EM TuningJMB Retrofits
Results 1 to 17 of 17
    Oct 2011
    760
    mad max diverter
    so after a lot of reading and research i decided to try the mad max diverter.
    Bought a evo 9 diverter for £60 ebay.
    Turned up, did the fill on the oem hole and drilled the new one.
    Fitted and went for a spin.
    i did not crush the top part yet, im not running huge boost and fitted backwards( reversal of normal dv fitting)
    First thoughts are very impressive.
    Very responsive and good pick up between changes.
    off to work now so i will let you know how it works on a longer run.
    dusty's Avatar
    Nov 2010
    nw england
    144
    I need a new d.v. I've been looking at these and the forge 008p let us know how you get on with it
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    beachbuggy's Avatar
    Surrey
    1,744
    Have a look on the ttforum, big thread on there on them....
    dusty's Avatar
    Nov 2010
    nw england
    144
    Thanks mate I've just read about them what are your opinions should i get the mad max or the forge 008
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Had mine fitted for about 3 weeks and love it, its the actual one off max, noise, response etc is immense, just a shame about the price.
    beachbuggy's Avatar
    Surrey
    1,744
    To be honest I have never used one, for the simple reason it's a DV, it has no performance enhancement, the forge DV's are good and so are 3rd party ones. As long as it holds boost and opens when it should it doesn't matter who or what make it is in my opinion! Buy it if you feel like something different but it's not going to change your life. It's better than stock , which is all that matters!
    But listen to those that have used
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Dan i totally agree but this is a defo improvement over the forge 008 that i ran, throttle response is better and back on boost is better if that makes sense.
    beachbuggy's Avatar
    Surrey
    1,744
    It's funny as its the "BIGGEST" thing on ttforum at the moment but things like Wellys coolers, b5 tips , hybrids all seem to be behind..
    Maybe we're all being a bit slow now with this!
    dusty's Avatar
    Nov 2010
    nw england
    144
    I have a bailey valve at the moment was on the car when i got it the threads in the plastic nipple where the small hose goes to are stripped its loose and I would like to replace my valve for this reason
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Quote Originally Posted by beachbuggy View Post
    you are talking about the TT forum tho..... lol
    it has to be both cheap, and shiney
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2011
    760
    A little update.
    Last night on the way home, coil pack gave the ghost (was trying the tfsi uprade coils)
    Got home just.
    So this morning refitted my old bolt downs and went to pick up my xs manni gasket (wrong one will have to wait till monday now to fit xs)
    Any way i would recommend this valve, you can feel the difference between gear changes and pick up.
    im glad i took plunge, the valve all in all cost me about £100 with reducers and hose.
    Dani does The hole in your valve go all the way through to the internal chamber? or does it just penetrate the first skin?
    This is the only part i didnt understand
    The valve is double skinned where the hole is
    My valve is deffo not shiney lol
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sure mine goes all the way through mate, ill double check and let you know. Got any pucs of your setup? I didnt use reducers, i just fitted a 35mm t piece on my coldside dv kit and Used a 35mm elbow onto the t for opitmal flow lol.
    Aug 2010
    bradford
    1,252
    Ya got pics dan won't mind one ha is it louder than the 007p and feel better or u not had one pal
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill post aome up tomorrow pal, its massive at side of the 008, and yeah i e got one, the soind is awesome compared to the forge ones, nice little flutter chcked in too.
    Oct 2011
    760
    Thanks dani
    Will drill all the way through then. and crush the top.
    Will do picks on monday mate (cars in bits a mo, xs mani being fitted)
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yeah sure it needs drilling all the way, also dont crush the top
    too
    much, only needs doing a littlw.
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Where would i find one of these mad max dv's and would thry suit a non mapped a3 1.8t
    Cheers grant
  1. Mad Max 2
    By Sandra in forum Movies
    Last Post: 6th August 2011, 00:05
  2. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
  3. Diesel Diverter Valves
    By simmolee in forum Diesel forum
    Last Post: 10th April 2003, 17:22
  4. Mad Crash Website
    By Moresauce in forum Other Brands & Models
    Last Post: 14th January 2003, 17:06
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
