EM TuningAH Fabrications
Results 1 to 8 of 8
    BeeKay's Avatar
    Jun 2012
    Tipton, Dudley, United Kingdom, United Kingdom
    63
    turbo intercooler hose clip
    ok so ive got myself a 1.9 tdi 130 bhp was driving completely fine then i hear a pop n see a cloud of smoke pulled over cracked open the bonnet to find the intercooler pipe at the front of the engine had come off found out that the clip is messed up , anyone know where i can get a new clip picture of it below
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Ant view pics at the moment but ud recommend getting a hve stainless clamps.you can get them on ebay
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Lewis583's Avatar
    Mar 2010
    872
    The clip looks fine to me from that picture. You will probably find the metal coupling on the intercooler hose has worn. I would take the hose off and inspect the coupling.
    Both clip and hose will be availabe from main dealers.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    BeeKay's Avatar
    Jun 2012
    63
    thanks for the replys will take a look , i just went to a audi stealership but the parts section had closed from reading around ive seen there 30 quid for the pipe and the clips
    BeeKay's Avatar
    Jun 2012
    63
    ok after taking the pipe completely out abd inspecting its deffo not rhe pipe see 1st pic looks completely fine , after going further back i looked at the thing it clamps onto it comes out as the intercooler is also clipped onto this attachment taken pics of it looks worn out round the edges see 2nd pic when i turned it around and clipped it onto the other side it worked fine for a while ( has the same type of teeth both sides) i even had a good blast in the car but 2 hours later it came off again , anyone know what its called and where i can get one from trying to aviod a stealership as much as i can bad experiance , also the top of my pipe looked very dirty looks like i need to clean the carb see pic 3
    Lewis583's Avatar
    Mar 2010
    872
    Yeah i thought the coupling would have been worn. Unfortunately you have to buy a new boost pipe mate as the coupling and hose can't be separated. AFAIK the hose is dealer only aswell
    Full VCDS
    BeeKay's Avatar
    Jun 2012
    63
    thanks for your reply it was the bottom coupling that was worn this is detachable see pic attached
    BeeKay's Avatar
    Jun 2012
    63
    got it fixed was a 30 quid part ( pic attached ) gave it a good blast drives like a dream now
    will add part number for refrence should anyone have the same prob might come in handy
  1. Turbo hose clips and clamps
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2009, 12:16
  2. Turbo versus Jubilee clip
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2008, 08:31
  3. Samco T.I.P. - Where to find good quality hose clips ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2005, 09:59
  4. s3 Bottom intercooler hose
    By S3_Shaun84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2005, 14:50
  5. Those f****** b****** DV hose clips... Help!
    By PreacherCain in forum General Technical / How To
    Last Post: 20th May 2003, 12:45
