AH FabricationsVolks Autos
    Mar 2011
    Argyll, Scotland
    69
    Cold start problems
    Hi, need some help. My s3 has recently having trouble getting started when the engine is cold. Starts first time when warm. Takes a good few turns of the key. There will be nothing at first, then it will get better and want to start but cut out, then it will start and rough idle for a pretty short time, give it a few revs and drive of and it runs great.
    things to note: it has just got a new oem maf, it has recently got a dp and decat.
    Any info would be great cheers.
    AG205's Avatar
    Mar 2012
    York
    37
    Personally, I'd start by getting it fault code read or scanned on VCDS even better, to see if it chucks out any codes so you have a place to start.
    Otherwise would probably start looking at the coolant temp sensor as that controls air/fuel ratio on cold start until management goes into closed loop using the O2 sensor.
    2001 Audi S3 AMK Nogaro Blue - Eibach Pro Street coilovers, Stage 2 remap,
    Milltek Resonated + Hi Flow cats, Badger TIP, now catch tank'd and de-cluttered
    1993 Renault Clio 1.8 16V in Black (frilly arched project car)
    1991 BMW E30 318i with 325i Sport engine in Red (owes me big money)
    Mar 2011
    Argyll, Scotland
    69
    Its came up fault code 17704, am i right in thinking its the coolant temp sensor?
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    The Ross Tech wiki is your friend....
    17704/P1296/004758 - Ross-Tech Wiki
    I would have suggested the coolant temp sensor also for poor cold start - looks like the fault code confirms.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Mar 2011
    Argyll, Scotland
    69
    Thanks for replys, i have ordered one. So will let people know if it solves the problem for future referance.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by krisrg87 View Post
    Should do. Make sure you do it when the engine is cold - else hot coolant WILL go everywhere, including over you.
    Homer Simpson
  1. A4 2.5tdi cold starting problem
    By Quattro john in forum Diesel forum
    Last Post: 26th July 2009, 13:09
  2. A3 1.8TQS Extreme cold Starting problem
    By Broken Byzan in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2009, 17:41
  3. S3 Cold Start Problem
    By squale in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2008, 01:15
  4. Cold start problem
    By C Mesher in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2007, 15:24
  5. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
