Volks AutosAH Fabrications
Results 1 to 8 of 8
    Aug 2012
    Glasgow
    11
    Exclamation Help Identifying a Hose (and where to get a replacement)
    Hi Guys
    Had an air leak with the S3 today - now identified it as this hose
    Can anyone tell me a name for this ? or where i can order a replacement
    Thanks in advance
    R
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    The part number will be on the hose itself and you can get from Audi. I think forge do a "upgraded" one that does not brake down so easily. It's a important pipe as that vacume is part braking system. It also causes leaks in the PCV system. Pretty common!
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by RossB View Post
    I had part of that assembly go on my S3 (AMK).
    I don't think Audi sell that part on it's own. But as mentioned you can buy a silicon one from Forge.
    You will probably find that many of the hoses and tubes are on their way out.
    I got a replacement part 06A 133 789 - you can see it on top of my manifold - which includes that part you're after. It cost £62 from TPS for that.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Feb 2012
    bedfordshire
    735
    Better of getting rid of all them pipes and putting an oil catch can on the car for all the money spent on hoses
    have a read on the forum loads of info easy job to
    Dre
    Chugger
    North Devon
    2,716
    Hi ross, it's cheaper to go with the forge replacements. But as said overall you will be better off fitting a catch tank as other hoses will go
    57 A3 2.0 TDI Sportback (140)
    Aug 2012
    Glasgow
    11
    Dre is there any how to guides etc ?
    Surely the hose in question is a vacuum hose tho ? and not an oil pipe ?
    Please excuse the layman questions not very good with Audi's ...Yet !! haha
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    That looks to be parts of the PCV system - as said above. That stands for Positive Crankcase Ventilation. Basically, it's relieving pressure inside the crank case from gas creeping past the rings. Mainly that pipe will carry air, oil and oil vapour.
    If part of the PCV, it's not a vac hose. I can't really tell from the photo - and am not that familliar with the AMK/BAM setup.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Wait for Tufty to appear with his pic in a while
  1. A6 Avant - rear tail gate brake light (highmount)....where to get a replacement.
    By tullA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th September 2011, 22:02
  2. Replies: 3
    Last Post: 22nd June 2011, 18:44
  3. Replies: 6
    Last Post: 8th April 2008, 12:36
  4. Where to get the chrome windows surround, and how much?
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2005, 23:12
  5. Where to get and what type of replacement shocks?
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2004, 13:46
