Chris NottEM Tuning
Results 1 to 14 of 14
Like Tree2Likes
  • 2 Post By Audi S3 freak
Thread: Wheel question. Info please
    Feb 2012
    135
    Anyone have any ideas what size wheel adapters I need to run range rover sport wheels? It's been done before I know but love how they look on the s3 so getting them made up as soon as I have the info. Cheers
    Feb 2012
    135
    Want it to sit like this one
    s3clarke and Nogmeister like this.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,832
    5x100 ---> 5x120, can't give info on offset, as I don't know what offset Range Rover wheels come in.
    You've got to have a laugh!
    Feb 2012
    135
    Quote Originally Posted by jojo View Post
    Cheers jojo. If I get the offset are you able to work it out or at least tell me how to work it out? I know it's been done to at least 2 s3's before but for some strange reason can't find any info on them! Already have the wheels just sat here! Lol
    Jun 2012
    285
    What size are they? 19s or 20s? Fooking ell
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,832
    Quote Originally Posted by Audi S3 freak View Post
    Offest is easy, clearance depends on the wheel widths and tyre sizes. Standard is ET35, but running 10mm spacers will make this ET25. So if the Range Rover wheels happen to be ET45, I would recommend 20mm hub adaptors to make them ET25. This offset is fine for 19x8.5 size rims running 235/35 tyres. Rears you can go as low as ET15 with the same size alloy/tyre combo.
    Feb 2012
    135
    ok well the wheels are 19x9 i think? Standard range tyres on it wass 225 not sure if that will help? and tyres will be 215/35/19
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Looks good, but it's totally unusable.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    needs far more tyre.
    215's on a 9 is retarded.
    The wheel pictured above is ET53.
    TD5 Land Rover Defender build
    Feb 2012
    135
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,832
    Agree with Kev here, 215s on a 9" rim is stretching it a little, but if it's what you are after, I would avoid driving the car hard! 9" wide means you will need ET25 minimum to clear the strut, but if you use coilovers, then it gives you a bit more room to play with. ET53 gives you a lot of options, so just need to make sure you get your calcs correct.
    Feb 2012
    135
    Well the car above is sat on 215's so can't be as bad as it seems! Your all missing the point, all I want to know is what width adapters not my choice in tyre size! Lol as for useable.....I have 18" rims for beating it these will just be for looks when I go to shows! 18" are my daily choice! Oh and it's sat on kw variant coilys. Cheers for the help jojo
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,832
    You need 25 or 30mm adaptors then, to make the rangy wheels ET23 or ET28, I've ran ET25 and ET30 with 19x8.5s and 235/35 tyres with no rubbing issues, the latter was about 3mm clearance from the strut, and I even tracked it!
    Feb 2012
    135
    Jojo your a star cheers fella! Will post a pic when she's all done!
  1. wheel offset and tyre sizes, need info please :)
    By liam_b in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2010, 23:34
  2. Another wheel question please
    By Fulham71 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2007, 05:49
  3. Steering wheel swap? Info please
    By ITALIANJOB in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2005, 14:46
  4. New S3 wheels question
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 15:11
  5. just another wheels question
    By darrenrally in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2003, 22:38
