Monster MotorsportVolks Autos
Results 1 to 16 of 16
    Feb 2012
    bedfordshire
    749
    Do Audi sale Replacement coil pack harnesses
    finally found my problem with the car holding back me thinks
    do audi sell these harnsses in one or separate, im also im crap with electrics is it hard job ? is it cut and join or will it go straight to the ecu ?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    319
    Ring Milton Keynes TPS on 01908 625000 and ask for Mat, he is a very knowledgable bloke he will know all about if you can get sections etc and if comes as one piece and so on mate. Hope that helps!
    Or maybe try a auto electrician as they may be able to repair the damaged loom and make a good job of removing the plug and re joining the wires and plugs etc! Hope that helps
    Jun 2012
    57
    Awesome gti sells them
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    if you have a level sensor in the sump then you need 1J0 971658 M the loom wires differ in colour but if your careful you should have a problem
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Audi do sell looms but they are generic ones from all the ones I have seen... they are more like a3 looms than s3 ones... I fitted one to mine recently and just cut the wires and soldered the new ones on.... here is the bit in my build thread...
    My minor modding thread
    It not a comprehensive guide but you get the idea... I didn't buy the loom with the sensor as all I wanted to change was the coil pack part... worked out a bit cheaper that way...
    <tuffty/>
    Feb 2012
    bedfordshire
    749
    How much was the harness mate and what was the part number Tuffty
    cheers mate
    Dre
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Part number should be the one Andrew posted earlier and was around 20-30 quid... can't remember the exact price as I get trade from TPS anyway but budget for that..
    <tuffty/>
    Feb 2012
    bedfordshire
    749
    <tuffty/>
    Ok mate just been up TPS to get my clutch pedal and there have ordered me a harness it was around £30 so hopefully get it within the week thanks for your help
    Feb 2012
    bedfordshire
    749
    Anyone know what the harness from awsome gti is like? it goes straight to the ecu but can it be cut ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Quote Originally Posted by dre_S3 View Post
    I would imagine its the same as the OEM mate... if its a wire it can be cut ;P
    The OEM one is supposed to go to the ECU too...
    <tuffty/>
    Feb 2012
    bedfordshire
    749
    Ok thanks Tuffty May just order it from them as tps have to get it from Germany could be up 2 weeks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    !!! they must have run out then... fairly typical though...
    <tuffty/>
    Feb 2012
    bedfordshire
    749
    Yeah just ordered one from awsome just need to get someone to fit it as my soldering skills are not that good lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Make sure its a fairly powerful soldering iron for the thicker power cables else you will get bad resistive joints causing other issues...
    <tuffty/>
    Feb 2012
    bedfordshire
    749
    Yeah think I will let a pro at it, can't be dealing with more problems if I muck it up
    AG205's Avatar
    Mar 2012
    York
    37
    Did mine recently, lopped out the cracked wiring as far back as needed and just spliced the new coil connectors/earth in via soldered and heatshrunk joints. Just did one wire at a time to make sure everything went back in the same place and jobs-a-good'un. I used the loom from Awesome GTi (ECS Tuning sourced) and it arrived in a proper VAG box which was reassuring although it's certainly not plug and play on the S3 unfortunately.
    All my coil connectors where broken and the thicker wires were cracked pretty badly so definitely needed doing.
    2001 Audi S3 AMK Nogaro Blue - Eibach Pro Street coilovers, Stage 2 remap,
    Milltek Resonated + Hi Flow cats, Badger TIP, now catch tank'd and de-cluttered
    1993 Renault Clio 1.8 16V in Black (frilly arched project car)
    1991 BMW E30 318i with 325i Sport engine in Red (owes me big money)
  1. Audi Coil pack wiring harness **NEW**
    By SiGainey in forum For Sale/Wanted - Audi Parts
    Last Post: 30th April 2012, 21:37
  2. audi 2.0t coil packs
    By sewell10 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd March 2012, 14:14
  3. Free coil pack replacement from Audi
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2012, 16:05
  4. Coil Pack replacement at Bristol Audi
    By Audi-do-dat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2009, 09:13
  5. audi warranty on coil packs?
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2006, 15:47
