EM TuningMonster Motorsport
Page 3 of 9 FirstFirst 123456789 LastLast
Results 81 to 120 of 336
Like Tree127Likes
Thread: s3gazz's slow engine build
  1. #81
    Aug 2010
    bradford
    1,252
    I did not no it was the chip a thought It could of been owt else up with car so left it till I could get someone that new what they were doin to look into it dan
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  3. #82
    RIP S3dave
    May 2004
    nr Glos
    7,141
    Quote Originally Posted by s3gazz View Post
    For clarity: And How This Reads:
    So Dan, who TOLD YOU already it was faulty, you IGNORED it, thinking he perhaps did'nt know what he was doing?? (seriously???) and waiting for someone else who ALSO knows what they're doing, to confirm its fecked?
    That reads so wrong gazz its unreal..
    Jeez
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  4. #83
    Aug 2010
    bradford
    1,252
    Dan did not tell me it was fooked bill he said it could just be down to not been mapped simples why would I change it if it I thought it just needs mapping and saved for that so I could put it right
  5. #84
    RIP S3dave
    May 2004
    nr Glos
    7,141
    Thing is I know he did.......
    He's said in this very thread Gazz he told you it was faulty..........
    whatever
    bill@badger5.co.uk
  6. #85
    beachbuggy's Avatar
    Surrey
    1,741
    And when I sent it back with a stock map, and you still had the fault I said it had to be n75, boost leak or Ecu.. N75 was apparently right , no leaks and i believe you changed the map sensor after an altitude pressure fault code.. It makes no odds to me but I told you it had to be Ecu and then you text me in the 25th June to say its the Ecu which is at fault and some guy was sending you a spare! Hence why I thought you had replaced it already, obviously not!
    I'm just surprised you seemed a little surprised when Rick told you.. Glad it's all sorted now though and looking forward to the results
  7. #86
    Aug 2010
    bradford
    1,252
    Lol iv got txt on my phone saying it just might need mapping so u wrong there
  8. #87
    Aug 2010
    bradford
    1,252
    Thanks dan ill sort somate out about logs when been on dyno
  9. #88
    beachbuggy's Avatar
    Surrey
    1,741
    Yeah and I also told you it might be the ecu!
    So have I ..... on the 28th may I told you it was an n75 , ecu or boost leak issue.. You told me the n75 was ok and no leaks..
    you told me that if you take it down to niki and it's not the ecu then it's a waste of a trip..
    on the 31st may you told me the map sensor fault came up. And you didn't want to buy a new one if it was the ecu..you asked if I had touched the map, to which I replied no just flashed your original tuned file back on..
    on the 6th June,, you told me it must be the ecu as you bought a new map sensor and it still had the fault..
    I then offered to flash a completely stock map back on to eliminate the map...which I did
    on the 25th.. You txt me to say that you had been told the ecu was damaged and the altitude chip was telling the n75 not to work..someone was sending you another ecu..
    whilst I might not have actually said.. "Gaz your ecu is faulty, go out and buy another one now" I said it was faulty and so did someone else! I was diagnosing it all by text and postal service, I did say it was the ecu at fault and when the map had be eliminated it was going to always be hardware.. something you confirmed to me after someone else told you it was.. My point being I am suprised it took a 3rd person to tell you..
    Its no issue to me, but like I said I was always under the impression you had bought another ecu and hence the suprise to here Rick said you need a new one!
    It surely wasn't a suprise to you?
  10. #89
    Aug 2010
    bradford
    1,252
    New ecu bought Rick will have this Tuesday and then go from there.
    how does the chip just go bang when nothing been touched or done to it apart from a flash these things just don't happen do they lol.
    so this is why I didn't want to waste my time on another ecu when I wanted to be shore my self by someone that nose what there doin do like guessing
  11. #90
    beachbuggy's Avatar
    Surrey
    1,741
    Flashing an an ecu isn't going to make an ecu chip pop.. Short circuits and bad wiring looms , water somewhere it shouldn't be will...
  12. #91
    RIP S3dave
    May 2004
    nr Glos
    7,141
    Question is:
    if wiring, wonder if the next ecu will also fail
    bill@badger5.co.uk
  13. #92
    Aug 2010
    bradford
    1,252
    Unless it was damaged in transit no wires have been touched
  14. #93
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I think they're referring to the loom into the ECU and not the wiring within the ECU.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  15. #94
    Aug 2010
    bradford
    1,252
    God nose then westy we will see when the new ecu is fitted pal
  16. #95
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Bill why get involved in something that does not concern you as usual?
