Volks AutosMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 75
    Aug 2010
    bradford
    1,252
    turbo turned up today
    got my turbo back today after i sent it to cr and craig rang me few days ago explaining that the bearing was warm and had crack in the hot side so he fix the problems thats so much and it looks new again hot side dont look ryt whats your thoughts thanks.
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Is it a hybrid?
    Its got a cut back turbine wheel, and a bored out wastegate so i assume so?
    What do you think is wrong with it?
    TD5 Land Rover Defender build
    beachbuggy's Avatar
    Surrey
    1,744
    It looks like a copy turbine housing with helicoils fitted.
    Just to clarify not saying anything wrong with it but it's not an original by the looks of it
    Aug 2010
    bradford
    1,252
    that was my imprestion dan u think it will be ok got a years warranty with it.
    the helicoils ok or best putting the normal inserts in pal and does it look like a hybrid thats what i sent hope its what theyve sent back
    Aug 2010
    bradford
    1,252
    do the spec of stuff look ok I.E clipped and ported and so on
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Is that a 2283 wheel? can't tell if its billet or not from the picture...
    <tuffty/>
    Aug 2010
    bradford
    1,252
    Should be same mate told them not to change owt is there away u can tell pic or by eye tuffty
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Thats not a billet wheel that i can see?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    Interesting, copy housing that's been drilled and had helicoils fitted? Could this be down to forums saying 'look for inserts' all the time so they're trying to catch us out? why else would they fit helicoils into a brand new housing....
    Comp wheel doesn't look billet either to me.
    slappy_dunbar's Avatar
    Let's Do This
    Westchester Cty, New York USA
    229
    It's an ETT wheel. No, it's not billet, but that's beside the point. My guess is that it's a 2277-series wheel. The machining to the OEM housing looks minimal.
    Aug 2010
    bradford
    1,252
    well ill be in contact monday and get them to replace the lot not happy robbing t...ts pay £730 for a hybrid to last year and half then say they will fix it and comes back totaly different copy housing and ****ter wheel no thanks im very mad
    Jun 2009
    Leeds
    3,469
    What stage turbo is it?
    only a Stage 3 CR Turbo comes with a billet wheel
    FOR SALE
    Aug 2010
    bradford
    1,252
    they told me it was the top spec andrew carnt get better and i said i dont want a chiness copy but they give me one how **** is that
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Why are people still using CR turbos?! I've seen so many on this forum that are inconsistent and troublesome and yet people still use them! There's other companies out there that can do the work too.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    In fairness... CR typically use 'aftermarket' housings to replace the normally 'shagged' hotsides as to get a proper borg warner housing they normally have to buy a complete new turbo as the housings aren't easily available on their own
    The hotside is not a major issue but if you specced for a billet wheel and not got it then that could be... not like CR to do a switch on purpose though... I'd give them a ring to verify the spec in the first instance...
    <tuffty/>
    Aug 2010
    bradford
    1,252
    I will do tuffty thanks iv got emails from Craig saying its a billet whell or was ha and the total spec and to not recieve that back is really bad
    beachbuggy's Avatar
    Surrey
    1,744
    That is a 2283 billet wheel, I would stick my neck out and say the shot blasted it to clean it, taking off the shine hence why it don't look billet, a common practice by all accounts from a friend in thè industry. Just from the picture I'm sure it's the 2283 billet wheel.
    Aug 2010
    bradford
    1,252
    Thanks so much dan all look sand blasted to be fair but one thing is the inlet blade look very Skiny to me and Dave.
    Iv got pics of the wastage as I opened it up look very big ported about 1" wide more would that be a problem I'll post pics soon as
    Aug 2010
    bradford
    1,252
    pic of the wastgate
    another of the hotside blade and inlet
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    I can see the machining marks in teh last pic of the comp wheel... its a billet...
    Wastegate looks fine... all looks good mate... get it fitted
    <tuffty/>
    beachbuggy's Avatar
    Surrey
    1,744
    One on the right in this picture is the same 2283 compressor.
    Yours looks fine, I'll put a fiver on its the right compressor.
    Have to agree with tuffty, providing they have sorted out previous issues with the hot sides there should be no reason why it's not any good. My only concern is that even a hair line crack is ok on a housing providing it doesn't affect the internals, normally these have gone through 1000s of heat cycles and are pretty solid , where as a new housing is an unknown , yours being new could equally crack or fail, there's no guarantee!
    I am very surprised that cr turbos haven't invested in larger scroll housings, can't cost any more to manufacture and potentially could prove more BHP and less likely hood of surge thus negating the need of clipping the wheel, it's still a bloody big hack in my mind but there we go!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by beachbuggy View Post
    get on it dan!
    beachbuggy's Avatar
    Surrey
    1,744
    get on it dan!
