Sky InsuranceChris Nott
Results 1 to 12 of 12
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Check Engine Light after fitting 3" DP and 200 cel cat
    Hi Peeps,
    Just a quick one really, Since fitting my new relentless 3" downpipe and 200 cell cat the check engine light has come on twice now. Both times it has taken a good 50-60 miles before the light has come on. When i scan the car it says catalyst effeciency too low (cant remember exact code).
    Is there anyway to solve this or can someone explain why this is happening as i am using the OEM lambda sensors from the old system so (which were working fine). I have heard it can be coded out but i thought that was only if you were using a decat not a sports cat. Can i code it out myself using VCDS?
    Any help would be appreciated
    Rob
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    beachbuggy's Avatar
    Surrey
    1,746
    You are probably getting the same error as with the decat. Rear O2 sensor either needs to be coded out or you can put a spacer in between the lambda probe and exhaust to raise the señor out of the flow more.
    If you want to test the theory. Remove the rear 02 sensor and put the bung back in, leave the rear sensor plugged in but tuck it out the way securely and then see what happens. .
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Quote Originally Posted by beachbuggy View Post
    Mate thanks for the speedy response
    By a spacer do you mean like a washer or 2? to make it less inside the actual pipe?
    Yeah i can easily remove the sensor and put the bung back in to test the theory.
    When it comes to coding it out is that something i can do myself or is it a proffesional job?
    Mar 2012
    94
    He means a spacer like this:
    42 Draft Designs O2 Sensor Spacer
    My only concern is if it is triggering the fault code will it pass an emissions test?
    Contact admins for advertising
    TT 225 + a bit!!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Ahh cool i see so it need to be spaced out alot then lol.
    I am planning on getting my car mapped with Revo stage 2 in the nearish future once i have done my FMIC. Which i have been informed gets rid of this light too so i may well just wait for that to happen rather than buy the spacer now.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    would this cheapo ebay spacer do the job as for £8 i could afford to buy that for a temp fix.
    OXYGEN LAMBDA O2 SENSOR EXTENDER DECAT SPACER HYDROGEN HHO FUEL CELL | eBay
    Mar 2012
    94
    Just wait and have it mapped out mate, save your money
    TT 225 + a bit!!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Quote Originally Posted by Rich196 View Post
    I take it the light being on isnt a bad thing then and does not effect anything else as its just a warning as such.
    beachbuggy's Avatar
    Surrey
    1,746
    Rear O2 sensor on all cars is just a narrow band sensor. Only good at reading stoich 14.7 . It's there as an extra to adjust fuelling post cat. You won't have any issues removing it and coding it out with mot. If you take it out but leave it plugged in it'll just read 1 the spacer movies it out of the air flow more making it less sensitive.
    Coding out needs to be done via the map and can't be done via vcds. It's literally a 5 minute job.
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    so a faulty post cat O2 sensor will affect the fueling?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Not afaik, its only there to monitor cat efficiency.
    TD5 Land Rover Defender build
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Thanks for the info guys will get it sorted during the upgrade to stage 2 software. But if its not gonna happen for a few weeks i may just put the bung back in but leave it connected until i can as the light on the dash is annoying lol
  1. Resetting check engine light and ln1
    By VuDuStetson in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2008, 12:44
  2. Check engine light & codes
    By pipewerkz in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2005, 16:00
  3. Check Engine Light
    By Bliz35 in forum General Technical / How To
    Last Post: 15th November 2004, 19:39
  4. check engine light
    By imported_mikee111 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2004, 09:51
  5. ECU and check engine light
    By imported_utquattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2004, 20:21
