EM TuningVolks Autos
Page 9 of 9 FirstFirst ... 23456789
Results 321 to 336 of 336
Like Tree127Likes
Thread: s3gazz's slow engine build
  1. #321
    RIP S3dave
    May 2004
    nr Glos
    7,185
    Reading the post he suggests that it doesnt actually hold 11?
    Even if the preload was weak, you'd surely expect consistently low boost, not fluctuations?
    I've read it a few times and abandoned understanding what went on.. Cant make head nor tale tbh
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  3. #322
    Aug 2010
    bradford
    1,252
    Thx guys very interesting all this dan the actuater rod with the 15 psi actuater u sent is longer this time and has plenty of room for preload lol not like the other so I'll add quite a bit and see what happens also get a picture of the rod for u
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  4. #323
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    It holds 11. It didn't hold 11 in limp mode as it is throttled.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  5. #324
    RIP S3dave
    May 2004
    nr Glos
    7,185
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    that makes more sense. Ta << Northen Saying I believe
    For me 11psi on actuator would hold >20psi at 7krpm on the hybrids without maxing the duty cycles..
    I usually aim for minimum 12psi-15psi actuator pressure on a k04 hybrid.... exhaust manifold back pressure is very high when pushing on.
    www.badger5.biz
    bill@badger5.co.uk
  6. #325
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    No thats just Gazz
    badger5 likes this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  7. #326
    Jan 2012
    Stockport, Cheshire
    748
    I'd expect that too but this one won't, probably a back pressure issue as you say.
    Rick
  8. #327
    RIP S3dave
    May 2004
    nr Glos
    7,185
    Rick
    yep, combined with the smaller than OE wastegate arm, as I posted the lever ratios earlier in this thread.. Effectively down rates the actuators psi rating. doh!
    www.badger5.biz
    bill@badger5.co.uk
  9. #328
    Aug 2010
    bradford
    1,252
    So as all this is said I'm thinking of taking the turbo off sometime in January, February and see what the issue is if it comes to it I'll be getting genuine k04 hot side and ask dan if he could put it together for me then I no that's out the way does it fix my problem hopefully.
    back pressure wise can only be the hotside as iv done everything I can so make it better flowing most people won't of ported the downpipe but I have to help get rid of more back pressure and we now no from bills tuning last week the v3 does flow.
  10. #329
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Perhaps look into extrude honing the hotaide? Effectively increasing the scroll
    m19lte likes this.
  11. #330
    RIP S3dave
    May 2004
    nr Glos
    7,185
    ker-ching!
    been there.... costed tooling.. Owch!
    nice process mind you but... need to churn a few out to pay for the tooling costs
    Kennametal in UK do the process from memory
    www.badger5.biz
    bill@badger5.co.uk
  12. #331
    beachbuggy's Avatar
    Surrey
    1,745
    ker-ching!
    Gaz, hopefully in the next few weeks I'll have my k04 turbine housings, testing permitting, come the time you remove your turbo you are more than welcome to one.
    They have been been made designed to be better than the stock k04 housing.
    fully ported wastegate
    ported inlet and throat
    clearanced exit
    and correct length arm.
  13. #332
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by beachbuggy View Post
    clearanced exit
    or cool dan I go for that then haha solve all mi problems in one haha nice. Have to let me no when u have em and I'll get turbo off
  14. #333
    Aug 2010
    bradford
    1,252
    So iv added some preload few full turns and don't feel any different.
    whats getting me is my boost gauge says 11psi and my liquid gauge says 15.5 psi which is over the actuater pressure. My self I think the liquid is the most accurate so I'm not running the right actuater pressure I think till I can log it.
  15. #334
    beachbuggy's Avatar
    Surrey
    1,745
    Quote Originally Posted by s3gazz View Post
    So iv added some preload few full turns and don't feel any different.whats getting me is my boost gauge says 11psi and my liquid gauge says 15.5 psi which is over the actuater pressure. My self I think the liquid is the most accurate so I'm not running the right actuater pressure I think till I can log it.
    Liquid gauge/mapsensor is before throttle. Boost gauge is post throttleN75 feed - pre throttle, dyno take off boost sensor - post throttle15psi pre throttle , 11 psi post throttleMmmm where's the possible issue?!
  16. #335
    RIP S3dave
    May 2004
    nr Glos
    7,185
    same as conversation with gaz yesterday........... pressure difference across tbody..
    logs being done to confirm how much the tbody is opening.. Suggestion that during mapping the tbody kept needing resetting ??
    www.badger5.biz
    bill@badger5.co.uk
  17. #336
    Jan 2012
    Stockport, Cheshire
    748
    Gaz was on the dyno again today, made very similar power to when I ran it so it's all good. Lower torque as &lt;br&gt;<br>
    it's running less mid range boost. Also runs were done in succession so the last run would make more if the car was allowed to cool. So Gaz is happy - still wants more boost though!
    Rick
    Jason.s and StaceyS3 like this.
  1. large port head advice AEB/AGU for engine build on A4 bfb block
    By dubmx in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2012, 18:09
  2. Research done decisions made :) ( aarons engine build )
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2011, 19:15
  3. Research done decisions made (aarons engine build)
    By AARON77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2011, 18:52
  4. Replies: 0
    Last Post: 14th September 2011, 11:49
  5. Engine build ideas,
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2009, 17:01
