JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Andyrew_69's Avatar
    Aug 2012
    54
    Coilovers/Tie Bars - Still unsure which to buy after reading a few reviews! Help :)
    Hi there I am currently after purchasing a set of coilovers for my S3. Ideally wanting something adjustable but wondering if its worth spending that little bit extra for just a little adjustment when a pre set coilover is good enough??
    Purpose of car is fast road car/track use but I am not to bothered about a slightly harsher ride as long as handling is much improved as stock set up there is far to much body roll!!
    Which adjustable rear tie bars are people using?? I'll fit poly bushes when fitting these.
    Also will I need wheel spacers?? Running the BBS Anniversary Golf wheels.
    And also where is best place to get all these goodies??
    Thanks a lot
    All help appreciated and pictures of cars lowered would be a bonus to get an idea of looks ;-)
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    Adjustable damping is a nice thing to have when tracking a car but you need to think weather you'll actually get the use out of it or not.
    Did you have a budget in mind?
    Yes I'd personally go for some front and rear spacers with those wheels.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Andyrew_69's Avatar
    Aug 2012
    54
    Quote Originally Posted by DPM View Post
    Budget not really thought to much about it as want it to be right so don't want to cut corners. Id probably say between 600 and 900 on coilovers.....
    What wheel spacers would you suggest and what width??
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    Depending on how low you go and what look you're going for, around 20mm rear and 10mm front would fill the arches up nicely.
    DPM Performance
    T: 01207 561606
    Andyrew_69's Avatar
    Aug 2012
    54
    What prices can you offer on the AP coilovers or the Kw Variant 1's with a set of rear adjustable tie bars? thanks
    Diesel Quattro's Avatar
    Sep 2009
    Cheshire, UK
    119
    Good to see the comments as i will be looking into this finally. i want a comfy ride, but want it lower so it sits nice and unsure if tie arms will be needed with a small drop?? also can i just use the standard shocks and lowering springs??
    also what width is the max for wheels?
    aaron
    A3 Tdi Quattro 3Dr 51 Plate
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    I'll PM some prices over.
    DPM Performance
    T: 01207 561606
  1. Which adjustable tie bars?
    By s3 Hoggy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2012, 17:56
  2. Which Tie-Bars/Control Arms?
    By S3 HODGE in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2009, 16:53
  3. Tie bars, Coilovers and ARB fitting costs!
    By Olly P in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 19:02
  4. Which tie bar to change
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2009, 20:39
  5. KW Tie Bars/Control Arms Group Buy
    By DPM in forum DPM Performance
    Last Post: 19th February 2008, 10:56
