
[/TR]
[TR]
[TD="align: right"]30.88[/TD]
[TD="align: right"]2400[/TD]
[TD="align: right"]23.61[/TD]
[TD="align: right"]14.5[/TD]
[TD="align: right"]31.18[/TD]
[TD="align: right"]2600[/TD]
[TD="align: right"]52.6[/TD]
[TD="align: right"]1060[/TD]
[TD="align: right"]30.58[/TD]
[TD="align: right"]0.695[/TD]
[/TR]
[TR]
[TD="align: right"]31.78[/TD]
[TD="align: right"]3000[/TD]
[TD="align: right"]31.86[/TD]
[TD="align: right"]17.6[/TD]
[TD="align: right"]32.08[/TD]
[TD="align: right"]2960[/TD]
[TD="align: right"]31.48[/TD]
[/TR]
[TR]
[TD="align: right"]32.68[/TD]
[TD="align: right"]2360[/TD]
[TD="align: right"]4.44[/TD]
[TD="align: right"]9.8[/TD]
[TD="align: right"]32.98[/TD]
[TD="align: right"]2120[/TD]
[TD="align: right"]1050[/TD]
[TD="align: right"]32.38[/TD]
[TD="align: right"]0.04[/TD]
[/TR]
[TR]
[TD="align: right"]33.58[/TD]
[TD="align: right"]1400[/TD]
[TD="align: right"]11.28[/TD]
[TD="align: right"]24.8[/TD]
[TD="align: right"]33.88[/TD]
[TD="align: right"]1320[/TD]
[TD="align: right"]33.28[/TD]
[/TR]
[TR]
[TD="align: right"]34.48[/TD]
[TD="align: right"]65.5[/TD]
[TD="align: right"]34.78[/TD]
[TD="align: right"]1520[/TD]
[TD="align: right"]80.5[/TD]
[TD="align: right"]34.18[/TD]
[TD="align: right"]0.835[/TD]
[/TR]
[TR]
[TD="align: right"]35.38[/TD]
[TD="align: right"]1680[/TD]
[TD="align: right"]28.56[/TD]
[TD="align: right"]76.5[/TD]
[TD="align: right"]12.8[/TD]
[TD="align: right"]35.68[/TD]
[TD="align: right"]1760[/TD]
[TD="align: right"]91.7[/TD]
[TD="align: right"]1720[/TD]
[TD="align: right"]1150[/TD]
[TD="align: right"]35.08[/TD]
[/TR]
[TR]
[TD="align: right"]36.28[/TD]
[TD="align: right"]38.53[/TD]
[TD="align: right"]84.7[/TD]
[TD="align: right"]12[/TD]
[TD="align: right"]36.58[/TD]
[TD="align: right"]2000[/TD]
[TD="align: right"]107.5[/TD]
[TD="align: right"]1900[/TD]
[TD="align: right"]1250[/TD]
[TD="align: right"]35.98[/TD]
[TD="align: right"]0.79[/TD]
[/TR]
[TR]
[TD="align: right"]37.18[/TD]
[TD="align: right"]2200[/TD]
[TD="align: right"]50.36[/TD]
[TD="align: right"]90.6[/TD]
[TD="align: right"]11.3[/TD]
[TD="align: right"]37.48[/TD]
[TD="align: right"]2280[/TD]
[TD="align: right"]124.1[/TD]
[TD="align: right"]2100[/TD]
[TD="align: right"]1410[/TD]
[TD="align: right"]36.88[/TD]
[TD="align: right"]0.825[/TD]
[/TR]
[TR]
[TD="align: right"]38.08[/TD]
[TD="align: right"]2520[/TD]
[TD="align: right"]67.36[/TD]
[TD="align: right"]96.9[/TD]
[TD="align: right"]38.38[/TD]
[TD="align: right"]2640[/TD]
[TD="align: right"]142.9[/TD]
[TD="align: right"]2270[/TD]
[TD="align: right"]1640[/TD]
[TD="align: right"]37.78[/TD]
[TD="align: right"]0.82[/TD]
[/TR]
[TR]
[TD="align: right"]38.98[/TD]
[TD="align: right"]2880[/TD]
[TD="align: right"]97.06[/TD]
[TD="align: right"]99.2[/TD]
[TD="align: right"]8.3[/TD]
[TD="align: right"]39.28[/TD]
[TD="align: right"]3040[/TD]
[TD="align: right"]180.5[/TD]
[TD="align: right"]2370[/TD]
[TD="align: right"]2010[/TD]
[TD="align: right"]38.68[/TD]
