AH FabricationsChris Nott
    ukku's Avatar
    S3 1.8TQ / Turkey
    Mar 2011
    23
    Question S3 Performance Trouble
    Hi,
    I have an Audi S3, APY engine, 210 with ESP.
    It's not mapped. Stock.
    Just have supersprint exhaust, k&n panel filter and silicone TIP bought from ebay.
    I logged with VCDS several times. (on 3rd and 4th gear)
    Peak maf reading is about 160-165 grams at 5800-6000 rpm, but it suddenly drops on about 6000 rpm, when I reach 6500-6600 rpm, MAF only reads 120-125 grams. Engine load drops with maf. Timing CF starts on 5500 with 1-2 degrees and goes on with 7-8 degrees about 6500 rpm.
    I have changed these;
    MAF (From dealer, not the cheap one)
    Brand new turbo and exhaust manifold
    Coolant temp sensor
    Fuel pressure regulator
    N249, N112, PCV and evap deleted. Vacuum hoses renewed with silicone.
    Intercoolers, inlet manifold and throttle body cleaned. Adaptation ok.
    Boost and vacuum test has done, some clamps renewed. There is no leak anymore.
    Tried another N75, fuel pump, coil pack, dump valve. Nothing changed.
    What should I try?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    165gs equates to approx 206.25 bhp so not a million miles away from stock power, and could easilly be down to just age, do some logging and post the results on here and Im sure some of the more knowledgeable ones will be able to spot anything amiss
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
  1. Performance ???
    By bigtbanshee in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th October 2003, 22:17
  2. 2002 A4 Cab roof trouble
    By gdcfc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th July 2003, 10:55
  3. S3 finalist in Motor's performance car of the year
    By jamesa in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2003, 01:44
  4. Tranny Trouble ?
    By DavidT in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2003, 22:01
