Sky InsuranceEM Tuning
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    Boost / turbo problem...boost not holding
    its been two days i am trying to solve this problem with no luck yet so here we are...
    lets say on 3rd gear (or pretty much any gear) when i put my foot down and the revs start building to around 4000 rpm the boost goes up to 0.9 bar and then immediatly goes down to 0.4 or 0.5 and stays there till the rest of the rev band.
    I tried the N75 and mbc in parallel and still the same prob. Done a pressure test and tested good.
    The turbo looks in good shape.
    Car have a relentless exhaust manifold and downpipe, 007 DV. AMK engine.
    Do you think a crack in the manifold can cause that problem? Boost holds 0.9 bar for just One second!
    I disconnected the maf and tried again..same result.
    i am out of ideas here...
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    RIP S3dave
    May 2004
    nr Glos
    7,156
    any codes?
    sounds like its dropping into limp, usually associated with a boost deviation
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    any codes?
    No codes.
    My freind is suspecting the green spring of the Forge 007 needs replacing. will try that
    Audi S3 AMK
    Feb 2012
    Pie eating land
    1,341
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    Quote Originally Posted by Chlippo View Post
    No codes.
    Bit of a stab in the dark without scanning it, could a number of things to do with your boost deviation.
    Has it happened over night, or have you changed something before this happened??
    B6 1.9tdi Quattro Avant Sport:
    My Build Thread = http://www.audi-sport.net/vb/a4-a4-c...so-begins.html
    Coming soon: -35mm Springs, Colour coded FOG grills, Trip stalk upgrade.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch,Full Stainless, S4 Brakes, 5m mspacers - front, 10mm spacers rear, MFSW.
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    I am suspecting an error in my N249 bypass, which is leading to a limp mode.
    Audi S3 AMK
    Feb 2012
    Pie eating land
    1,341
    How did you get to the conclusion, have you had it scanned??
  1. Help turbo problem not boosting like it should.
    By Kezzie87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2012, 21:56
  2. Is this the leaky boost pipe problem or not?? Not 100% :/
    By nathan_wilson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2011, 22:11
  3. AGU BOOST/TURBO PROBLEM! HELP REQUIRED ASAP!
    By Dibdub1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2011, 07:41
  4. 2.0 TDi Not Holding Boost
    By APL TDi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2009, 18:24
  5. Not holding boost.....any suggestions
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2007, 21:46