[TD="align: right"]0.83[/TD]
[/TR]
[TR]
[TD="align: right"]39.88[/TD]
[TD="align: right"]3400[/TD]
[TD="align: right"]136.31[/TD]
[TD="align: right"]100[/TD]
[TD="align: right"]40.18[/TD]
[TD="align: right"]3560[/TD]
[TD="align: right"]191.7[/TD]
[TD="align: right"]2340[/TD]
[TD="align: right"]2450[/TD]
[TD="align: right"]39.58[/TD]
[TD="align: right"]0.855[/TD]
[/TR]
[TR]
[TD="align: right"]40.79[/TD]
[TD="align: right"]3920[/TD]
[TD="align: right"]154.67[/TD]
[TD="align: right"]66.3[/TD]
[TD="align: right"]41.08[/TD]
[TD="align: right"]4080[/TD]
[TD="align: right"]158.6[/TD]
[TD="align: right"]1890[/TD]
[TD="align: right"]2190[/TD]
[TD="align: right"]40.48[/TD]
[TD="align: right"]0.865[/TD]
[/TR]
[TR]
[TD="align: right"]41.69[/TD]
[TD="align: right"]4320[/TD]
[TD="align: right"]126.42[/TD]
[TD="align: right"]41.99[/TD]
[TD="align: right"]4480[/TD]
[TD="align: right"]156.4[/TD]
[TD="align: right"]1820[/TD]
[TD="align: right"]1770[/TD]
[TD="align: right"]41.39[/TD]
[TD="align: right"]0.86[/TD]
[/TR]
[TR]
[TD="align: right"]42.59[/TD]
[TD="align: right"]4680[/TD]
[TD="align: right"]135.03[/TD]
[TD="align: right"]42.89[/TD]
[TD="align: right"]4800[/TD]
[TD="align: right"]146.6[/TD]
[TD="align: right"]1750[/TD]
[TD="align: right"]1730[/TD]
[TD="align: right"]42.29[/TD]
[TD="align: right"]0.87[/TD]
[/TR]
[TR]
[TD="align: right"]43.49[/TD]
[TD="align: right"]5040[/TD]
[TD="align: right"]136.5[/TD]
[TD="align: right"]43.79[/TD]
[TD="align: right"]5160[/TD]
[TD="align: right"]144.4[/TD]
[TD="align: right"]1700[/TD]
[TD="align: right"]43.19[/TD]
[/TR]
[TR]
[TD="align: right"]44.39[/TD]
[TD="align: right"]5360[/TD]
[TD="align: right"]145.56[/TD]
[TD="align: right"]13.5[/TD]
[TD="align: right"]44.69[/TD]
[TD="align: right"]5440[/TD]
[TD="align: right"]143.6[/TD]
[TD="align: right"]1690[/TD]
[TD="align: right"]44.09[/TD]
[/TR]
[TR]
[TD="align: right"]45.29[/TD]
[TD="align: right"]5640[/TD]
[TD="align: right"]156.58[/TD]
[TD="align: right"]15.8[/TD]
[TD="align: right"]45.59[/TD]
[TD="align: right"]5760[/TD]
[TD="align: right"]141.4[/TD]
[TD="align: right"]1710[/TD]
[TD="align: right"]44.99[/TD]
[TD="align: right"]0.88[/TD]
[/TR]
[TR]
[TD="align: right"]46.19[/TD]
[TD="align: right"]5960[/TD]
[TD="align: right"]165.08[/TD]
[TD="align: right"]15[/TD]
[TD="align: right"]46.49[/TD]
[TD="align: right"]5840[/TD]
[TD="align: right"]63.9[/TD]
[TD="align: right"]1950[/TD]
[TD="align: right"]45.89[/TD]
[TD="align: right"]0.885[/TD]
[/TR]
[TR]
[TD="align: right"]47.09[/TD]
[TD="align: right"]4840[/TD]
[TD="align: right"]6.67[/TD]
[TD="align: right"]47.38[/TD]
[TD="align: right"]1120[/TD]
[TD="align: right"]46.79[/TD]
[TD="align: right"]0.66[/TD]
[/TR]
[TR]
[TD="align: right"]47.98[/TD]
[TD="align: right"]24.78[/TD]
[TD="align: right"]14.1[/TD]
[TD="align: right"]35.3[/TD]
[TD="align: right"]48.28[/TD]
[TD="align: right"]1080[/TD]
[TD="align: right"]47.68[/TD]
[/TR]
[TR]
[TD="align: right"]48.88[/TD]
