Volks AutosJMB Retrofits
    Jun 2011
    Northampton
    33
    Central locking stopped working
    Hi guys,
    I went to open my car this morning and the indicators flashed but none of the doors/boot opened. The alarm is working but even using the key doesn't prompt the central locking and just opens the drivers door.
    Is it likely to be the central locking pump that's failed? Where is it located?
    Thanks in advance
    '98 Audi A3 (8L) 1.8T Yellow
    K03s turbo - Forge 007p - AMD remap - Milltek exhaust - Eibach springs - 18" TT Quattro Sport alloys
    VAG-COM says 176.18 g/s (220bhp)
    Dec 2011
    Basingstoke
    84
    Will bet its the graphite impeller in the pump shattered, its located behind the nearside boot trim under the sub.
    Jun 2011
    Northampton
    33
    So basically a new central locking pump? Is it easy to access?
    Dec 2011
    Basingstoke
    84
    Yeah, basically... there was someone selling impeller repair kits on ebay a while ago.... could be worth looking into that.
    Not too hard to access, but you do have to take quite a lot of trim out to get to the pump. If you do get an entire new pump, you will either have to code it with vcds or de-solder the pcb from your old pump and put it in the new one (much simpler imo).
    brasiliangringo's Avatar
    Mar 2010
    544
    Ebay the part number, there will be some out there - i sell them for around 60 quid (2nd) for the A4 not that i have any others unfortuately.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    A3 and A4 pumps are often the same.
    Its often cheaper to buy an old unit from an olde Audi 80 or similar, Those have more robust internals, and the vacuum pump be swapped over with a bit of tweaking.
    TD5 Land Rover Defender build
  1. S3 Central Locking stopped working
    By sportquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2010, 15:16
  2. central locking not working!!!!
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th August 2007, 10:03
  3. Central Locking stopped working
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2006, 15:01
  4. Central locking not working
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2006, 21:24
  5. HELP!!!!! Central locking not working.
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2004, 08:57
