Results 1 to 9 of 9
    Omniquito's Avatar
    Sep 2012
    55
    Oil pressure gauge fitment & measure
    Hi everyone, yet another pressure related question.
    Am i right in thinking that if i fit a pressure gauge to test my oil pump if my bottom end is shot it will show low pressure too so wont single out the pump?
    I am most likely going to unscrew the pressure switch and fit a gauge in there but really want to prove the pump or not as the case maybe.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Pumps don't normally go its the oil pick up that gets blocked that typically causes the problem... if the bottom end is shot its most likely the result of an oil problem rather than the cause...
    Got a TT in at the minute that had a blocked oil pick up and was on a track day at combe... its spun a big end bearing....
    <tuffty/>
    Omniquito's Avatar
    Sep 2012
    55
    Hi tufty.
    I had the pickup replaced and it was rammed but didnt stop the issue of the 3 lights and top end starvation when warm...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Chances are then the damage is done... a new pump can be bought for around 40 quid on eBay (Topran brand, I use on myself)...
    I was chasing a rattle on mine which turned out to be small ends but while doing so I changed the oil filter housing which has a one way valve in it, new oil pump and a few other things...
    Oil pressure should be around a bar on idle and be on 4 bar or more iirc once the revs rise....
    If your oil pressure is low then it could be the bottom end is shot... you can inspect the big ends while the sump is off...
    Check oil pressure first... there is a capped hole on top of the oil filter housing that you can use for the pressure gauge rather than pulling the pressure switch... confirm its pressure related rather than a dodgy sensor as the sump sensors can go iffy too...
    <tuffty/>
    Omniquito's Avatar
    Sep 2012
    55
    Thanks mate, a lot of possibilities to check for but need to start somewhere so i will test the pressure.
    Do you know what thread it is?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Not sure off hand... M10x1 leaps to mind...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,162
    yep, M10x1 - there is a blank in the housing you can use for tapping in.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Omniquito's Avatar
    Sep 2012
    55
    Thanks you fellas, thats what i will be doing this weekend then!
    At this tap, if i had low pressure would this suggest only the pump could be to blame or does it go through the big ends etc and give me false hope to the pump?
    RIP S3dave
    May 2004
    nr Glos
    7,162
    it does'nt really prove either distinctly...
    excessive clearances on bearings would also lead to lower oil pressures... as could a tired pump.
    pump cost ~ £80-£90 to be sure
    bill@badger5.co.uk
  1. Would like to fit an oil pressure gauge...
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2011, 10:56
  2. ****Oil pressure gauge install with pics**** As requested...
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2010, 19:48
  3. Oil pressure gauge/Oil pressure test
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2010, 10:58
  4. Oil pressure gauge help needed
    By Iridium in forum General Technical / How To
    Last Post: 14th March 2007, 15:57
  5. oil pressure gauge help needed
    By Iridium in forum Volkswagen and other VAG
    Last Post: 14th March 2007, 15:55