[TD="align: right"]4440[/TD]
[TD="align: right"]16.36[/TD]
[TD="align: right"]49.18[/TD]
[TD="align: right"]1070[/TD]
[TD="align: right"]48.58[/TD]
[/TR]
[/TABLE]
re-log
Code:
[TR]
[TD]Group A:[/TD]
[TD]'003[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group B:[/TD]
[TD]'115[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group C:[/TD]
[TD]'031[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Engine
Speed[/TD]
[TD]Mass
Air
Flow[/TD]
[TD]Throttle
Valve
Angle[/TD]
[TD]Ignition[/TD]
[TD][/TD]
[TD]Engine
Speed[/TD]
[TD]Engine
Load[/TD]
[TD]Boost
Pressure[/TD]
[TD]Boost
Pressure[/TD]
[TD][/TD]
[TD]Lambda
Control[/TD]
[/TR]
[TR]
[TD]TIME[/TD]
[TD](G28)[/TD]
[TD][/TD]
[TD]Timing
Angle[/TD]
[TD]TIME[/TD]
[TD](G28)[/TD]
[TD][/TD]
[TD](actual)[/TD]
[TD]TIME[/TD]
[TD]Bank 1
(actual)[/TD]
[/TR]
[TR]
[TD]STAMP[/TD]
[TD] /min[/TD]
[TD] g/s[/TD]
[TD] %[/TD]
[TD] °BTDC[/TD]
[TD]STAMP[/TD]
[TD] /min[/TD]
[TD] %[/TD]
[TD] mbar[/TD]
[TD] mbar[/TD]
[TD]STAMP[/TD]
[TD] V[/TD]
[/TR]
[TR]
[TD="align: right"]3.58[/TD]
[/TR]
[TR]
[TD="align: right"]3.69[/TD]
[TD="align: right"]22.6[/TD]
[/TR]
[TR]
[TD="align: right"]1.83[/TD]
[TD="align: right"]-2.3[/TD]
[TD="align: right"]2.2[/TD]
[TD="align: right"]2.5[/TD]
[TD="align: right"]0.145[/TD]
[/TR]
[TR]
[TD="align: right"]2.8[/TD]
[TD="align: right"]3.1[/TD]
[TD="align: right"]880[/TD]
[TD="align: right"]3.4[/TD]
[TD="align: right"]0.665[/TD]
[/TR]
[TR]
[TD="align: right"]3.7[/TD]
[TD="align: right"]4.03[/TD]
[TD="align: right"]4[/TD]
[TD="align: right"]960[/TD]
[TD="align: right"]23.3[/TD]
[/TR]
[TR]
[TD="align: right"]4.6[/TD]
[TD="align: right"]9.81[/TD]
[TD="align: right"]4.9[/TD]
[TD="align: right"]1040[/TD]
[TD="align: right"]48.1[/TD]
[TD="align: right"]5.2[/TD]
[TD="align: right"]0.755[/TD]
[/TR]
[TR]
[TD="align: right"]10.28[/TD]
[TD="align: right"]5.8[/TD]
[TD="align: right"]49.6[/TD]
[TD="align: right"]6.1[/TD]
[/TR]
[TR]
[TD="align: right"]6.4[/TD]
[TD="align: right"]1360[/TD]
[TD="align: right"]11.5[/TD]
[TD="align: right"]6.69[/TD]
[TD="align: right"]44.4[/TD]
[TD="align: right"]6.99[/TD]
[/TR]
[TR]
[TD="align: right"]7.29[/TD]
[TD="align: right"]23.44[/TD]
[TD="align: right"]18.4[/TD]
[TD="align: right"]7.59[/TD]
[TD="align: right"]2160[/TD]
[TD="align: right"]67.7[/TD]
[TD="align: right"]7.89[/TD]
[TD="align: right"]0.745[/TD]
[/TR]
[TR]
[TD="align: right"]8.19[/TD]
[TD="align: right"]2720[/TD]
[TD="align: right"]40.06[/TD]
[TD="align: right"]8.49[/TD]
[TD="align: right"]2920[/TD]
[TD="align: right"]54.1[/TD]
[TD="align: right"]8.79[/TD]
[/TR]
[TR]
[TD="align: right"]9.09[/TD]
[TD="align: right"]4.19[/TD]
[TD="align: right"]9.39[/TD]
[TD="align: right"]2080[/TD]
[TD="align: right"]9.69[/TD]
[TD="align: right"]0.035[/TD]
[/TR]
[TR]
[TD="align: right"]9.99[/TD]
[TD="align: right"]1240[/TD]
[TD="align: right"]17.5[/TD]
[TD="align: right"]10.29[/TD]
[TD="align: right"]1480[/TD]
[TD="align: right"]71.4[/TD]
[TD="align: right"]1350[/TD]