    I'm working on it!
    RIP S3dave
    May 2004
    nr Glos
    7,167
    the turbine wheel clearance looks large... wonder what size feeler gauge would slide in there..
    makes for a slippy wheel, more so given its clipped as well
    stock clearance being 0.4mm as a guage
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Aug 2010
    bradford
    1,252
    Thanks dan and hope this one lasts.
    Tuffty soz for the dislike bloody iPhone pig to use.
    Bill ye there is I lot of space around the whell on the hot side ported too much this course any problems pal
    Let's Do This
    229
    OP
    Send the turbo back. If you paid for a 2283 compressor wheel, they did not deliver the turbo properly. I still believe it is an under-specced wheel. Probably 2277. Maybe 2280. For a 2283 wheel to be incorporated into an OEM K04 compressor housing, the inlet walls need to be machined to a near paper-thin dimension. The outside dimension of that housing is 50mm. The 2283 wheel requires a 46mm hole. Do you think your turbo has a hole that size? Here's another example of a turbo re-manufacturer attempting to stuff that big wheel in such a small housing:
  28. #27
    Aug 2010
    bradford
    1,252
    Hi pal so if the hole of the inlet wheel is not that's size u say it's not the 2283 spec pal thanks
  29. #28
    "Stick a V8 in it!"
    15,370
    Not unless the hole is tapered in some way.
  30. #29
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    CR typically machine the inside of the comp housing to size up to where the locating recess is on the outlet for the OEM TIP... then machine past that to the edge of the inlet... this is to allow extra material where the recess is as this has been known to fractureand the comp housing inlet break off...
    What you should see on yours Gazz is there is a ridge inside the comp inlet adjacent to the recess on the outside...
    <tuffty/>
  31. #30
    Aug 2010
    bradford
    1,252
    ye tuffty i see the ridge mate all way around.
    andrew also come to help deglazz my bores saturday and thats done now showed hime the turbo he said its a billet got the machine marks on it just worrying that on the hot side were they have ported it around the wheel has got 2 to 3 mil gap from the blade will this course a prob.
  32. #31
    beachbuggy's Avatar
    Surrey
    1,744
    2-3mm is quite alot and considering you have a clipped turbine wheel anyway it isn't needed. With the clipping I'd expect to see stock clearance of around .5mm if you run a non clipped wheel then running more gap is needed but certainly not 3mm
  33. #32
    Aug 2010
    bradford
    1,252
    would u send it back dan as its def 2mm no less
  34. #33
    RIP S3dave
    May 2004
    nr Glos
    7,167
    checked how gaz?
    feeler gauge slid in to check?
    www.badger5.biz
    bill@badger5.co.uk
  35. #34
    Westy's Avatar
    Dec 2008
    17,273
    I've never seen so much chat over a turbo! Bolt it on already
    S3 Build Thread
  36. #35
    Jun 2009
    Leeds
    3,469
    It looked about 1.2 mm gap not 3 mm
    That was just a estimate as i didn't have any feeler gauges on me at the time
    FOR SALE
  37. #36
    Aug 2010
    bradford
    1,252
    Thanks Andrew mate and had a chat with a lass from cr turbos today Craig some how knows about the problem
    and wants to pick it up tomoz to sort it only thing I can think of is on here this feed weird tho just want the top spec I payed for guys soz about all this chat
  38. #37
    Aug 2010
    bradford
    1,252
    good news today guys CR turbos rang me and told me that there picking it up coz its the wrong hots side for that turbo great service and thanks so much to craig hes a star will be sorted hehe
  39. #38
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by s3gazz View Post
    You say "great service" Gazz but that's only because you questioned the work they did, otherwise you'd be none the wiser and CR turbos wouldn't have known either
    Glad it's getting sorted though.
    S3 Build Thread
  40. #39
    Aug 2010
    bradford
    1,252
    thanks westy i n owhat u mean but they did do it for nothing in the first place and its not under warranty so how it should come back with the genuin housing and inserts
  41. #40
    RIP S3dave
    May 2004
    nr Glos
    7,167
    its this exact quality issue which worries me about CR...... Inconsistent..
    Perhaps its depends on who is building it as to what they do... which in itself is a worry
    Dissapointing
    www.badger5.biz
    bill@badger5.co.uk
  1. Replacing turbo again today
    By Superpotter80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2011, 21:54
  2. look what turned up today.... Sexy Turbo pics inside
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2011, 09:24
  3. Anyone Turn Up To The Ace Cafe Meet Today?
    By MoAudi1.8T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2011, 03:00
  4. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
