EM TuningVolks Autos
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: ABS not working
    Apr 2012
    93
    ABS not working
    hi all, i hade my master cylinder changed last week at a grarge, the brakes are loads better, but today i needed to stop quite quick and slammed on the brakes, i dont think the abs cut in as my front wheel nearly locked up, and i dint fell any push back of the peddel, ive scaned with vagcom no faults in abs, does the abs need resetting after changing the m/c? should there be push back off the peddle when barking hard? the brakes feel ok when barkng normal. thanks in advance
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    If it nearly locked up then its most likely working...
    Try braking on a looser surface at a very low speed and see if it kicks in ok... alternatively have a read of the procedures on this page...
    Audi A3/S3 (8L) - Ross-Tech Wiki
    I think the S3 abs pump is an MK60... going to the ABS module in VCDS should tell you which one it is...
    <tuffty/>
    Apr 2012
    93
    HI m8 thanks for reaply, I've just tryed it on loose gravel and the back wheels locked up, so my abs in not working ?, does it just need reset or something ?, thanks in advance .
    UOTE=<tuffty/>;1668605]If it nearly locked up then its most likely working...
    <tuffty/>[/QUOTE]
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Check the procedures in the link I sent you... personally I would take it back to the garage that fitted the MC... its their responsibility to ensure the brakes are working after doing the work they have
    <tuffty/>
    HOTTIGGER likes this.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    If the light comes on and goes back out, it's more likely working tbh. If the light is staying on, it's not working.
    The normal operation of the ABS is designed to be almost transparent .
    JMZ
    JMZ's Avatar
    Aug 2012
    Sunshine Coast, Australia
    12
    bit of a thread revival........I know that my ABS is working BUT I don't know if it's working properly.
    basically I get rapid kick-back through the pedal like any other ABS system however my tyres alternatively lock up/keep rotating rapidly as well. Is this normal for a 2007 8P? I have new tyres on it but everything else is stock.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Quote Originally Posted by JMZ View Post
    This is the 8L section mate... might have better luck asking in 8P....
    <tuffty/>
  1. ABS & Traction Control Light On... ABS Not Working
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2010, 09:32
  2. ABS ESP not working?
    By rraghvani in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2007, 21:12
  3. ABS not working??
    By skooby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2007, 20:08
  4. URGENT - BRAKE LIGHTS NOT WORKING!!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2003, 21:57
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