[TD="align: right"]10.59[/TD]
[/TR]
[TR]
[TD="align: right"]10.89[/TD]
[TD="align: right"]25.39[/TD]
[TD="align: right"]71[/TD]
[TD="align: right"]11.19[/TD]
[TD="align: right"]1600[/TD]
[TD="align: right"]87.2[/TD]
[TD="align: right"]1110[/TD]
[TD="align: right"]11.49[/TD]
[TD="align: right"]0.72[/TD]
[/TR]
[TR]
[TD="align: right"]11.79[/TD]
[TD="align: right"]1800[/TD]
[TD="align: right"]32.83[/TD]
[TD="align: right"]80.4[/TD]
[TD="align: right"]12.09[/TD]
[TD="align: right"]96.2[/TD]
[TD="align: right"]1190[/TD]
[TD="align: right"]12.39[/TD]
[/TR]
[TR]
[TD="align: right"]12.69[/TD]
[TD="align: right"]43.25[/TD]
[TD="align: right"]88.6[/TD]
[TD="align: right"]12.99[/TD]
[TD="align: right"]112.8[/TD]
[TD="align: right"]1310[/TD]
[TD="align: right"]13.29[/TD]
[/TR]
[TR]
[TD="align: right"]13.59[/TD]
[TD="align: right"]57.94[/TD]
[TD="align: right"]94.1[/TD]
[TD="align: right"]13.89[/TD]
[TD="align: right"]2480[/TD]
[TD="align: right"]129.3[/TD]
[TD="align: right"]2220[/TD]
[TD="align: right"]1490[/TD]
[TD="align: right"]14.19[/TD]
[/TR]
[TR]
[TD="align: right"]14.49[/TD]
[TD="align: right"]77.81[/TD]
[TD="align: right"]98.4[/TD]
[TD="align: right"]14.79[/TD]
[TD="align: right"]2840[/TD]
[TD="align: right"]154.9[/TD]
[TD="align: right"]2350[/TD]
[TD="align: right"]15.09[/TD]
[/TR]
[TR]
[TD="align: right"]15.39[/TD]
[TD="align: right"]3120[/TD]
[TD="align: right"]117.81[/TD]
[TD="align: right"]15.69[/TD]
[TD="align: right"]3280[/TD]
[TD="align: right"]2290[/TD]
[TD="align: right"]15.99[/TD]
[/TR]
[TR]
[TD="align: right"]16.29[/TD]
[TD="align: right"]3680[/TD]
[TD="align: right"]156.97[/TD]
[TD="align: right"]6.8[/TD]
[TD="align: right"]16.59[/TD]
[TD="align: right"]3840[/TD]
[TD="align: right"]16.9[/TD]
[/TR]
[TR]
[TD="align: right"]17.2[/TD]
[TD="align: right"]4200[/TD]
[TD="align: right"]124.17[/TD]
[TD="align: right"]40.4[/TD]
[TD="align: right"]1870[/TD]
[TD="align: right"]1960[/TD]
[TD="align: right"]17.8[/TD]
[/TR]
[TR]
[TD="align: right"]18.1[/TD]
[TD="align: right"]4560[/TD]
[TD="align: right"]134.92[/TD]
[TD="align: right"]153.4[/TD]
[TD="align: right"]1810[/TD]
[TD="align: right"]1790[/TD]
[TD="align: right"]18.7[/TD]
[TD="align: right"]0.875[/TD]
[/TR]
[TR]
[TD="align: right"]19[/TD]
[TD="align: right"]4880[/TD]
[TD="align: right"]137.31[/TD]
[TD="align: right"]19.3[/TD]
[TD="align: right"]5000[/TD]
[TD="align: right"]145.1[/TD]
[TD="align: right"]1740[/TD]
[TD="align: right"]19.6[/TD]
[/TR]
[TR]
[TD="align: right"]19.9[/TD]
[TD="align: right"]5240[/TD]
[TD="align: right"]152.44[/TD]
[TD="align: right"]20.2[/TD]
[TD="align: right"]152.6[/TD]
[TD="align: right"]20.5[/TD]
[/TR]
[TR]
[TD="align: right"]20.8[/TD]
[TD="align: right"]5560[/TD]
[TD="align: right"]160.47[/TD]
[TD="align: right"]21.1[/TD]
[TD="align: right"]5680[/TD]
[TD="align: right"]148.9[/TD]
[TD="align: right"]1780[/TD]
[TD="align: right"]21.4[/TD]
[/TR]
[TR]
[TD="align: right"]21.7[/TD]
[TD="align: right"]5880[/TD]
