Sky InsuranceVolks Autos
Results 1 to 16 of 16
    May 2012
    Manchester
    229
    quick boost leak pointer
    I know a lot of people are chasing boost leaks, ive been chasing one for a while now and i thought i tried everything, untill i reached down the back of my turbo this morning. The egt prope was loose tightened it up with a 17mm spanner and finally found that little bugger! Ive been over the engine bay with a fine tooth comb and not even thought to check that so thought id share the tip.
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    A valid pointer! Most people including myself forget about that and focus on boost pipes!
    Audi S3 AMK in dolphin grey, cleaner than clean!
    James TQ's Avatar
    Apr 2012
    Essex
    548
    silly question where about is it? can you see it or do you have to feel your way around?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    also have you noticed a big difference in the drive?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    When the turbo is cold to save burning yourself, reach down the back of the engine grab the turbo have a little feel around on the narrower body part and you should feel a 17mm 6 sided nut with a little rod and braided wire coming out!!
    May 2012
    Manchester
    229
    yeah the difference in the drive is great, the boost used to come in and give me a kick but tail off instantly with a hissing that was coming from behind the centre console. you can see it if you shine a torch down the back of the turbo, its a thin metal pipe that has a 90 degree bend in it and goes towards the passenger side. reach your hand down and behind the tip and give the pipe as it joins the turbo a wiggle, if you can turn it in the direction the prop shaft turns if you get me then its loose (probably the worst description ever)
    James TQ's Avatar
    Apr 2012
    Essex
    548
    just had a quick look, couldnt make out where you were on about lol, ill try find a picture on here
    James TQ's Avatar
    Apr 2012
    Essex
    548
    is the probe even on a ko3 lol?
    May 2012
    Manchester
    229
    any luck? ive had a look for pics on google but cant find anything decent. If you look down the back of the turbo you will see the actuator rod, just below this you will see a thin silver pipe coming straight out towards the rear of the car then bending 90 degrees to the right, best i can explain it im afraid, or try and follow the silver braided wire from the little black box under the inlet manifold.
    May 2012
    Manchester
    229
    Quote Originally Posted by James TQ View Post
    not sure, look underneath your inlet manifold and if you have a small black square box with an electrical connector on on end and braided wire coming out of the rear of it then yeah you do, if not then im guessing you dont have this
    James TQ's Avatar
    Apr 2012
    Essex
    548
    egt sensor location on '03 S3 ill have another look tomorrow, thanks guys
    James TQ's Avatar
    Apr 2012
    Essex
    548
    dont think i have the sensor i can only see a probe on the downpipe
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    EGT Sensor wouldnt cause a boost leak Its in the exhaust.
    K03's dont have EGT sensors.
    TD5 Land Rover Defender build
    May 2012
    Manchester
    229
    thinking about it yeah your'e right, unless some of my exhaust gasses were leaking causing less gasses spinning the turbine or something? definately has helped a little bit though and some of the hissing has dissapeared
    "Stick a V8 in it!"
    15,385
    It'll certainly have caused a hissing noise, theres typically more pressure in the exhaust manifold than in the inlet, but its not a boost leak :P
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    Its only facelift S3's (AMK/BAM) that have EGT probes.... A3's and pre facelift S3's (APY) don't have them...
    <tuffty/>
  1. Boost Leak
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2005, 15:17
  2. Oil/Boost Leak
    By chimmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2005, 10:48
  3. more boost leak possibilities....
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2005, 14:23
  4. Follow up from Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 13:43
  5. Boost Leak
    Last Post: 8th December 2004, 20:47
