Volks AutosEM Tuning
Results 1 to 17 of 17
    Aug 2012
    Essex
    A3 TQS GT28rs anyone done it
    I want to get a bigger turbo but for the money a ko4 just doesn't seem enough of a gain for how much it's going to cost.
    i have a ko3s is it a straight bolt on - off to switch to a gt28rs
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    No, you need to change all the same parts as you would for a K04, but using Garrett specific components.
    IE manifold, downpipe, coolant and oil lines, TIP, charge pipes.
    TD5 Land Rover Defender build
    Aug 2012
    Essex
    Thanks for the info, I was looking on eBay for one but they only had ones for the fwd not the Quattro. Looks like I'm gonna have to give them a call to get all the parts I'm gonna need.
    Would it be sensible to put the turbo on first (with low boost) then start upgrading the internals as and when I get the money or put the turbo on last
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    You will still need injectors and a custom map too...
    <tuffty/>
    Aug 2012
    Essex
    <tuffty/>
    I was thinking 550cc they should be ok for 300bhp
    i also saw a gt28 that uses the standard manifold and down pipe that's why I thought it would go straight on
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    550's, S3 maf tube and a suitable inlet pipe too...
    That turbo 'kit' is typically 'bolt' on in that respect but there are supporting mods required to make it all work without nuking your engine..
    On a build like this I would be doing the rods too
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    Quote Originally Posted by 69rush69 View Post
    that'll be an eliminator then.
    expect it to spool ~4krpm
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Aug 2012
    Essex
    Then I won't be getting that lol.
    I basically need this don't I , or at least all that's on that list.
    APR Stage III Kit - MkIV VW and Audi - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
    Aug 2012
    Essex
    <tuffty/>
    The standard rods are good till 280 I think I read it on here somewhere but I don't plan to get that much power out of it till at least Christmas then I can ask Santa for them.
    brasiliangringo's Avatar
    Mar 2010
    496
    Buy an s3 and tweak, sounds cheaper !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    Ignore anything about what power rods are good too mate as at the age of the engines its too subjective... I have seen rods bend on std power and stage 2 power so power at this stage of the engines life is irrelevant... and its torque (cylinder pressure to be precise) that bends rods not power...
    The rods can bend at any stage of tune these days due to wear and tear hence recommending them... Prawn has managed to make his std rods last on his 200k miles engine but he is very aware of what could happen...
    Obviously its your call and you know how you drive and can have the engine mapped to calm down the onset of massive amounts of boost and timing advance to minimise the risk but tbh you would be silly to ignore changing the rods sooner rather than later..
    <tuffty/>
    Aug 2012
    Essex
    That's a good point I like to think I wouldnt give it some but I probably will lol, is there any you could recommend.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    IE or Brute as long as they are rifle drilled... Bill keeps drilled IE's in stock...
    <tuffty/>
    Aug 2012
    Essex
    <tuffty/>
    Thanks for that will be giving him a call in the next few days. is it an easy job to change them myself or would it be better to take it somewhere.
    "Stick a V8 in it!"
    14,900
    Well it effectively involves rebuilding the engine. Only you know your level of skill as to wether it could be described as easy or not.
    Aug 2012
    Essex
    I took an old game boy apart once, never got it working again lol so looks like that is a no no.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
  1. Has anyone done their IQ test?
    By Soupie69uk in forum General Chat
    Last Post: 10th February 2005, 14:06
  2. Strut Brace for the A3 - has anyone done this mod?
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 20:36
  3. Anyone done the N249 mod to their S3 ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2005, 18:54
  4. 1.8T 180hp Remap - Anyone done it?
    By IanWood in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:29
  5. shark ariel, anyone done it?
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2004, 12:54