    This is how i see how it went and yes i was there...
    Gazz built is engine up and asked dan to put a safe map on it until it was mapped....
    gazz got the ecu back from Dan and on the first engine start after the build it would start but not run....
    Dan said there maybe a fault in the map, send it back and he will put the original map on....
    Gazz sent the ecu back off and when he got it back from Dan it ran ok although it had an internal altitude sensor problem...
    And thats how it has been since, nobody is blaming anybody, these things happen, stop making mountains out of mole hills....
    The main thing is now is that Gazz gets another ECU in and it gets back to its full potential with a nice map from rick to compliment Dans hybrid....
    Jason.s and s3gazz like this.
  17. #96
    Gizmo20VT's Avatar
    Jun 2012
    289
    Need a popcorn Icon!
  18. #97
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Gaz, after all the effort you've put into this I hope it bloody flies.
    s3gazz likes this.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  19. #98
    RIP S3dave
    May 2004
    nr Glos
    7,141
    Dave, seriously??......... as Usual?? Lets not forget the many other self inflicted problems on this build by Gaz. (your future son in law for others reading this)
    ............. flashing it would not have damaged it.
    If its FAULT occurred when in the car....... then there is possibly something about the car/install which damaged it..
    Thats what I have said........... and if thats the case, the replacement ecu may also get damaged.
    Its possible, but rare in my experience for an ecu to develop such an issue without external influence.
    things which can blow ecu's are lambda heat circuit shorts for example...
    I say this as something to help, not hinder. Gaz has had enough "issues" already.....
    Please STOP taking things the wrong way Dave.
    bill@badger5.co.uk
  20. #99
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Wow .... dont know whats meant by this at all....
  21. #100
    Aug 2010
    bradford
    1,252
    Thanks Dave that's exactly what happened.
    the ecu came back with this problem bill not before so that's why I think it's been done in transit or will doing something with the ecu not blaming dan he's a top bloke just saying.
    doing an engine build shortly will not damage the ecu but we will see when new one turns up
  22. #101
    Aug 2010
    bradford
    1,252
    What do u mean by that comment daves on about future son in law
  23. #102
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Gazz you are one of the unlucky members for sure, so i hope the new ecu is ok and rick can bring a nice conclusion to the build, regardleas of what went wrong and whos fault it is, that doesnt matter when all you want is a car thats finished and driveable
    s3gazz and Gizmo20VT like this.
  24. #103
    Jan 2012
    Kilmarnock, Scotland
    336
    at a guess - your engaged to Daves daughter?
  25. #104
    beachbuggy's Avatar
    Surrey
    1,741
    You possibly can damage an ECU during an engine build, if as part of the build you have to remove any of the wiring loom or unplug a sensor the wiring can get damaged.. This may, and I'm not saying it will , could cause a short in the wiring , which when you start the car could fry the ecu or a component..
    I think this is why there is some concern that if this is the case and you put another ecu in the car it will do the exact same thing.
    Maybe a new ecu will go in the car and all will be fixed , happy days, and the mystery behind the blown chip may never be resolved, but £50 to fix a car which has cost £X000's already is a small price to pay....I just hope it gets sorted asap for you...
    s3dave and s3gazz like this.
  26. #105
    Aug 2010
    bradford
    1,252
    Thanks lads and so do I hope I fixes the problem too lol.
    i see what u mean buy a short out and could be the case ill have to see if its the wiring that's at fault then if the new ecu does not work.
    yes Karl I just want a nice drivable car and get some nice figures out of her for the money been spent.
  27. #106
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,326
    I don't get the hostility towards friendly advice...
    pardon my rudeness here Dave / Gaz, but might I suggest, given the epic wealth of success you two have had with your respective Hybrid builds, that you quite possibly need all the help you can get....
  28. #107
    Aug 2010
    bradford
    1,252
    Suppose that what I get not paying the extortionate build prices and not nowing a thing about engine I think iv done quite well and no the 1.8t engine very well now. Some people won't ever change a DV lol so for me to do two engine builds iv come for we all start somewhere so it's not that iv fooked my car up lol
    superkarl likes this.
