Sky InsuranceEM Tuning
    Keefy's Avatar
    Feb 2009
    Bristol
    123
    Extended bolts for spacers
    Need to get some extended bolts for spacers, but wondering if anywhere does extended 'star-drive' bolts so I can use the OEM tool and not have to get locking bolts?
    Also, are the OEM hex-bolts a standard diameter? (Can't measure right now unfortunately).
    '01 Facelift S3. CC'd by the Badger
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Bill sells bolts for these mate but you will need to buy new locking bolts...
    The ones he keeps are long enough to be used on 15mm spacers uncut but you will need to trim them a tad for 10mm spacers especially for the front..
    OEM wheels use radius seats...
    <tuffty/>
    Keefy's Avatar
    Feb 2009
    Bristol
    123
    Yeah, have messaged Bill but he needs to know more details:
    "Do you have sufficient diameter in your wheels to accommodate normal Hex head bolts?"
    I'm assuming that's the diameter of the hex head itself
    - can't remember if it's 17mm or 19mm on OEM RSTTs?
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    you asked for splines, which is only lockers, and the splines are specific for the lockers.. not the same splines..
    i think you are perhaps confused..
    spline drive bolts are available for non-std wheels where usually they are multifitment drilled...
    17mm hex is std... you just need slightly longer bolts which I quoted you for.. Asking for splines was'nt relevant I dont think for what you actually want.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Keefy's Avatar
    Feb 2009
    Bristol
    123
    Apologies for the confusion - didn't know what you meant by 'splines' and was wondering if you can get longer versions of the OEM lockers so the 'star' tool can still be used.
    Will take this back to email
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    ah. no.. no can do on that one. soz
    bill@badger5.co.uk
  1. Wheel bolts for spacers
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2012, 11:03
  2. Extra long Wheel Bolts for 20mm spacers
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2011, 00:27
  3. Wheel spacers.. did you change the bolts for longer ones?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2010, 20:22
  4. bolts required for spacers?
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2007, 05:21
  5. WHEEL BOLTS FOR SPACERS
    By S3 03 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2006, 22:21
