Sky InsuranceJMB Retrofits
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Rear Number Plate Holder Bolts - what size?
    Hi,
    got fed up using sticky pads to fix my rear number plate (they keep getting soggy and the glue doesn't hold), so I've treated my car to a plastic number plate holder as I didn't fancy drilling holes in the plate.
    Anyhoo, I'm trying to figure out what size bolt/screw I need to attach the number plate holder - there are two bolt holes which I've so far been unable to find a suitable size bolt.
    The plastic capped screws that my local Audi deal gave me are two small (diameter) and the two plastic bolts I've tried appear to have the wrong thread.
    I've searched around, but everyone else is using sticky pads/tape. Call me Capt. Awkward, but I really want to bolt them in place
    Thanks,
    Mark.
    rhys1210's Avatar
    Oct 2011
    Fareham
    152
    I think there M6, i had to tap mine out as they were rusty.
    2003 S3 BAM 225 Dolphin grey, Silk Nappa Leather, Bose, Cruise control.
    Mods; custom code stage 1, S3 8P gear knob, pipercross panel filter, APR diverter valve, Forge TIP, Powerflex bushes, R32 rear anti roll bar, spacers F 15mm R 20mm, haldex race controller, Bilstein b12 pro kit, Porsche 996 turbo brakes.
    MarkyB's Avatar
    Bristol & Salisbury
    106
    Mine are looking a bit rusty too, will try WD40 and an M6 Bolt.
    Cheers,
    Mark.
  1. Bolt size for rear number plate fixing
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 17:02
  2. Rear Number plate Light Holders
    By Davy in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st September 2009, 21:44
  3. Genuine Audi rear number plate holder?
    By evapor8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2009, 23:12
  4. Changing my rear number plate and found this!
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2006, 13:05
  5. Fixing Rear Number Plate
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 14:09
