AH FabricationsEM Tuning
Results 1 to 13 of 13
    Dec 2011
    396
    cam chain tensioner how to
    hi all i cant seem to find the how to on replaceing it ?
    Dec 2011
    396
    help ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    <tuffty/>
    IFFY_77's Avatar
    Jun 2012
    London
    68
    Oww I think I need to replace my cam chain tensioner it sounds like the ticking/clicking is coming from thr have you had this problem? Is it a common problem my cars done 111k don't think it's ever been changed ... timing belt and pulley tensioner are fine hydrolix tappets are fine checked them and the ticking is constant through rev range. Must b the the cam tensioner ???
    Sep 2012
    bournemouth
    32
    Quote Originally Posted by harvey01 View Post
    help ?
    i replaced mine the other day changed the cambelt and waterpump at same time.
    Basically i took cambelt off, then undone all the torq bolts holding the camshafts in place and the ones holding the chain tensioner. My tensioner was so worn that with small amounts of force with a screw driver i pulled the camshafts out with the tensioner and chain as one piece.
    If u have autodata it then shows you how the chain should line up with the camshafts have to get that bit spot on. fitted it all in again together checking the chain was still timed up correctly then just took off the tool holding the pads away from chain which then tensioned it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    You only need to remove the inlet cam to get the tensioner out...
    <tuffty/>
    Sep 2012
    bournemouth
    32
    save urself few minutes by doing that then
    Dec 2011
    396
    so ive started my cam chain but ive noticed when i was turning the engine over to find tdc my tensioner hissis could this be a seal on it im going to fit the new one anyway but could this have been my problem ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    The hiss is compression being released from the engine... its normal
    <tuffty/>
    Dec 2011
    396
    its not that mate ive got no plugs in and it only comes from the tensioner side . it dosent seem to drop back like some ive seen
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    ...in that case it will be the oil pressure in the tensioner itself I suspect... plausibly your issue... can't remember off hand from the last one I did...
    <tuffty/>
    Dec 2011
    396
    hi all well the tensioner is fitted quite easy but one thing i would say is the screews that hold the cam caps pull a small amount of ally when you take them out and if you dont notice it will go under the cam cap ! it looked like the tensioner was fine but the gasket under it was letting by so there was'nt the pressure to keep it working at low rpm
  1. Cam chain tensioner
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2010, 18:13
  2. Cam chain tensioner
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2010, 12:26
  3. Cam chain tensioner.
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 15:21
  4. cam chain tensioner
    By a4quat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2009, 23:00
  5. cam chain tensioner replacement
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2008, 16:18