[TD="align: right"]162.56[/TD]
[TD="align: right"]22[/TD]
[TD="align: right"]6000[/TD]
[TD="align: right"]22.3[/TD]
[TD="align: right"]0.89[/TD]
[/TR]
[TR]
[TD="align: right"]6200[/TD]
[TD="align: right"]171.53[/TD]
[TD="align: right"]98.8[/TD]
[TD="align: right"]22.9[/TD]
[TD="align: right"]6280[/TD]
[TD="align: right"]1620[/TD]
[TD="align: right"]23.2[/TD]
[/TR]
[TR]
[TD="align: right"]23.5[/TD]
[TD="align: right"]6440[/TD]
[TD="align: right"]163.03[/TD]
[TD="align: right"]17.3[/TD]
[TD="align: right"]23.8[/TD]
[TD="align: right"]6520[/TD]
[TD="align: right"]1610[/TD]
[TD="align: right"]24.1[/TD]
[TD="align: right"]0.895[/TD]
[/TR]
[TR]
[TD="align: right"]24.4[/TD]
[TD="align: right"]6640[/TD]
[TD="align: right"]157.92[/TD]
[TD="align: right"]54.9[/TD]
[TD="align: right"]24.7[/TD]
[TD="align: right"]6720[/TD]
[TD="align: right"]130.8[/TD]
[TD="align: right"]25[/TD]
[TD="align: right"]0.91[/TD]
[/TR]
[TR]
[TD="align: right"]25.3[/TD]
[TD="align: right"]6840[/TD]
[TD="align: right"]157.69[/TD]
[TD="align: right"]25.6[/TD]
[TD="align: right"]6920[/TD]
[TD="align: right"]130.1[/TD]
[TD="align: right"]25.9[/TD]
[/TR]
[TR]
[TD="align: right"]26.2[/TD]
[TD="align: right"]6080[/TD]
[TD="align: right"]9.47[/TD]
[TD="align: right"]26.49[/TD]
[TD="align: right"]5520[/TD]
[TD="align: right"]1180[/TD]
[TD="align: right"]26.79[/TD]
[TD="align: right"]0.795[/TD]
[/TR]
[TR]
[TD="align: right"]27.09[/TD]
[TD="align: right"]5.28[/TD]
[TD="align: right"]27.38[/TD]
[TD="align: right"]27.68[/TD]
[TD="align: right"]0.01[/TD]
[/TR]
[TR]
[TD="align: right"]27.99[/TD]
[TD="align: right"]7.53[/TD]
[TD="align: right"]28.29[/TD]
[TD="align: right"]4920[/TD]
[TD="align: right"]28.58[/TD]
[TD="align: right"]0.005[/TD]
[/TR]
[TR]
[TD="align: right"]28.89[/TD]
[TD="align: right"]8.28[/TD]
[TD="align: right"]29.19[/TD]
[TD="align: right"]4720[/TD]
[TD="align: right"]29.48[/TD]
[/TR]
[TR]
[TD="align: right"]29.8[/TD]
[TD="align: right"]7.81[/TD]
[TD="align: right"]4.7[/TD]
[TD="align: right"]30.08[/TD]
[TD="align: right"]3640[/TD]
[TD="align: right"]30.39[/TD]
[/TR]
[TR]
[TD="align: right"]30.68[/TD]
[TD="align: right"]2800[/TD]
[TD="align: right"]4.89[/TD]
[TD="align: right"]30.98[/TD]
[TD="align: right"]31.28[/TD]
[/TR]
[TR]
[TD="align: right"]31.58[/TD]
[TD="align: right"]2560[/TD]
[TD="align: right"]31.88[/TD]
[TD="align: right"]32.18[/TD]
[/TR]
[TR]
[TD="align: right"]32.48[/TD]
[TD="align: right"]5.22[/TD]
[TD="align: right"]32.78[/TD]
[TD="align: right"]33.08[/TD]
[/TR]
[TR]
[TD="align: right"]33.38[/TD]
[TD="align: right"]5.06[/TD]
[TD="align: right"]33.68[/TD]
[TD="align: right"]33.98[/TD]
[/TR]
[TR]
[TD="align: right"]34.28[/TD]
[TD="align: right"]2440[/TD]
[TD="align: right"]4.81[/TD]
[TD="align: right"]34.58[/TD]
[TD="align: right"]34.88[/TD]
[/TR]
[TR]
[TD="align: right"]35.18[/TD]
[TD="align: right"]2320[/TD]
[TD="align: right"]35.48[/TD]
[TD="align: right"]35.78[/TD]
[/TR]
[TR]
[TD="align: right"]36.08[/TD]
