Chris NottMonster Motorsport
Results 1 to 13 of 13
    Apr 2012
    Surrey
    23
    A little help for a noob.
    Hey all. Ive done so well at not having to ask anything but I have been unable to find what I'm stuck on.
    I bought a jetex cone filter and I'm unsure what to do with two bits of hosing. I was wondering if anyone could help me out as I don't want to attach the two then find out I shouldn't have etc etc.
    So I have a hose coming from the car (the one not going anywhere) and then the silver looking one coming off the filter itself.
    Any help I would greatly appreciate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Thats the secondary air injection inlet... you should fit a small filter to it really or do the SAI delete (links in the stickies...)
    <tuffty/>
    Apr 2012
    Surrey
    23
    Ok. Thank you.
    Apr 2012
    Surrey
    23
    Another question, installed that all fine, however my diverter valve now seems to be making a dumping noise when I take my foot off the accelerator. I had a look it all seems attached and the hoses are all ok. Is it dying or could something else cause this? I presume something is up as its always been quiet.
    Also coilovers now fitted and I have the driveshaft rubbing problem. I was reading a thread about replacing the arb with an s3 or tt arb. This would solve my problem? I don't have the money now to buy a better one, so it would just be so I can drive my car.
    thanks if anyone can help.
    Apr 2012
    Surrey
    23
    I'm sorry to post again, but can no one help? I just want some advice before I go to a garage and get conned. It's happened too many times.
    Sep 2005
    Derbyshire
    180
    The DV noise is normal as you have fitted an Open Filter.
    I can't help with your other problem however. Unless shorter drop links would work?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    oh the DVa noise id strip the turbo and check all seals.
    Apr 2012
    Surrey
    23
    Ok, I'm not mechanically minded, so I suppose I will have to go get it checked as two different views.
    Anyone know what the lowest you can go without the arb hitting the driveshaft? I read so much but there doesn't seem to be one cure that works for everyone.
    Thanks.
    James TQ's Avatar
    Apr 2012
    Essex
    548
    He was joking fella it's normal!
    Apr 2012
    Surrey
    23
    Oh, hence the little joker, haha. I'm a girl, forgive me :-p
    Thank you.
    Chugger
    North Devon
    2,716
    Well if you want to really drop it, you need to be looking at other arbs, like neuspeed. Or you could just get the coil overs adjusted, I think the max is about 40mm before you have driveshaft fouling?
    As long as it isnt fluttering, the dv noise is normal after fitting a cone filter.
    57 A3 2.0 TDI Sportback (140)
    Apr 2012
    Surrey
    23
    Yeh, I want it low. I read that standard is 19mm? So I would need one the same size as that? I see them at 25mm etc.
    How about...FK 23mm Front Anti Roll Bar A3 8L 1.6, 1.8, 1.8T, 1.9TDi FWD 08/96> - £115.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts for all VAG vehi
    simply cos it is cheap, I wasn't planning on doing my arb quite yet so it wouldn't be forever.
    Ok, it just is loud, but only from inside the car.
    S3 Paul's Avatar
    Oct 2006
    2,764
    The DV will seem louder ,
    Nothing to worry about there.
    Anti roll bar wise... ive only ever fitted one. That was a white line item from awesome gti,
    Some people dont like them but it worked fine,
    Noggy Blue 2001 S3
  1. A little Audio help for OEM Sub and Amp wiring
    By 4NT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2012, 20:46
  2. Help for an Audi noob
    By Squirrel in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2010, 12:12
  3. Help for my dad
    By Neal_A3T in forum General Chat
    Last Post: 27th November 2004, 09:12
  4. Your help for a newbie please
    By domcj in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2003, 15:42
  5. H&R Coilovers... Please help for the S3
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 06:28
