AH FabricationsBadger5
Results 1 to 7 of 7
    Aug 2012
    Devon
    Airbag light on after Service, seat was moved is this the dreaded broken wire connect
    Hello, recently had the s3 serviced and the mechanic is a midget, the driver seat was moved and now the airbag light is on! Any thoughts? Is this a coincidence or is it true that there is common problem with the air bag light connectors being disjointed under the front seats? Anyone had any experiences with this?
    Thanks very much in advance for replies.
    J
    brasiliangringo's Avatar
    Mar 2010
    538
    Most likely nothing to worry about and probably the connector / wires under the seat but you will need to clear the code before the dash light goes out, if it persists cut and crimp the wires or solder (ie remove the block connecter).
    Aug 2012
    Devon
    Thanks very much for the quick informed reply, I'll try and sort it next week end, will any of this prevet the airbags from firing though and once reset and reconnected will they all work fine? Thanks for your help in advance
    J
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Quote Originally Posted by MJtheGOAT View Post
    J
    If the airbag light is on, there's basically a fault, and non of it is active. If it's off, then all is well and should operate as intended.
    Get your car scanned first, I'm sure your mechanic will help you out, it will tell you exactly why your airbag light is on! Main culprit is the block connectors under the seats, all you need to do is take them apart, spray some WD40/electrical contact cleaner, refit and reset the light. Usually clears the problem in 95% of cases.
    Mar 2010
    538
    In such an instance where the side airbags are inactive (because of bad wiring) or any other airbag, all other airbags will still function in the event of an accident, so dont worry.
    Chugger
    North Devon
    2,716
    i had the same problem on my previous s3... ended up cutting the connector off and soldering the wires together, only problem doing this is it creates a bit more work if you ever need to remove the seats, but i didn't mind that.
    obviously don't start hacking things without scanning it first
    57 A3 2.0 TDI Sportback (140)
    Aug 2012
    Devon
    Quote Originally Posted by sportstractor View Post
    Thanks very much for all the help fellas! Will post how it go's fixing it.
  1. S3 Seats in A3 - Airbag Light - Solved at last
    By FactionOne in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2014, 13:46
  2. Airbag light - Passenger seat replacement
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2013, 23:01
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. S3 Airbag light/seat help
    By TanyaS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2007, 15:21
  5. Airbag light after glovebox removal
    By Roswell in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2006, 14:12
