Sky InsuranceAH Fabrications
Results 1 to 14 of 14
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Holding back on full throttle
    As title says really, I'm just out for a dive, second and third gear on full throttle is Lumpy and feels like its holding back then letting go... It used to do it on the occasion Inthird part throttle, from previous scans I know a lambs sensor flagged up could it be this?
    Im just sick of throwing money at the bloody thing, within the last few months iv cleaned the throttle body and the injectors
    Any ideas?! Thanks.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,840
    Boost leak, MAF sensor?
    You've got to have a laugh!
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Forgot to mention its not all the time. Iv looked everywhere for leaks need a smoke test though is there a way to check a maf? How much are they new and can I upgrade it, will a s3 one fit?
    Feb 2012
    bedfordshire
    735
    had this problem for a while Ended up being the maf
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Quote Originally Posted by James TQ View Post
    If its the MAF buy the right one for the car... the map is set for the type of MAF you have..
    Fault codes and logging next...
    What year/model is the car too?
    <tuffty/>
    Feb 2012
    bedfordshire
    735
    Go on euro car parts mate and use this code
    Midmonth30 Gives you 30% off and when you take the old maf back you get £35 back so I got one today for £58 for a Bosch
    James TQ's Avatar
    Apr 2012
    Essex
    546
    It's a 1999 a3 quattro
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,695
    I had boost issues recently being intermittent. For me it turned out to be the maf.
    <Jay A3 build thread>
    241bhp K03s - R Tech
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    I would be logging it first before chucking cash at it...
    MAF issue present differently on different engine codes... AGU's rely heavily on the MAF and generally don't run very well at all when its on its way out... cars with ME7 ECU's like in this case the A3 TQS fair much better and can run happily with the MAF disconnected...
    I would disconnect the MAF in the first instance and see if the car runs any better however... seeing as you have suggested there is a lambda fault then this should also be addressed (post up the actual code as this will help)
    You do need to log the car though... airflow and boost on yours in particular... logging the lambda in your case won't be of much help as its a narrow band ecu...
    The fact you know you have a fault somewhere and not addressed this won't be helping... only when you know all the known issues are resolved can you hope to find the ones you don't know about...
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    546
    right. codes are
    16518
    16500
    16487
    17524
    one is a maf reading too high?
    May 2012
    Manchester
    229
    Quote Originally Posted by dre_S3 View Post
    did you get that offer in store or online mate? would it be available either way? cheers
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Karl, I called euro. You'd have to type In the code online then select collect in store hand your maf over there....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Research your fault codes here...
    Category:Fault Codes - Ross-Tech Wiki
    If using VCDS to scan then post up the output of the scan as it will have the fault code descriptions in them making it easy to work out whats going on else we will just need to look them up defeating the object a bit
    16518
    Not listed at Ross Tech which typically means its not a common issue but using the power of Google... (VW Online Technical Library - Diagnostic Trouble Codes (DTC) Tables)
    "O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected"
    16500
    16500/P0116/000278 - Ross-Tech Wiki
    16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    16487
    16487/P0103/000259 - Ross-Tech Wiki
    16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too High
    17524
    17524/P1116/004374 - Ross-Tech Wiki
    17524/P1116/004374 - Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1: Open Circuit
    Couple of possibilities here.. could be wiring... check earths under the battery tray as wiring faults on multiple sensors are normally all interlinked somehow...
    If not that then it seems your Lambda is buggered so change it... its plausible the Signal too high fault is symptomatic of the lambda fault but get the Lambda changed first...
    CTS looks like its dodgy too (common issue)... get a genuine one as ECP ones fail quite often...
    See how that goes once fitted and codes cleared...
    No point in diagnosing much else until you know the sensors are working as expected..
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Is the lambda located on the downpipe? Also what is a cts? Thanks for the info it's a great help.
  1. S3 holding back on power... any ideas?
    By lloydsta101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2010, 11:02
  2. A3 tdi holds back like limp mode ?
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2009, 07:16
  3. Holding Back!!
    By Audilee in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2009, 23:43
  4. car hesitating/holding back
    By cawood in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2007, 13:24
  5. s4 seems to hold back at 3500 rpm
    By AudiPete in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2006, 10:57