  29. #108
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You know something prawn, that is beyond rude, do you even know what happened to my engine?
    Gaz made a mistake and it cost him dearly, and he as learnt from it..
    Friendly advice? do you even know what you are on about?
  30. #109
    May 2010
    Bedford
    2,877
    Also not everyone has an army of bumlickers from a zillion different forums that will drop everything and come to the rescue if anything goes wrong. Most people if it goes wrong are on their own or recieve a bit of help or a slating on a forum.
    I think as you mention despite the dramas you`ve done well to get stuck in yourself. I certainly wouldnt to that extent.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  31. #110
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    now irrelevent people have joined in...
    Gloating of success when others have fallen, how things have stooped
    If mine blows up id still have some pride that id attempted it, as gazz should.
    And this ecu problem will be solved in time, sooooo, wheres the beef?
    [Dave B], s3dave, Jason.s and 1 others like this.
  32. #111
    Aug 2010
    bradford
    1,252
    Thanks Karl and Jason I try and have tried with everything I can on my car and get slatted for giving it a go fooooks me off really but or well.
    bill had a problem with Stacey's car dint he and he's been doing it years no slating there I see.
    Jason.s likes this.
  33. #112
    RIP S3dave
    May 2004
    nr Glos
    7,141
    for clarity.. I had a problem with the supplied built by customer car - yes.
    well documented, and not something I wish to experience again, nor stacey... one thing after another = frustrating and expensive
    hope yours Finally comes good.
    you have at least stuck at it, and are hopefully within sight of a decent conclusion. plenty of others chuck the towel in and break them.
    So how long does rick need it for his mapping magic?
    s3gazz likes this.
    bill@badger5.co.uk
  34. #113
    May 2010
    Bedford
    2,877
    Ah well atleast if there are issues Rick wont plaster it all over Facebook embarrassing the customer and having people judge what someones done by accident or put it on public forums before the customer even knows themself.
    [Dave B], s3gazz and ScottD3 like this.
  35. #114
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,326
    i don't Dave, no. I know you've had some pretty **** luck with it though and I'm sorry about that.
    I wasn't gloating at all, merely taking the thread at face value for what it is.
    Gaz has a known ecu issue, a possibly cause was pointed out, and the provider of said info was rudely told to butt out.
    I havnt slated you at all Gaz, I think it's great that you've done it all yourself, it's a credit to you mate, I just don't think rudely dismissing the opinion of someone with far more experience than any of us is the way to help your self....
  36. #115
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,511
    Tbh if this thread becomes any more hostile I'll close it without further warning. There is no need . I logged on to see how it was going and find this. Sigh.
  37. #116
    Aug 2010
    bradford
    1,252
    ye i love to do these things my self it's a hobby we all have good and bad time in doing so its just a learning curve.
    bill he said a few days but told him to keep as long as he needs no rush. I'm making a large port inlet to also a better flowing map sensor pipe
  38. #117
    Aug 2010
    bradford
    1,252
    Np pal dint mean slating me as in u just when ever somate goes wrong people have a go lol and I try and stick at it all the way kinder p...ies me off when I try my best but not seen no one else get same treatment as me haha
  39. #118
    Aug 2010
    bradford
    1,252
    Lets all forget and move on and see what this BBT baby can do hehe
  40. #119
    May 2010
    Bedford
    2,877
    Quote Originally Posted by Byzan BAHons View Post
    By close you mean close to clean it up? Because closing it would be a bit harsh on Gazz`s part. Not his fault people came in and started causing a ruck and shouting at him and playing the blame game for no reason.
    s3gazz likes this.
  41. #120
    Apr 2004
    12,511
    Quote Originally Posted by Jason.s View Post
    I meant close, harsh yes, but that's how it is. I read it differently, I am however not going to talk about this anymore.
    Gaz is happy to move on, I suggest others do the same. Thanks
  1. large port head advice AEB/AGU for engine build on A4 bfb block
    By dubmx in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2012, 18:09
  2. Research done decisions made :) ( aarons engine build )
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2011, 19:15
  3. Research done decisions made (aarons engine build)
    By AARON77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2011, 18:52
  4. Replies: 0
    Last Post: 14th September 2011, 11:49
  5. Engine build ideas,
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2009, 17:01
