JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    Apr 2012
    Tunbridge Wells
    105
    S3 8L facelift headlamp compared to A3 8L facelift headlamp...
    Hey all,
    Bit of a weird title I know, but I'm interested to know what similarities, or differences, there are between the S3 8L facelift headlamps, and the A3 8L facelift headlamps. My reason for wanting to look into this is, as you might expect, that the headlights on my S3 are just beyond repair. Despite 4 attempts to fix them, I'm still having issues, particularly with the below:
    - 2 of the manual adjustment cogs have gone brittle and snapped off (common fault). Managed to replace these with A3 equivalents from my local scrappy, but aren't holding well enough, adjustment is near enough impossible.
    - Both auto levelling clips are broken. Had 4 attempts at fabricating my own using pre-facelift A3 clips as a base, but these aren't holding as well as they should really.
    - The lenses, despite having been polished and buffed right up, are just old and tired looking
    So really, I'm looking to find out whether or not I could use parts A3 facelift lights to replace the broken bits on my S3 lights. I'm aware that I could use the manual adjustment cogs no problem, but could I use the lenses? And are the levelling clips the same design? The A3 facelift headlights look absolutely identical, but apparently, internally, they're totally different.
    If anyone can help point out any differences, I'd be really grateful. You might be wondering why I'm even considering attempting this project - fact is, I'm not willing to shell out near enough £500.00 a side for new headlamps.
    Thanks in advance for your help - of course, if I do take on this project, I'll be sure to document the whole thing!
    Greg-S3's Avatar
    Aug 2012
    Northampton
    312
    Face lift S3 headlamps are xenon, standard A3 headlamps are halogen bulbs and the optical lens is a lot bigger than a xenon one.
    Audi S3 AMK in dolphin grey, cleaner than clean!
    Apr 2012
    Tunbridge Wells
    105
    Quote Originally Posted by Gregor-S3 View Post
    So, with this in mind, the only parts that should be different are the optical lenses, and wiring obviously, as the S3 headlamp includes xenon ballast etc.?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    312
    S3 lamps have ballast packs but standard one don't! Suppose the best thing to do is buy a second han standard headlamp, open her up and see what's what!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    If they're made by the same company, then it should be possible to swap the Xenon projector and ballast into the non-xenon unit.
    Its certainly the case on B5's, the non-xenon headlights use exactly the same casing as the Xenon ones, just different internal bits.
    TD5 Land Rover Defender build
    Apr 2012
    Tunbridge Wells
    105
    Thanks Aragorn, that's exactly the info I was looking for.
    From the part images on ETKA, the casings and lenses appear to be indentical, so I'm hoping I'll be able to cobble together a set of working headlights from parts from my current ones, and parts from some brand new A3 facelift halogens. I've ordered the A3 halogens, so if I manage it, I'll post a thread up showing how it went.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by AJD S3 View Post
    Hi
    The black plastic casing and the lens are from the same moulds(ish).
    However to fit the xenon gubbins to a non-xenon casing you'll have to dremel some holes into the black plastic where the xenon electrics need to enter.
    You will, as mentioned, also need to swap the reflector and projector BUT this will require splitting the headlight unit in half.
    This is easy if you have a unit which has the temperature sensitive adhesive. You can bake it in the oven for a while.
    If you have the Silicon-type adhesive you WILL NOT be able to split the head light apart. Full stop. I tried this, the adhesive is also NOT silicon which can be broken down with a normal silicon digester gunk.
    Any way - good luck with this. If you find a way of breaking down the newer adhesives let me know.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Apr 2012
    Tunbridge Wells
    105
    Quote Originally Posted by vfr800 View Post
    Hi
    Liam
    Hi, thanks for this.
    I was assuming the holes would still be there for the Xenon cables, considering both casings are from the same mould? I thought they'd just have plastic inserts clipped in to fill the holes? Either way, cutting holes shouldn't be an issue.
    Ive already taken my current headlights apart many, many times, using a heatgun - all seems to go very smoothly to be honest. So I'm thinking it'll be the same with the new ones. I will post up progress photos on how it all goes.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Good luck with it. If you've found a source of headlamps which are bonded with the old adhesive I'd be interested.
    Liam
    "Stick a V8 in it!"
    15,370
    The Valeo units on the A4 arent heat sensitive, you need to be VERY brutal with a screwdriver or two to get the units apart. I've done it though, took a few hours, but i managed it!
    Theres a guide on a4mods that explains what you need to do, but basically you use heat and force to bend the outer lip up out the way so its poking up at a right angle to the casing, then you can get the screwdriver in behind/underneath the lens and break it free from the adhesive.
    The older Bosch and Hella units are heat sensitve as mentioned and come apart much easier.
    One thing that might work, is to buy Depo replicas of the proper light units if they're available, as these usually use the heat sensitive glue, and while they have rubbish optics, your throwing them away anyway!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Did you get anywhere with this?
  1. Facelift sline rear bumper on pre facelift?
    By Danny Scott in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2009, 13:20
  2. Facelift 2001 mirrors onto a pre-facelift 1996
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2008, 15:12
  3. How easy is it to fit a facelift centre console in a pre-facelift?
    By Blue_Thunder in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th August 2007, 13:09
  4. Facelift front seats into a pre facelift car?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 12:46
  5. Facelift head lamp guys on pre facelift cars.
    Last Post: 8th December 2005, 18:58
