Sky InsuranceEM Tuning
Results 1 to 28 of 28
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    520
    Think it's catch can time - where's the bloody can?!
    Hi guys. So, car's done 130k now, and when I replaced the rubber turbo charge pipe (because the OEM one had split) for a forge upgrade, the inside of the old pipe was pretty full of oil. Yes, this may be turbo seals (which I plan to do anyway, and could be attributing to my current 1 liter of oil every 1000 miles even though I've changed the cam cover gasket problem), but I think it's time for a PCV delete and catch-can install.
    So, first thing, get all the equipment together. Second thing, where on earth are you guys finding catch cans with proper 19mm inlet and outlet ports?! I'm starting to feel like an internet idiot now because I can't find any lol!!
    AG205's Avatar
    Mar 2012
    York
    37
    A lot of people (incl. me) go for the Saikou Michi catch cans from the US as they're actually pretty reasonably priced and are a decent quality bit of kit. These come with 19mm outlets if you get the Stage 3 can & cost about £90 incl. shipping from US. There probably are others that use a 19mm outlet and there's no real reason why you need to be tied to this size as hose reducers are readily available.
    I did this install recently and biggest problem I found was finding some decent oil resistant hose that actually liked to be bent! I used clear reinforced PVC hose at first as it's relatively thin walled but found that as soon as the temperatures rise it just becomes really soft and the hose just starts to collapse in on itself at bends. Using proper thick walled oil hose at the moment but it's a tw*t to fit in and refuses to bend. Still on the look out for a decent alternative!
    2001 Audi S3 AMK Nogaro Blue - Eibach Pro Street coilovers, Stage 2 remap,
    Milltek Resonated + Hi Flow cats, Badger TIP, now catch tank'd and de-cluttered
    1993 Renault Clio 1.8 16V in Black (frilly arched project car)
    1991 BMW E30 318i with 325i Sport engine in Red (owes me big money)
    AG205's Avatar
    Mar 2012
    York
    37
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    149
    hi,
    i got my oil grade hose from Roose Motorsport in Lincoln and they are pretty Damn Good even the postage cost and Time was brill and they do it in different colours too if needed.
    Give them a try.
    Olly
    Feb 2012
    Surrey
    520
    Thanks guys,
    Reason for a proper 19mm inlet/outlet is to ensure the largest bore i can get - reducers effectively restrict the flow which I would like to avoid if possible
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    149
    i got 19mm oil grade from them for my Saikou Michi Catch Can, i got 2m which came to £61 ish due to it beikn Fluoro Lined oil grade hose.
    Feb 2012
    Surrey
    520
    This stuff doesn't look bad for the hose: OIL SUCTION DELIVERY NITRILE RUBBER HOSE 1 MTR 19mm 3 4
    S3_Olly's Avatar
    Full Throttle
    Jul 2011
    Aston, Sheffield
    149
    that look good mate, i only got mine from there as i wanted to be a fancy pants and match the rest of my engne bay with the red hose lol.
    but yes that looks like it will do the job.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    I fitted a Saiko Michi can a year or so ago as part of the group buy that was on here.The 19mm hose we used was pretty inflexible, but was fine for the runs required. The can is installled on the bulkhead, behind the tip. I'll post a link to a separate thread with a pic of my engine bay in a minute...
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Found it. This is my B5 TIP Instal thread, but you can see the catch can in the pics:
    B5 TIP Fitted - with pics
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,707
    Its in the stickies mate here's the link.
    Guide - How to fit a catch can and simplify the PCV system
    Chris.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    I would show you my Catch Can build but Dr OCD Paul up there ^ would get upset when he see's how dirty his bay is compared to mine haha
    Feb 2012
    Surrey
    520
    cool, thanks guys. yeah, saw the sticky, anyone with an APY engine done this? I assume it's exactly the same
    AG205's Avatar
    Mar 2012
    York
    37
    S3_Olly - Have you got a pic of the oil hose you used fitted? I've been thinking about getting some fluoro-whatever coated silicone hose to do the job for a while but is generally quite expensive.
    Squirrel.O.D. - That stuff you linked to looks decent and a bend radius of 70mm seems pretty good, might look at that as an alternative. As it happens space is tight on the S3 so fitting in hose reducers is a bit of a waste of space but I don't think using a smaller dia. would make a big difference on a road car and majority of aftermarket catch cans for cars with much bigger engines and higher bhp use smaller dia. plumbing.
    I found that the bulkhead fitting position was too cramped and as long as the inlet of the catch can is no lower than the cam cover breather then it doesn't really matter where you fit it.
    Feb 2012
    Surrey
    520
    Feb 2012
    bedfordshire
    735
    Quote Originally Posted by Squirrelofdoom View Post
    I fitted one of these to mine a few weeks ago good quality can
    Feb 2012
    Surrey
    520
    cool, thanks dre
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,892
    you could always buy one of the cheap ebay ones put some wire wool in it and make some 19mm out lets, that what i did. and that way you get to play with tools and make a mess :D
    Feb 2012
    Surrey
    520
    could do coatesy, but those ones don't have a 19mm bore throughout the ports, therefor even is for make 19mm connections, the flow is restricted any by the rest of the can
    coatesy's Avatar
    Oct 2010
    1,892
    i think the threaded holes are about an inch each don't hold me to that though, infact don't buy one and do what i said until iv 100% finished mine lol as it might not work now you have said that
    sambryant's Avatar
    seat leon cupra r owner
    May 2011
    bristol
    152
    I just got this can from 42draft designs in the states. 19mm ports, baffled, dipstick. The quality of the finish is second to none.
    BADGER 5 TUNED gt2871, 360bhp 360ftlb
    sambryant's Avatar
    May 2011
    bristol
    152
    Before this can I ran a toyo can with 15mm inlets, never had a issues and made 285bhp at bills so I don't think the engine was struggling to breath.
    I then got a custom can made with 19mm ports, great can but did lack the bling factor hence the reason for the 42 draft can
    I run all my cans to atmosphere.
    coatesy's Avatar
    Oct 2010
    1,892
    that can is awesome
    Feb 2012
    Surrey
    520
    cost for the 42 draft can?
    coatesy's Avatar
    Oct 2010
    1,892
    Feb 2012
    Surrey
    520
    yeah, i meant cost for the custom one
  28. #27
    Nov 2011
    pboro
    185
    the catch can above posted by sam i found online for 235 dollars
    42 Draft Designs
  29. #28
    Feb 2012
    Surrey
    520
    Now I look at it, that previous hose is only rated to 55 degrees celcius, not enough for under bonnet. How about this stuff?
    Rubber Marine Fuel, Diesel & Oil Hose - 19mm ID AP Motor Store
  1. oil catch can fitted diffrenty to the norm??
    By frank s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 06:34
  2. Where is the catch...
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2008, 14:05
  3. where does the factory sub plug in in my a3??? RACKING MY BRAIN BIG TIME
    By samthomas33 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2008, 11:34
  4. Anyone know where you can get these in the UK?
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2005, 16:21
  5. Where in the UK Can I Buy H&R Coilovers?
    By XXX_18T in forum General Chat
    Last Post: 14th November 2003, 10:29