[TD="align: right"]36.38[/TD]
[TD="align: right"]36.69[/TD]
[/TR]
[TR]
[TD="align: right"]36.98[/TD]
[TD="align: right"]4.33[/TD]
[TD="align: right"]37.28[/TD]
[TD="align: right"]37.58[/TD]
[/TR]
[TR]
[TD="align: right"]37.88[/TD]
[TD="align: right"]4.28[/TD]
[TD="align: right"]38.18[/TD]
[TD="align: right"]38.48[/TD]
[/TR]
[TR]
[TD="align: right"]38.78[/TD]
[TD="align: right"]39.08[/TD]
[TD="align: right"]39.38[/TD]
[/TR]
[TR]
[TD="align: right"]39.68[/TD]
[TD="align: right"]3.92[/TD]
[TD="align: right"]39.98[/TD]
[TD="align: right"]40.28[/TD]
[/TR]
[TR]
[TD="align: right"]40.58[/TD]
[TD="align: right"]3.36[/TD]
[TD="align: right"]-3.8[/TD]
[TD="align: right"]40.88[/TD]
[TD="align: right"]41.18[/TD]
[/TR]
[TR]
[TD="align: right"]41.48[/TD]
[TD="align: right"]-6[/TD]
[TD="align: right"]41.78[/TD]
[TD="align: right"]42.08[/TD]
[/TR]
[TR]
[TD="align: right"]42.38[/TD]
[TD="align: right"]42.68[/TD]
[TD="align: right"]42.98[/TD]
[/TR]
[TR]
[TD="align: right"]43.28[/TD]
[TD="align: right"]680[/TD]
[TD="align: right"]3.81[/TD]
[TD="align: right"]20.3[/TD]
[TD="align: right"]43.58[/TD]
[TD="align: right"]760[/TD]
[TD="align: right"]43.88[/TD]
[TD="align: right"]0.78[/TD]
[/TR]
[TR]
[TD="align: right"]44.18[/TD]
[TD="align: right"]44.48[/TD]
[TD="align: right"]44.78[/TD]
[TD="align: right"]0.07[/TD]
[/TR]
[TR]
[TD="align: right"]45.08[/TD]
[TD="align: right"]3.42[/TD]
[TD="align: right"]45.38[/TD]
[TD="align: right"]45.68[/TD]
[TD="align: right"]0.11[/TD]
[/TR]
[TR]
[TD="align: right"]45.97[/TD]
[TD="align: right"]3.89[/TD]
[TD="align: right"]46.27[/TD]
[TD="align: right"]46.57[/TD]
[/TR]
[TR]
[TD="align: right"]46.87[/TD]
[TD="align: right"]3.56[/TD]
[TD="align: right"]47.17[/TD]
[TD="align: right"]47.48[/TD]
[TD="align: right"]0.63[/TD]
[/TR]
[/TABLE]
Code:
[TABLE="width: 766"]
[TR]
[TD]Group A:[/TD]
[TD]'003[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group B:[/TD]
[TD]'020[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]Group C:[/TD]
[TD]'031[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Engine
Speed[/TD]
[TD]Mass
Air
Flow[/TD]
[TD]Throttle
Valve
Angle[/TD]
[TD]Ignition[/TD]
[TD][/TD]
[TD]Timing
Retardation[/TD]
[TD]Timing
Retardation[/TD]
[TD]Timing
Retardation[/TD]
[TD]Timing
Retardation[/TD]
[TD][/TD]
[TD]Lambda
Control[/TD]
[/TR]
[TR]
[TD]TIME[/TD]
[TD](G28)[/TD]
[TD]Sensor
(G70)[/TD]
[TD][/TD]
[TD]Timing
Angle[/TD]
[TD]TIME[/TD]
[TD]Cylinder 1[/TD]
[TD]Cylinder 2[/TD]
[TD]Cylinder 3[/TD]
[TD]Cylinder 4[/TD]
[TD]TIME[/TD]
[TD]Bank 1
(actual)[/TD]
[/TR]
[TR]
[TD]STAMP[/TD]
[TD] /min[/TD]
[TD] g/s[/TD]
[TD] %[/TD]
[TD] °BTDC[/TD]
[TD]STAMP[/TD]
[TD]°KW[/TD]
[TD]°KW[/TD]
[TD]°KW[/TD]
[TD]°KW[/TD]
[TD]STAMP[/TD]
[TD] V[/TD]
[/TR]
[TR]
[TD="align: right"]0.85[/TD]
[TD="align: right"]3.67[/TD]
[TD="align: right"]-4.5[/TD]
[TD="align: right"]0.25[/TD]
[TD="align: right"]0.55[/TD]
[TD="align: right"]0.13[/TD]
[/TR]
[TR]
[TD="align: right"]1.78[/TD]
[TD="align: right"]9.08[/TD]
