AH FabricationsChris Nott
Results 1 to 13 of 13
    Feb 2011
    14
    S3 Cylinder compression figures?
    Hi guys, I've been using lots of oil (topping up approx 1.5litres per month) recently. Last night i decided to check the compression of each cylinder, and found i was down a fair bit on 2 cylinders compared to the others. Im not entirely sure what readings to expect but the results i found were as follows,
    170PSI on 2,
    155PSI on 1
    145PSI on 1
    Could anyone please advise me as to what i should be expecting to find? Car is a 2003 BAM engine, REVO stage 1.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Pretty low dude... especially 145psi... typically 180/190psi from memory on a good one... you tried it wet yet? (pour a small amount of oil in the plug hole)
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Is it a standard engine?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Feb 2011
    14
    Cheers Tuftty. Yes tried this on the 2 lowest ones and the pressure increased way above this, not sure on figures though, definately above the 170 i found on the other 2 though. Am i right in thinking my problem here lies with the piston rings rather than the valves?
    Feb 2011
    14
    The cars been remapped Andrew, Revo stage 1, also have Milltek cat back, FMIC, TIP and aftermarket panel filter.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Quote Originally Posted by harrsf View Post
    You say the pressures increased when wet tested?
    What were the cyl numbers/pressure in the end?
    <tuffty/>
    Feb 2011
    14
    I only wet tested the 2 cylinders closest to the cam belt side, not sure what the numbers of these are. Not entirely sure of the end pressure as i didn't write these figures down but it went upto around 200-210PSI if I remember rightly.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Is the car breathing heavy? blue smoke on acceleration? not seen bad valves as such even on high mileage 20vs but have seen worn rings so its plausible that is ts the rings in this case... done a leak down test?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    so 145psi when dry and 200psi when wet?... thats quite a leap tbh... normally goes up 10/15% iirc
    <tuffty/>
    Feb 2011
    14
    Yes it was defiantely a jump of that. The car does seem a little down on power, but no blue smoke, only smoke its given off was after the wet test when burning the oil i'd put in. My next question if you can advise me; how big of a job is it to remove the engine from these cars? Its just that my clutch needs replacing, and i was also thinking of changing the exhaust manifold, downpipe and cat once my other troubles were sorted.... but now thinking of doing it myself with some help from more knowledgable people, and killing a few birds with one stone hopefully?
    Apr 2012
    Wiltshire
    164
    not too hard, the part i struggled with was getting front bumper off lol as i thought that there must be more holding it on (its simple once you have done it). life is much easier once engine is out to change clutch. your just need red coolant, power steering fluid, if you have air con your lose your gas, and brake fluid.
    Feb 2011
    14
    Cheers Dan, i'm a bit of a master at removing and refitting the bumper lol, done it a few times re-attatching popped off intercooler hoses due to inadequate jubilee clips!
    As i say i have zero experience working on engines, let alone removing one but i have friends and family who have, and im full of enthusiasm and want to learn! I work in engineering so im pretty decent with my hands, but i just wanted to make sure removal wasn't something we could start and get stuck into without being properly prepared for.
    Apr 2012
    Wiltshire
    164
    I am the same, the bottomw end went on my car several months ago. I re-built the whole engine on my own with only a haynes manual and information off the internet. i change everything, crank, mains, bigends, conrods, pistons, rings, oil pump, pump chain, crank oil seals, all the cam belt stuff, re-built head and ground in all the valves. did all this over a period of like three months, never done this before as i am a plumber not a mechanic. and the amazing part is it runs lol done over 3thousand miles in it now and there are no knocks of nothing. It is rewarding doing it yourself, and if you have the time and you want to then why not. I dont think i will ever take the car back to a garage again except for mot and tuneing lol
  1. Help!!! audi a3 1.8t 1998 (aug). No compression on cylinder 1
    By dandos in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2011, 16:55
  2. Star Performance Testing Day Pt5 Power Figures
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 08:49
  3. Performance figures
    By robthehungrymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 20:45
  4. What are the 225 S3's performance figures
    By David_Moon in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2004, 11:49
  5. 91 Audi 80 1.8 4 cylinder not fast enough any help
    By dan1972 in forum Classic Audi Forum
    Last Post: 26th April 2004, 16:07
