Chris NottVolks Autos
Thread: Speedometer
    Aug 2012
    47
    Speedometer
    Hello everyone, I have an Audi A3 2001,AUQ 8L.
    initially it was an Automatic transmission, but for some reason, it was changed to manual trans, now the problem is the speedometer won't work. Now am thinking maybe the wiring was messed during the change over.I need someone who has the same car to help me with the color code or someone help me kindly point me to a solution.
    maybe just so u know I used VAG & tested my instrument cluster & all niddles rise OK, we also changed the speedo sensors but all in vain. Any help will be highly appreciated.
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    hello.
    Im not 100% but arent automatic and manual instument clusters different? And again im not 100% but doesnt the speedo for an auto pick up its signal from the gearbox ecu?
    Aug 2012
    47
    Speedometer
    Do scare me, I thought of that but didn't want to believe it, mostly the fact that it could be getting the speed from the Trans computer. But what are the color codes? Maybe there is a bypass.
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    i dont think there would be a bypass mate, you may need new clocks and id say the wiring loom is different. You could always wire in your own speedo using a digital unit?
  1. need help speedometer,blower fan control switch
    By audi-90qua in forum General Technical / How To
    Last Post: 27th October 2007, 16:53
  2. need help speedometer
    Last Post: 26th October 2007, 14:55
  3. Speedometer went dead.
    By maciekm in forum Classic Audi Forum
    Last Post: 4th July 2006, 20:11
  4. Speedometer
    By NEiLS3LK51 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2004, 10:55
  5. My speed on speedometer is wrong:
    By tennisguy in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2004, 09:36