[TD="align: right"]1.15[/TD]
[TD="align: right"]1.45[/TD]
[/TR]
[TR]
[TD="align: right"]2.75[/TD]
[TD="align: right"]10.67[/TD]
[TD="align: right"]2.15[/TD]
[TD="align: right"]2.46[/TD]
[TD="align: right"]0.455[/TD]
[/TR]
[TR]
[TD="align: right"]3.65[/TD]
[TD="align: right"]11.31[/TD]
[TD="align: right"]9.4[/TD]
[TD="align: right"]3.05[/TD]
[TD="align: right"]3.35[/TD]
[/TR]
[TR]
[TD="align: right"]4.55[/TD]
[TD="align: right"]9.94[/TD]
[TD="align: right"]3.95[/TD]
[TD="align: right"]4.25[/TD]
[/TR]
[TR]
[TD="align: right"]5.45[/TD]
[TD="align: right"]14.89[/TD]
[TD="align: right"]10.2[/TD]
[TD="align: right"]4.85[/TD]
[TD="align: right"]5.15[/TD]
[TD="align: right"]0.62[/TD]
[/TR]
[TR]
[TD="align: right"]6.35[/TD]
[TD="align: right"]28.42[/TD]
[TD="align: right"]20[/TD]
[TD="align: right"]5.75[/TD]
[TD="align: right"]6.05[/TD]
[TD="align: right"]0.35[/TD]
[/TR]
[TR]
[TD="align: right"]7.25[/TD]
[TD="align: right"]3160[/TD]
[TD="align: right"]53[/TD]
[TD="align: right"]36.5[/TD]
[TD="align: right"]22.5[/TD]
[TD="align: right"]6.65[/TD]
[TD="align: right"]6.95[/TD]
[TD="align: right"]0.105[/TD]
[/TR]
[TR]
[TD="align: right"]8.15[/TD]
[TD="align: right"]3.72[/TD]
[TD="align: right"]7.56[/TD]
[TD="align: right"]7.85[/TD]
[/TR]
[TR]
[TD="align: right"]9.05[/TD]
[TD="align: right"]27.67[/TD]
[TD="align: right"]8.45[/TD]
[TD="align: right"]8.75[/TD]
[/TR]
[TR]
[TD="align: right"]47.25[/TD]
[TD="align: right"]34.5[/TD]
[TD="align: right"]9.34[/TD]
[TD="align: right"]9.64[/TD]
[/TR]
[TR]
[TD="align: right"]10.84[/TD]
[TD="align: right"]3080[/TD]
[TD="align: right"]83.08[/TD]
[TD="align: right"]10.24[/TD]
[TD="align: right"]10.54[/TD]
[/TR]
[TR]
[TD="align: right"]11.75[/TD]
[TD="align: right"]3880[/TD]
[TD="align: right"]72.14[/TD]
[TD="align: right"]24.3[/TD]
[TD="align: right"]11.14[/TD]
[TD="align: right"]11.45[/TD]
[TD="align: right"]0.84[/TD]
[/TR]
[TR]
[TD="align: right"]12.64[/TD]
[TD="align: right"]4.67[/TD]
[TD="align: right"]12.05[/TD]
[TD="align: right"]12.34[/TD]
[/TR]
[TR]
[TD="align: right"]13.54[/TD]
[TD="align: right"]28.72[/TD]
[TD="align: right"]30.8[/TD]
[TD="align: right"]12.94[/TD]
[TD="align: right"]13.24[/TD]
[/TR]
[TR]
[TD="align: right"]14.44[/TD]
[TD="align: right"]61.94[/TD]
[TD="align: right"]13.84[/TD]
[TD="align: right"]14.14[/TD]
[/TR]
[TR]
[TD="align: right"]15.34[/TD]
[TD="align: right"]97.31[/TD]
[TD="align: right"]14.74[/TD]
[TD="align: right"]15.04[/TD]
[TD="align: right"]0.815[/TD]
[/TR]
[TR]
[TD="align: right"]16.24[/TD]
[TD="align: right"]3480[/TD]
[TD="align: right"]136.28[/TD]
[TD="align: right"]15.64[/TD]
[TD="align: right"]15.94[/TD]
[/TR]
[TR]
[TD="align: right"]17.15[/TD]
[TD="align: right"]4040[/TD]
[TD="align: right"]159.56[/TD]
[TD="align: right"]16.54[/TD]
[TD="align: right"]16.84[/TD]
[/TR]
[TR]
[TD="align: right"]18.05[/TD]
[TD="align: right"]162.53[/TD]
[TD="align: right"]17.45[/TD]
[TD="align: right"]17.75[/TD]
[/TR]
[TR]
