Badger5Volks Autos
    Aug 2012
    Unhappy a3 alarm problem
    Got an A3 1.8t today, it had been stood for months so had to put a new battery on... the keyfob does not lock/unlock the doors and the alarm wont stop going off, no siren just the hazards flashing.
    Ive tried locking and unlocking with the key with no joy and even when started up the hazards just keep flashing.
    anyone????
    colicabcadam
    man that sucks, first post and it's a problem
    seems like you need the keys paired with the alarm to be honest ?? i am sure someone else will advise it obviously starts up ok right ?
    Aug 2012
    yeah starts and runs fine, just hazards wont stop flashing
    colicabcadam
    immob is still paired then
    probably the alarm module is shot, i know this sounds silly, but have you changed the battery in the key lol ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    I would get the car scanned with VCDS tbh... it will show any fault codes related to the alarm module including which sensors have set the alarm off..
    Tbh if the car starts and runs then I doubt its a key coding issue as its coded to the immobiliser... what I suspect has happened is the common battery backed siren issue of flat/duff batteries....
    If badly corroded I have heard it can bugger the alarm module too... further info here...
    My minor modding thread
    <tuffty/>
    Aug 2012
    cheers guys, will check tomorrow and let you know
  1. Alarm problem
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2005, 15:25
  2. Further twists to my alarm problem
    By FactionOne in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 14:02
  3. S3 Alarm Problem...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2004, 12:27
  4. arggggg! A3T alarm problems :(
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2004, 10:52
  5. ALARM PROBLEM
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th July 2004, 19:41
