pictures of my turbo,head, mani dry build
s3gazz
bradford
hi guys some pics here of my AGU head mani and turbo plus down pipe all together after some modding u dont need to use the copper spacers either and all looks ok with no real problem in fitting with the head off.
here is the head with the mani and gasket on touching the suport bracket for the charge pipe so had to wip that off and the mani touching the head before s3dave took a grinder too it.
and after a took the suport bracket off
here is where the mani catchies on the head
then s3dave took his grinder to the mani
and the turbo and mani on the head with no problems
and with the downpipe connected.
hope u enjoy i did hehe.
you will want to install the water/oil lines before installing.. kok of a job afterwards otherwise
much more clearance on the problem dp stud in your pix than the one i have here. which is never going to clear.
good work
well done chaps
keep it up
Reactions: TqsScott
What version u have at the min bill as I take it my v3 has more clearance.
Ill fit the water and oil lines first ye due to 2 of them been reel pigs one behind the turbo and one undernief will the oil and water lines be ok with the heat of the mani bill thanks
V3... but I think an earlier one... which came with the copper gasket things..
it wont fit however..
seems it was a woops on the 1st few..
this kit is the same bill with the copper spacers i think not shore there gaskets think they are for clearance pal on downpipe and so on.
nice bit of kit tho and oem gaskets for me too.
what downpipe wrap would u use bill and will it benefit from been wraped
11
560
778
11
