Sky InsuranceVolks Autos
Results 1 to 8 of 8
    imported_monkeytrousers
    Smell from windscreen washer
    Hi
    When I use my windscreen washer I am getting an eggy / sulphur smell in the car.
    I suspect there is algae or bacteria in the washer tank.
    Anyone else had this and have any tips for getting rid of the stink?
    Jun 2003
    World of my own
    9,813
    Re: Smell from windscreen washer
    Are you sure it's not the aircon?
    Yes, it's definitely the windscreen washer, when I squirt the screen it smells like a stink bomb!
    I'm sure I read something about this somewhere.
    imported_jamesgraham
    You could try draining the bottle completely,then add some baby bottle steriliser solution ,or a mild bleach .Leave it in for a couple of hours then flush it out .I had the same problem with a previous car. Ithink its when you start using diferent windscreen wash mixes.
    Oct 2005
    Windsor
    39
    funnily enough my dad is getting this in his car but its just a constant smell even when u get in u can notice it..its only done 10K and he's had it from new so its not as if an old person has pee'd on the carpets or seats. its really pongy and eggy whatever it is... i was just worried the aircon could be leaking something dangerous into the car?
    Jun 2003
    World of my own
    9,813
    If he turns the aircon/cc off in the winter (which you're not supposed to do) then it will be a bacteria build up in the pipes. You can get some anti-bacterial spray to get rid of it.
    Climate control is designed to be on all year round, presumably it's still under warranty (unless he's only does 3k miles/year).
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Open the bottle and have a good smell. That'll tell you if it's off the windscreen washer.
    Oh and I had a similar problem (not a bad smell) but I noticed there was a residual biuld up on the walls of the washer.
    Cleaned it and it's sorted.
    hopper's Avatar
    Jan 2005
    stoke-on-trent
    122
    normally you get this smell wen just topping the washers up with water, it goes stale and does smell over time.
    empty the bottle and give it a good rinse, then make sure you put plenty of screenwash in, and keep topping it up with a mixture instead of just water
