Results 1 to 13 of 13
Thread: Next Mods???
    mark_S3's Avatar
    Yorkshire & Humber Events Mod
    Sep 2012
    Wakefield
    494
    Next Mods???
    Hello people...
    I'm new to Audi's and also turbo cars. Right, I have a 2000 S3 which ive had for two months now.
    The previous owner spent 1000's on mods but also keeping her healthy and full Service history.
    The mods that are on it are: Milltek CAT back, Milltek HiFlow CAT, K&N filter and a SuperChips remap which all where done at Demon Tweeks. The brakes where also upgraded to drilled/ grooved, better pads .
    Well more to the point, what other mods can I purchase in regards to performance? Would love to get a FMIC but cant stretch to that price. I mean less that few 100. I know this has been covered 100's of times but things like TIP or N75, etc I'm lost.
    Mark
    Jun 2012
    285
    Badger5 tip is the best in the business, search Badger5 on ebay. Expect to pay £280 ish for 10-18bhp (?). Leave your N75 valve, she's probably fine. Look at changing your Bosch recirculating valve for Forge 007 or 008 for £80-£130.
    mark_S3's Avatar
    Sep 2012
    Wakefield
    494
    Presuming a recirculating valve is similar to dump valve or same as my K&N filter makes a 'swirlling'' noise already on gear change, so don't really want them clashing.
    As with the TIP what benefits will I get and is it the part going from my filter to turbo?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    mark_S3's Avatar
    Sep 2012
    Wakefield
    494
    Cheers tuffty
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,285
    Don't forget your momentum / optimax 99 !
    mark_S3's Avatar
    Sep 2012
    Wakefield
    494
    Always use Vpower but put fuelsave in a few times recently and found no difference in performance or mpg
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,285
    Reallllly.....? I found a nice difference on shell optimax! Most remaps are done to accommodate the car being run on high octane fuel. Also inside your fuel cap Audi recommend running on 97+ octane
    mark_S3's Avatar
    Sep 2012
    Wakefield
    494
    Honest pal. I drive sensible as it keeps engine healthy but do boot it a few times a day. Averaging 29.8mpg and since owning it for past two months I've use Shell Vpower! Full tank a week but other week put fuelsave in as test and found no difference at all, if any better mpg.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Id say either the B5 full induction kit of the welly cooler, the welly cooler can be done for around £250.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Should mention that Shell Optimax no longer exsits... its now V-Power...
    I use Tesco Momentum 99 in mine as thats the only garage on my trip to work and the SHell garage near Bills place is always running out so I have given up trying...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Quote Originally Posted by mark_S3 View Post
    Takes a couple of tanks for the ECU to adapt... if the map you have is quite conservative (don't know anything about the superchips ones) then you may not notice the performance drop but believe me its there... the ECU will pull time timing and adapt timing out over time... this will give less power and make the engine run hotter...
    <tuffty/>
    Oct 2011
    728
    forget the forge recirc valve.
    Try googling mad max diverter valve.
    Yes there good.
  1. Recommend my next mod!
    By Els in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2010, 07:07
  2. Found my next MOD !!!!!
    By madalex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2008, 14:23
  3. Next Mod: Milltek Exhaust or Fuel Pump ?
    By Iggu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2008, 18:00
  4. Next mod for 1.9TDI Quattro
    By QUATTRO_REP in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2006, 22:34
  5. Next Mod for my 1.8 T??
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 15:44
