Volks AutosJMB Retrofits
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    871
    Add Vex182 on Facebook
    Post Quick question: Will this cable fit the S3?
    Need to buy myself "a cheap eBay cable" like I read on here a lot. Would this do the job and then I download the free version of VCDS on my laptop.
    VAG GROUP USB OBD2 II KKL ECU DIAGNOSTIC CABLE LEAD Compatible VCDS-LITE or 409 | eBay
    Cheers!
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Yarp...
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    871
    Man that was a quick reply! Thanks! Can old fault codes still I it's memory still slow the car down or cause it to be careful with out going into limp mode? I left a sensor unplugged one night when i changed my alternator and I felt like after I plugged it in, it's not felt 100% - could be just me though!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Fault codes will remain until cleared...
    Depends on the fault code... a 17705 can induce limp mode if its a recurring fault... scan for faults and take it from there
    Useful resource for fault code...
    Category:Fault Codes - Ross-Tech Wiki
    <tuffty/>
  1. Quick wheel question - will this tyre / alloy fit my S3?
    By Denty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2011, 20:25
  2. Question!! Will this fit ??
    By smythey1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2010, 20:29
  3. quick question...Will this size wheel fit?
    By piers90 in forum A5/S5/RS5 Forum
    Last Post: 30th October 2010, 18:09
  4. Will this turbo fit the a3 1.8t 1999
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2010, 09:07
  5. Quick Question. Will standard wheels fit brembo's?
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2009, 11:17
