Chris NottJMB Retrofits
    Jun 2004
    Surrey, UK.
    269
    Tupperware, clips made of cheese and sparks
    I changed the sparkplugs this evening. Put in NGK Iridiums BKR6EIX. The original ones looked like the NGK Is, but with Audi 4 rings on the insulator. They were dry, no oil, grey ish in colour. The tip is about half worn compared to the new ones.
    Does it mean that I need to put in cooler plugs ?
    Also I had to take off a small black box that was obscuring the 3rd and 4th coilpack, that doesn't look like it's doing much, it has a pipe coming out of it and connects to a rat's nest of pipes connected to a electrically operated valve.
    Whats the black box for ? Valve ?
    Is it for emissions ? Is it part of the EGR ? Can it be removed ?
    Also I broke the clip on the coil pack connector :-( I reckon they're made from Jacob's finest.
    It was well worth changing the plugs, much smoother. Car is slightly faster, but that might be the cool night air though.
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    534
    Hi mate,
    That small black box and "rat's nest of pipes" as you so rightly put it is a vacuum chamber, all part of the N249 sensor system. Yes it can be removed, plenty of guides on here - check out the sticky for N249 delete.
    Cheers,
    Aran
    Jun 2004
    Surrey, UK.
    269
    Cheers Mr Squirrel, I'll search for it.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    N249 Bypass How To (2000 S3 - but same for many)
    If you have a bam engine car like mine its a peice of cake as you need about 1m of silicone tubing and you run this from the top of the DV to the inlet on the bottom of the throttle body leave the N249 sensor connected and bobs your uncle
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Jun 2004
    Surrey, UK.
    269
    yes I do have a BAM engine - means I don't even need a T-piece?
    1m of 4mm silicone tubing it is then.
    Cheers Bob
  1. Thermostat and spark plugs....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2010, 20:29
  2. Air filters and spark plugs for TQS
    By steveboyo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th June 2008, 20:32
  3. replacement filter and spark plugs for s3 2000 x
    By sleeksx in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2008, 13:45
  4. clean and sparkly in the sunshine
    By sitrials in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2007, 20:00
  5. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
