Volks AutosAH Fabrications
Results 1 to 9 of 9
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    AEB Head - stk cams or S3 cams
    Hi Guys
    As above, should I use the stock AEB cams or should I transfer the cams from my S3. This is temporary as the courier has lost my cat intake cam
    Are there any differences between camshafts on the 1.8t 20v heads?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I transferred my S3 cams into the AEB head only because I knew the history of my cams over the AEB ones. Apart from that there should be no difference.
    You will also need to transfer over your VVT unit if you have one as AEB heads don't.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    You can't use the pully from an AEB head as the inline setup is different... you will need the cam position wheel from the S3 if yours is an AMK/BAM as VVT is 4 window rather than non VVT 2 window
    <tuffty/>
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Thanks for the wise words guys
    Apr 2012
    Wiltshire
    164
    i changed my apy head for a aeb head, asked audi and they checked the part numbers out and both the cam are identical part numbers. the only part i did change was the cam pully and the sensor cap thing.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    So I finally got some cat cams to go with the AEB head.
    I remember Tuffy mentioned that I will need to use the VVT from my S3 engine. What would happen if I didnt use the VVT? Is it possible or will it cause issues with the ECU ?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,454
    If you wanted you can code out the VVT but i don't see the point if you have then keep.
    You can run without the VVT but a error code would come up
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    the aeb head that I got came with a brand new cam chain tensioner and thought it might be better to use it rather than the used VVT,
    but I dont want to have error codes.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    <tuffty/>
    Tuffty do you know if the cam wheel on an ARY is the same as an AGU?
  1. Audi AEB head gasket replacement
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2012, 14:59
  2. Cam adjuster Gasket, Cam Cover Paint (Pics)
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2011, 23:58
  3. will an aeb head fit apu engine?
    By olds_kool in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 08:38
  4. AEB Head
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2009, 21:58
  5. 2.0 TFSI HPFP Cam Lobe and Cam Follower
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 05:46
