Sky InsuranceJMB Retrofits
Results 1 to 12 of 12
    andya3turbo's Avatar
    Jan 2012
    Skelmersdale
    85
    Exclamation MOT Faild today??????????
    A3 faild its mot today on emissions CO levels too high, getting 0.57 on fast idle and limit is 0.30
    and getting 0.56 on idle. any ideas what this could be? my air filter is a bit dark black but have seen worse??. oil was changed and filter 3 months ago? also tester said about spark plugs not gapped? anyone have any ideas?
    thanks
    Greg-S3's Avatar
    Aug 2012
    Northampton
    332
    Have the car scanned for faults, get the car really hot before your next re-test, have the MAF sensor checked when scanned, when scanned see what the lamda's are reading, those fuel tank additives work, the good ones anyway!
    Audi S3 AMK in dolphin grey, cleaner than clean!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    What was lambda value?
    If it was sitting at lambda 1 with sensible HC then your cats either dead or missing.
    TD5 Land Rover Defender build
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    How come I've never seen you in Skem???Come to me andwe can check it what is wrong with your car. I'm in old Skem.
    Currently not in the country
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Dead cat(s) I'm afraid
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Jun 2012
    Birmingham
    29
    Quote Originally Posted by Benjiman46 View Post
    could also just be something simple like it needing a full service, with new plugs or the car wasn't up to temp while checking the emissions.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,390
    Paste it first with a forte engine cleaner and shell optimax in the fuel tank , worked for my focus st! :-)
    Aug 2012
    25
    I am a tester,give your car a good hard drive before u get it retested again.
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Put a brake fluid to the throttle body. It will clean all system but it will smoke for a couple of minutes.
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    Maybe Terraclean, always wanted to try it myself
    Jan 2012
    Skelmersdale
    85
    Cheers everyone for tips and advice, i used cata clean and nothing still sky high CO 's as above the cat is dead, lambada is fine tho atleast, got the old cat off yesterday. a little something i thought i would mention tho, i seen a video on YouTube about cat testing and it said that a small hole or gaps in the manifold joint can lead to high levels, on removing the cat one of the bolts was missing and the other was loose i am just thinking is it all that simple??? there's no rattle on the cat or anything so nothing is crumbled inside unless its burnt up? my new cat is ordered now so sit back and wait
    Greg-S3's Avatar
    Aug 2012
    Northampton
    332
    It could be as simple as replacing the stud and tighten it up! I remember fixing a vauxhall Astra that was running massively rich, turned out the problem was a tiny crack in the manifold after bank 1 lamda and before bank 2 and it turned out cold air (taken in from the crack)
    was rushing past bank 2 lamda which was raising the fuel put into the system hence high c0!!
  1. Mot today.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2010, 17:53
  2. How Bl**dy typical MOT day today
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2010, 02:04
  3. MOT Today....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2010, 12:18
  4. mot today..... failed
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2008, 10:38
  5. mot was due today
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2007, 01:00
