JMB RetrofitsVolks Autos
    Dec 2011
    396
    hi all ive got some silly questions
    hi all im doing my cam chain tensioner and in the gide it say get it to tdc but how do i no when its at top dead center and where is it best to turn the engine over from ?
    phil miller's Avatar
    Sep 2012
    Devon
    843
    If you jack up the drivers side wheel and stick the car in 5th or 6th you can turn it over using the road wheel, if you take the cambelt upper cover off you will then see the marks you need to line up
    hope the swap goes well
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    While you shouldn't have to remove the inlet cam from the timing chain just be aware that if you do that you need to make sure you set the right amount of links between the cam timing marks...
    ....and use a new gasket and half moon seal... they come in a kit and cost about a fiver from a dealer
    <tuffty/>
  1. next question...whose got some AJL code or tqs injectors spare
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2010, 21:01
  2. Hi all.... ive got a few questions to pick ur brain!lol
    By CamsA3 20vT in forum General Technical / How To
    Last Post: 25th August 2009, 20:37
  3. Finally got some pics! and a couple more questions...
    By croig in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2009, 12:22
  4. thnking of getting an s3 - got some questions/need some pointers
    By bozor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2008, 18:44
  5. All Tyres for Low Price! I Got Some!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2004, 11:14
