Volks AutosChris Nott
Results 1 to 10 of 10
    Aug 2012
    Newcastle
    Problems with staggered wheels on S3 8l
    Hi all, this is my first post so please be patient
    I recently bought some 17" Brock b2 splits for my S3, they are 10JJ rear and 8.5J up front, both ET25
    I needed 10mm spacers&amp to get the rears to clear the springs & shocks (they are still awfully close), but now the rim is poking outside the arch. The rears are running 245/35/17 and the front are 215/40/17 both streched to hell. I am awaiting the delivery of some coilovers as the car currently looks like a tractor with 17s with low profiles, but the last thing i want to happen is for the rims to smack of the wings if i hit a bump, so what are my options? I've heard of rolling arches but how much work is needed for this and is it recommended?
    The other possibly bigger problem is the noise!!! While on first run out on them the noise was terrible, it was that bad I though I hadn't tightened the rear wheel bolts properly, but when checked they were tight. I took it to a local tyre garage to have the balance checked, but upon them driving the car to the rear of the building to access the ramp, they came to the conclusion that the noise was solely down to the tyres and the stretch of them. The Veteran of the garage then told me that the tyres were far too small for the rim and that the difference in rolling circumference of the front to rears could do some serious damage to the Quattro system. He said the stretch was really dangerous and that the tyre could actually pop off the rim when turning.
    He also tried to educate me in tyre sizes, but he just confused the hell out of me, i thought that in 245/35/17 the 1st figure was width and the 2nd was height of tyre, but he was saying that theres more to it and its all about the aspect of the tyre so mine were close but not precise match and as such could cause major problems.
    Sooo where do I stand? I've searched google and other people have even narrower 225/40/17 on 10j so why are mine so bad?
    Is the Vet just stuck in his old ways and doesn't like the stance of stretch? and is anyone in the know of what tyres would be the perfect match in rolling circumference between the front and rears?
    Many thanks in advance for any responses
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,389
    When it comes to wheels, tyres and off sets user N8 is who you need to speak too. His details are in the sponors section at the bottom of the main forum page. Welcome to audi-sport.net. x
    Kowalski Details
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Feb 2006
    Lincolnshire
    692
    From the details you've given, the front wheel tyre circumference is 1896.9mm, and the rear 1895.3mm. 1.6mm circumference (or 0.5mm diameter) is not going to cause your quattro system any problems.
    If you're wheels are actually poking outside of the arches, then there's not a lot you can do, even with rolling. If the suspension was stiff enough, then I guess there may be no tyre/arch contact, but depends if you can stand the look.
    If the tyres are too stretched, then yes, they may pop off the rim or deflate. I've no experience with what size would be right though.
    Re tyre sizes, the second number is the aspect ratio. So, a 225/45/17 tyre has a sidewall 45% of the width of the tyre. So, it is the height, but not a direct measurement in mm etc.
    Audi S3 - 2002MY - Denim Blue
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Incase you don't already know, but if your tyre protrudes beyond the edge of the wing PC Plod won't be very happy with you.
    As Tooks says, the second figure is a % of the width. So a hypothetical 100/35/17 tyre would have a sidewall height of 35mm. A 200/35/17 would have a sidewall height of 70mm etc. That's why the wider a tyre gets, the smaller the ratio number is otherwise you end up with tractor style tyres with huge sidewalls.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    i heard staggered wheels are a no no on a Quattro..
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,884
    Quote Originally Posted by s3clarke View Post
    It's not a nono, more of a not recommended! Really depends on application. I like my S3 to handle, and go on track occasionally, so wider rears and stretched tyres don't appeal to me, but they can look good if done properly!
    You've got to have a laugh!
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    so say 8j fronts, 9j rears would be ok if fitted with the correct tyres? was looking at some porsche wheels which were stagered not long ago but was put off from people's opinions.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,884
    Yes, the Haldex has a 5% rotational difference factor built in to account for tyre wear. So long as you get the rotational difference to within 2% lets say, I can see no problem. The only thing I have against wider rear tyres is the effect it has on handling. The S3 is very understeer biased, basically not enough grip up front and plenty at the back. Wider rear tyres will just effect your turn in when cornering at low speed. It will more than likely increase your turning circle basically.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,113
    You can run staggered wheels just need to keep the rolling radius right
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,177
    I have staggered rims on my S3, with slight stretch on the rear tyres. Mounted tyre diameter is about 1cm different front to rear, on a total diameter of about 62cm.
    62cm diameter = 194.8cm circumference.
    63cm diameter = 197.9cm circumference.
    So, 3cm difference in circumference = approx 1.5% difference front to rear. No Haldex problems.
  1. Problem with changing wheel size.
    By stimpy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2010, 10:39
  2. Help with tyre sizes for staggered wheels!!
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2009, 00:39
  3. Problems with Revo
    By RSAudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2003, 13:48
  4. Problem with alarm
    By tim in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:58
  5. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
Tags for this Thread
