AH FabricationsEM Tuning
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Odd behaviour on the rollers
    Took my car to a dyno day (RR event) on the week end.
    The operator started to load the car and when on boost, all of the sudden the power cut down for a split second and kept doing this a couple of times during the pull, car never done this on other RR events.
    The operator rekoned is the haldex cutting in and out, i've seen a graph where the haldex makes more jagged line than what i've got, i think is throttle cut of some sort, the ESP was turned off when on the RR.
    My car is 05-00 build, so is my car been recalled by the factory to fit ESP or did it come with it?
    I'm asking this because i've heard storyes where a retrofitted ESP can never be turned off completelly or are just bolloks and problem is something else?
    Ross.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Assuming 4wd rollers? looks like haldex kicking in tbh... if the rear rollers aren't matched/driven from the front rollers then haldex will be cutting in and out.. easy fix is to run with the fuse pulled...
    <tuffty/>
    Jun 2011
    146
    Yes tuffty, 4wd dyno, this is the first time the car runned on a mailine dyno.
    Past times always used dyno dinamics.
    Other cars like TTS, 8P A3/S3 and golf R didn't suffer from the same issue, i do run a peloquin TBD at front.
    Next time i'll pull the fuse out.
    Ross.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Gen2 and above Haldex on later cars don't suffer as much as our Gen1 ones do... pulling the fuse is a simple enough task though...
    <tuffty/>
  1. Not a S3 I know, but had my new motor on the rollers yesterday..
    By Vtec Abuser in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2008, 09:46
  2. Had the Audi on the rollers today.
    By K7ERG in forum Diesel forum
    Last Post: 12th January 2007, 09:04
  3. Vid of 1520bhp supra on the rollers.
    By Soupie69uk in forum General Chat
    Last Post: 14th July 2005, 23:10
  4. on the rollers
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2005, 23:40
  5. Had my car on the rollers yesterday...
    By Drystone in forum Other Brands & Models
    Last Post: 15th April 2003, 01:48
