Monster MotorsportChris Nott
    Oct 2008
    Perth
    14
    Electrical connection on front of inlet manifold.
    Hi,
    I was wondering if anyone could tell me what the electrical connection on the front of the inlet manifold is for? Its just to the left of the dipstick when looking at the front of the engine. Oh its a 2002 BAM.
    The reason I ask is that whan I was carrying out the N249 delete the other day i must have forgot to connect it back up, as it was in the way when taking the metal plate out from underneath the plastic cover. I have noticed that my idle was a bit more stable after I had left it unconnected and put this down to the DV being straigh of the manifold and I had maybe eliminated a vacuum leak.
    However last night i was checking the oil and noticed it was disconnected and plugged it back in. I now have a slightly wobbly idle, and was wondering when this sensor was for.
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    The visible one next to the throttle body is the air temp sensor and the one (which I think you are on about) which is normally hidden under the plastic trim in front of the inlet manifold is the EGT sensor... if unplugged your MPG will be rubbish and you can potentially cause engine damage from bore wash
    <tuffty/>
    Oct 2008
    Perth
    14
    I had noticed my mpg was down but its now back to normal once connected back up.
    Is likely to affect the idle too or could that be a total coincidence?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Unplugging it will make it all run richer... the ECU will have adapted a bit for this... plugging it back in will have throw this adaption out again so I suspect it will settle again once you have driven the car for a little while
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Unless he is on about the N112 valve?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    not on a BAM.
    deffo egt sensor
  1. Perished hose connecting to inlet manifold
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 23:12
  2. polished inlet manifold??
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2007, 19:58
  3. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
  4. Dahlback Racing Inlet Manifold
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2004, 20:14
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
