Badger5Chris Nott
    Sep 2011
    Scotland Dumbarton
    246
    Dreaded first fault code after mapping...
    Just randomly last week I went to start the car after finishing work when the abs and traction control light came on have had a quick scan to tonight and I'm getting the code 01316 and have had a quick look on here for ideas....but not really sure, it come under the Haldex section on the scan for the whole car....I have my catch can almost directly above the abs block and it is dripping a bit so I thought it could e related???
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    01316 - Ross-Tech Wiki
    01316 - ABS Control Module: No Signal/Communication
    Possible Causes
    Wiring/Connector(s) from/to ABS Control Module faulty
    Fault(s) stored in ABS Control Module
    Possible Solutions
    Check Wiring/Connector(s) from/to ABS Control Module
    Check Measuring Value Blocks (MVB)
    Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    Unrelated to mapping I would think...
    <tuffty/>
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Yea, as above, nothing to do with mapping
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Sep 2011
    Scotland Dumbarton
    246
    i didnt really think it was related to the mapping, it was just a question of what the 1st code i would get after the mapping would be, still no nearer to solving this issue yet anyway think i'll need toget the connection to the abs controller off tohave a butchers.....
  1. a3 2.0 tdi BKD 8P fault codes after remap!!! worried!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 18:24
  2. How to drive after clearing any engine fault codes? Like you stole it?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2011, 16:54
  3. MAP sensor fault code 16492
    By RLilleyman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2009, 20:07
  4. Replies: 1
    Last Post: 26th September 2006, 12:08
  5. Fault codes diags after remap - Star Performance
    By prel2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th September 2006, 13:56