[TD="align: right"]18.94[/TD]
[TD="align: right"]158.5[/TD]
[TD="align: right"]18.35[/TD]
[TD="align: right"]18.65[/TD]
[/TR]
[TR]
[TD="align: right"]19.84[/TD]
[TD="align: right"]5280[/TD]
[TD="align: right"]166.64[/TD]
[TD="align: right"]19.25[/TD]
[TD="align: right"]19.55[/TD]
[/TR]
[TR]
[TD="align: right"]20.75[/TD]
[TD="align: right"]5600[/TD]
[TD="align: right"]168.78[/TD]
[TD="align: right"]20.15[/TD]
[TD="align: right"]20.45[/TD]
[/TR]
[TR]
[TD="align: right"]21.65[/TD]
[TD="align: right"]5920[/TD]
[TD="align: right"]177.86[/TD]
[TD="align: right"]21.05[/TD]
[TD="align: right"]21.35[/TD]
[/TR]
[TR]
[TD="align: right"]22.55[/TD]
[TD="align: right"]172.89[/TD]
[TD="align: right"]21.95[/TD]
[TD="align: right"]22.25[/TD]
[/TR]
[TR]
[TD="align: right"]23.45[/TD]
[TD="align: right"]51.17[/TD]
[TD="align: right"]22.85[/TD]
[TD="align: right"]23.15[/TD]
[/TR]
[TR]
[TD="align: right"]24.35[/TD]
[TD="align: right"]5120[/TD]
[TD="align: right"]4.94[/TD]
[TD="align: right"]23.75[/TD]
[TD="align: right"]24.05[/TD]
[/TR]
[TR]
[TD="align: right"]25.25[/TD]
[TD="align: right"]6.17[/TD]
[TD="align: right"]24.65[/TD]
[TD="align: right"]24.95[/TD]
[TD="align: right"]0.725[/TD]
[/TR]
[TR]
[TD="align: right"]26.14[/TD]
[TD="align: right"]4600[/TD]
[TD="align: right"]6.92[/TD]
[TD="align: right"]25.55[/TD]
[TD="align: right"]25.84[/TD]
[/TR]
[TR]
[TD="align: right"]27.04[/TD]
[TD="align: right"]8.22[/TD]
[TD="align: right"]26.44[/TD]
[TD="align: right"]26.74[/TD]
[/TR]
[TR]
[TD="align: right"]27.95[/TD]
[TD="align: right"]4360[/TD]
[TD="align: right"]27.34[/TD]
[TD="align: right"]27.65[/TD]
[/TR]
[TR]
[TD="align: right"]28.85[/TD]
[TD="align: right"]4280[/TD]
[TD="align: right"]8.58[/TD]
[TD="align: right"]28.24[/TD]
[TD="align: right"]28.55[/TD]
[/TR]
[TR]
[TD="align: right"]29.74[/TD]
[TD="align: right"]4160[/TD]
[TD="align: right"]8.86[/TD]
[TD="align: right"]5.9[/TD]
[TD="align: right"]29.13[/TD]
[TD="align: right"]29.44[/TD]
[/TR]
[TR]
[TD="align: right"]30.63[/TD]
[TD="align: right"]9.06[/TD]
[TD="align: right"]30.03[/TD]
[TD="align: right"]30.33[/TD]
[/TR]
[TR]
[TD="align: right"]31.53[/TD]
[TD="align: right"]30.93[/TD]
[TD="align: right"]31.23[/TD]
[/TR]
[TR]
[TD="align: right"]32.43[/TD]
[TD="align: right"]3.86[/TD]
[TD="align: right"]31.83[/TD]
[TD="align: right"]32.13[/TD]
[/TR]
[TR]
[TD="align: right"]33.33[/TD]
[TD="align: right"]5.31[/TD]
[TD="align: right"]32.73[/TD]
[TD="align: right"]33.03[/TD]
[/TR]
[TR]
[TD="align: right"]34.23[/TD]
[TD="align: right"]33.63[/TD]
[TD="align: right"]33.93[/TD]
[/TR]
[TR]
[TD="align: right"]35.13[/TD]
[TD="align: right"]5.11[/TD]
[TD="align: right"]34.53[/TD]
[TD="align: right"]34.83[/TD]
[/TR]
[TR]
[TD="align: right"]36.03[/TD]
[TD="align: right"]2240[/TD]
[TD="align: right"]4.97[/TD]
[TD="align: right"]35.43[/TD]
[TD="align: right"]35.73[/TD]
[/TR]
[TR]
[TD="align: right"]36.93[/TD]
[TD="align: right"]36.33[/TD]
[TD="align: right"]36.63[/TD]
[/TR]
[/TABLE]
