Badger5JMB Retrofits
Results 1 to 7 of 7
    B1GW1L's Avatar
    Sep 2012
    Waterlooville, Nr Portsmouth
    98
    Nearside Drive shaft oil seal
    Guys
    Anyone know where i can order a N/S Drive shaft oil seal from most garages have said its an audi dealer only part im hoping someone on here can advise me otherwise?
    Thanks in advance.
    Lewis583's Avatar
    Mar 2010
    872
    Have you tried the usual places?
    Eurocarparts/GSF/Andrew Page
    Can't see it being that expensive to be honest from main dealer
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    I've had non dealer parts before that don't fit correctly and just leak anyway. Get a dealer CV boot mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    It won't be anymore than £20 from a dealer, it'll fit well and won't leak, after market oil seals aren't worth the trouble!
    Audi S3 AMK in dolphin grey, cleaner than clean!
    B1GW1L's Avatar
    Sep 2012
    98
    OKay so ill get it from a main dealer anyone know if theres a thread for fitting it yourself or would it be better to take it to a garage and get it done?
    I presume you need a ramp ?
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by B1GW1L View Post
    You can do it on axle stands. I did mine. You need a spline tool to undo the bolts and a fair few extensions to reach the bolts where the shaft bolts to the gearbox. You will also need a CV boot too to do up the annoying clips.
    I broke my clip tool on the last CV boot and ended up just going to a garage. It's not the cheapest job labour wise but it's a bloody messy job. If you have all the tools, give it a go.
    S3 Build Thread
    B1GW1L's Avatar
    Sep 2012
    98
    To the garage it is then
  1. Early A3 170 CR - CBBB Engine Code - Oil Pump Drive Shaft
    By Craigy1D in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2011, 19:54
  2. Help! Rear Oil Seal Replacement B5 Quattro Nearside
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2009, 10:20
  3. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
  4. vacuum pump / drive shaft
    By ajmackie in forum General Technical / How To
    Last Post: 9th October 2004, 20:44
  5. Vacuum source / drive shaft
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 03:30
