Badger5Monster Motorsport
Results 1 to 7 of 7
    Aug 2012
    newport
    13
    S3 misfire, help!
    Just jumped in my car (2002 S3 BAM) and its misfiring like mad, I'm thinking coil pack but is there any way of checking this? I've got no engine management light on and I plugged my diagnostic reader in and no fault codes, the car was fine on my way hole
    from work last night, any help would be appreciated, thanks
    Greg-S3's Avatar
    Aug 2012
    Northampton
    281
    With the car running, Unplug the coil packs one at a time, the car should cut out until you get to the misfiring one in which case I should make no difference!
    Aug 2012
    newport
    13
    Nice 1, just did that and number 4 is dead, cheers
    Greg-S3's Avatar
    Aug 2012
    Northampton
    281
    Get your self a coil pack and a set of plugs dude!
    Aug 2012
    newport
    13
    Do u know the part number for the coil pack?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,462
    You can unplug the injectors one at a time... this is easier than trying to unplug a coil pack due to all the stuff thats normally on top of them especially on an S3... they are joined together but you can ping one at a time to listen for engine note change... if the note doesn't change then thats the offending one
    <tuffty/>
    Greg-S3's Avatar
    Aug 2012
    Northampton
    281
    Think it 058 905 105 but I'd check with a dealer to be sure! Might be worth checking with an Audi dealer as they ha a recall on the coil packs so if your is in the effected vin range and it's not been done you may get it done for free!!
  1. Injector misfire help K04
    By Uber-A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2013, 05:13
  2. running on 3 cylinders/ misfire. help needed :(
    By xCoupexAshx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2011, 20:03
  3. Cant work out why its misfiring HELP
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2011, 19:04
  4. misfire HELP!!
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2009, 09:34
  5. Misfire Help!!
    By Sohrob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2009, 02:25
