You may not need a new gasket but your pretty much f-ed if your current one breaks....
Use some carb cleaner to clean th throttle body.last time I had my cleaned I just disconnected the negative side of the battery for about half hour and it has been fine since.either that sorted it or I put it back in exactly the same place lol
I bought a new gasket just for the sake of it as the one on there will more then definitely be the original one. You may not need to re-align your TB after the clean.
Also from my experience, the TB will just get dirty again if you still have the original PCV oil system fed back into the TIP so keep an eye on it and see how quickly it gets dirty again.
